I got a roof condition P0172
Discussion in 'General Tacoma Talk' started by BrokeTacoma2.7L, Aug 19, 2023.
  1. Aug 19, 2023 at 4:28 PM
    BrokeTacoma2.7L
    BrokeTacoma2.7L [OP] Member
    Kevin
    It’s definitely running rich ive trown numerous parts at it but I can’t solve the issue. Any suggestions? p0172 is only code
  2. Aug 19, 2023 at 4:36 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    You checked your operating temp?
    Your TW Sensor reading?
    Map Sensor reading?
    Bivouac and BrokeTacoma2.7L[OP] like this.
  3. Aug 19, 2023 at 4:39 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
  4. Aug 19, 2023 at 5:39 PM
    BrokeTacoma2.7L
    Kevin
  5. Aug 19, 2023 at 5:41 PM
    BrokeTacoma2.7L
    Kevin
    Oh, I will check it. The temperature seems to be running normal on the dash gauge about 200 to 95 on dash coolenant temo, but I’ll check that TW on my scan tool I don’t remember checking that definitely something to look at. Thanks a lot for the reply. I’ll keep you posted.
  6. Aug 19, 2023 at 5:42 PM
    BrokeTacoma2.7L
    Kevin
    P0, 172 is the only code and it is rich. Usually a other associated systems will/maybpop a code to give guidance but I’ll definitely check that thanks a lot and I’m going to check the fuel lines too
  7. Aug 19, 2023 at 5:43 PM
    BrokeTacoma2.7L
    Kevin
    Map sensor is reading but it’s not OEM. It’s a cheaper and a off brand sensor may be better off ago with something more high-end or OEM, When I unplug the map sensor, the truck shuts off, you the old junkyard test but that does not necessarily its calibrated correctly I guess
  8. Aug 19, 2023 at 5:44 PM
    BrokeTacoma2.7L
    Kevin
    I do appreciate the reply and all comments, I appreciate any ideas thx so much
  9. Aug 19, 2023 at 5:48 PM
    BrokeTacoma2.7L
    Kevin
    I remember changing the valve cover gasket that wiring harness going to the TW got stretched possibly, it it’s on the back of the engine, very hard to access, moving the harness around to get to the valve cover bolts I could’ve pulled wiring loose or made it intermittent. but I can check It was a scan and should give me some good info. Thx again
  10. Aug 25, 2023 at 5:56 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Now that you have fired the parts Cannon so many new unknowns may have been added to the equation.
    There are many threads that discuss trying to repair this PO code.
