I Got asphalt stuck on my tire (bad), how do i get it off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4X42HEL, Jul 5, 2011.
  1. Jul 5, 2011 at 5:24 PM
    4X42HEL
    4X42HEL [OP] Well-Known Member
    San Diego
    2019 DCSB TRD-OR 4x4
    If you can believe my luck, I was picking up the wife today from work, and today is not a particularly hot day (it's hot, but not abnormally hot). I was driving way and I felt my tire was extremely heavy (driver's side front) as if I was in mud or something...
    I get out to look and sure enough, about 40% of the tire has gobs of asphalt stuck on it. I tried to drive it off, but it only made matters worse. Now I am at home, and the damn tire has asphalt basically glued to it so it's part of the tire. The truck shakes so bad like it has the worst alignment job and out of balance.
    I tried to take as much off as possible with a knife and welding iron brush... any other thoughts? Hate to scrap a tire which has 90% tread left on it....
    Pics to come shortly. Thx
  2. Jul 5, 2011 at 5:28 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Do Not put any chemicals on it! use a power washer and scrape
    where needed, should come off
  3. Jul 5, 2011 at 5:32 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Damn that sucks best of luck to you. Try and peel it off
  4. Jul 5, 2011 at 5:33 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Hairdryer to heat up the asphalt, then a putty knife to scrape off. Brake cleaner is said to work well, but you will have to wash it off quickly to minimize harm to the tire compound, so use it as a secondary operation for smaller bits that didn't scrape off.
    SocalTaco15 likes this.
  5. Jul 5, 2011 at 5:35 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    How about a heat gun or torch to get it soft and then scrape it off....
  6. Jul 5, 2011 at 5:38 PM
    4X42HEL
    San Diego
    I think I will try the hair drier idea right now.
    I just dumped two pots of boiling hot water on it and it didn't even phase it.
    It's like solid now. So frustrating the S#!T that happens to me.
  7. Jul 5, 2011 at 5:44 PM
    ETaco23
    Evan
    PNW
    not sure a hair dryer is ganna get it hot enough...
    You will need a heat gun or torch... if you use a torch just be careful and dont stay in one spot too long...
    power washer is a good idea too.
  8. Jul 5, 2011 at 5:50 PM
    4X42HEL
    San Diego
    How did you do a burnout with your front tire? I have a tacoma....
  9. Jul 5, 2011 at 5:52 PM
    4X42HEL
    San Diego
    Well, I'm not sure where the hell she buys this crap from, but my wife's hair dryer must be made of plutonium because it just melting this asphalt like butter.
    The good thing is, it is coming off, but the bad part is, its getting really gummy and this is tedious. No way I will get it off before the night.
    Anybody know if this stuff will "just fall off" as I drive?
  10. Jul 5, 2011 at 6:04 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    Burnout Time!!!
  11. Jul 5, 2011 at 6:13 PM
    ETaco23
    Evan
    PNW
    Yeah, it ganna be tedious, but if get most of it off, the rest should slowly come off as you drive.
    If not you can use a solvent to clean the rest off.. I think Aircraft remover would work really good for that.... :)
  12. Jul 5, 2011 at 6:16 PM
    4X42HEL
    San Diego
    I just dont understand how hundreds of cars park in that lot every day and there haven't been any known occurences of this.
    I pick her up ONCE and for 3 minutes waiting the lot, this happens.
    OK, now i'm officially pissed. Where's the fridge
  13. Jul 5, 2011 at 6:20 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Get "Tarminator" Had this last year when the fukstik construction turds didn't bother removing a little pile of fresh tar they dropped at an intersection. It spooged all up in my treads I was PISSED. I went to the parts house and bought "tarminator" and half a can knocked off every last bit of tar this stuff is fantastic!
  14. Jul 5, 2011 at 7:08 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    Isnt tar a rubber compound? Wouldnt that damage the tire? I may be wrong.
  15. Jul 5, 2011 at 7:24 PM
    Grande
    Grande Well-Known Member
    Victorville, CA
    Thomas, The little truck that could
    Painted badges. Bedlined grille, wheels and lower valence. Billies 5100 @.85 up front. Dodger Jack Ball Mod. Custom trail damaged rear bumper (for the time being). Lil LED light bar on grill. Hard-wired Radar Det. Custom Projector fog lights, Anytime Fog Mod, HIDS, White LED accent lighting on a Single post double toggle swicht, so they light up wit my door/dome light, or always on, or never on. LED map and dome lights.
    X2
    just find an open lot and let her lose :burnrubber:
    or the heating up way be better and safer and cheaper, so i would try somthin like that first, but if all else fails, u kno what to do :D
  16. Jul 5, 2011 at 7:33 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Know any commercial roofers? I'm one and if you can get your hands on carlisle weathered membrane cleaner it'll tske it off pretty easy. We get fuktards all the time that put tar on a rubber roof. Anything petroleum based will eat through a rubber roof.
  17. Jul 5, 2011 at 8:01 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Know what happens when ya do a burnout with tar stuck to the tire? You heat up and spread the tar further across the tread. Please-just try the Tarminator stuff.
  18. Jul 5, 2011 at 8:11 PM
    himmy33
    himmy33 Well-Known Member
    Washington
    2014 Tundra 1794 edition.
    I would add a powder or even sand to the tar when you are removing it with the hair dryer. Dump lots of cornstarch/sand.dirt etc. on the tar that way it has something to bond to and it doesn't stick to other things. Could make the job much easier.
  19. Jul 5, 2011 at 8:24 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    that asphalt companies that work for me coat everything with diesel. they use it to clean their tools too.
    not so sure what it would do to the rubber.
  20. Jul 5, 2011 at 8:35 PM
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    Throw it in neutral, strap up to either a Veyron, John Force, or someone you know that has V-tec technorogy and get up to 88 mph before the end of the train track. That oughta do it.
