I Got asphalt stuck on my tire (bad), how do i get it off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4X42HEL, Jul 5, 2011.
  1. Jul 6, 2011 at 10:31 AM
    #41
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    hahah. i changed out my chevy in-line fuel filter in the street. the leaked fuel dissolved the AC, and it got stuck in my hair!! i was effed! i had to spray my head with WD-40, rub it in..and luckily it came out. now i have no hair..but hopefully it is genetics, not my stupidity. solvents are our friends.
  2. Jul 6, 2011 at 10:38 AM
    #42
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ^ that's what I was thinking too, except I would have tried an upside can of that condensed-air key board spray or dry ice.
  3. Jul 6, 2011 at 10:46 AM
    #43
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
  4. Jul 6, 2011 at 10:48 AM
    #44
    OffroadToy
  5. Jul 6, 2011 at 10:55 AM
    #45
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    old guy advise or younger know it all view....hmmmmmmmmm who wins
    LOL. Live and learn the hard way like we did then. :D
  6. Jul 6, 2011 at 10:59 AM
    #46
    Ridgerunner
    Frank
    Rocklin, Ca.
    Yeah you are so right Dave-what the hell did I bother for??
  7. Jul 6, 2011 at 3:15 PM
    #47
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    x2...
    You can't force anyone to listen, you have provided what appears to be sound advice and that is all you can do.
    Do you own the company or stock in it?!
  8. Jul 6, 2011 at 3:25 PM
    #48
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Diesel and gasoline will soften your tires when you use it to clean tires/rubber. incidental contact is no problem.
    Tar is what's left of crude oil when they boil off the more volitile gases ie. gasoline, kerosene, etc.
  9. Jul 6, 2011 at 3:41 PM
    #49
    OffroadToy
    Have you tried urinating on the tire? :notsure:
    medic2230 likes this.
  10. Jul 6, 2011 at 3:47 PM
    #50
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Awwwww... Piss on it!
  11. Jul 6, 2011 at 4:09 PM
    #51
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Call the paving co. and ask them how to get it off they must deal with it all the time got to be all over their equipment.
  12. Jul 6, 2011 at 4:12 PM
    #52
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    We deal with it like Ridgrunner said, use Deisel fuel, or burn it off........The latter is not a good option for it stuck on tires.
  13. Jul 6, 2011 at 8:26 PM
    #53
    4X42HEL
    4X42HEL [OP] Well-Known Member
    San Diego
    2019 DCSB TRD-OR 4x4
    Ok, so, update:
    I went to discount tire because the guy said he could help me (if they couldnt, i would try the tarminator...). After 5 min he came inside and said "holy bleep" then said he never got one with that much. He picked out as much as he could, then had to use their largest weights to balance it and i had them swap it with the back wheel. Tomorrow we will see.
  14. Sep 9, 2016 at 1:06 PM
    #54
    ddeeren26
    ddeeren26 New Member
    daphne
    traverse
    Call your state department of transportation, or the company that owned the parking lot and is reslonsible for its upkeep, and get a new tire. problem solved. Just had this happen to me, the shit made me think I had a flat.. over 50% of my tire covered in it.
    asuchemist likes this.
  15. Sep 9, 2016 at 1:32 PM
    #55
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    It's been 5 years..he either got new tires or just drove it until if fell off.
    Welcome to TW
    tcjacado and Nickel like this.
  16. Sep 9, 2016 at 5:01 PM
    #56
    ddeeren26
    daphne
    traverse
    thats the beauty of the internet, if someone googles the same question they will see my response as an option for them.
    asuchemist[QUOTED] likes this.
  17. Sep 13, 2016 at 12:20 AM
    #57
    shakerag
    shakerag Member
    don
    Ozark Mountains
    14-Tacoma extented cab
    Hello
    I worked for a asphalt company as a young man and when one of the company pickups had that problem they would remove tire and wheel and put in a wash tub and cover it with diesel fuel and let it soak the asphalt off. Diesel fuel works when sprayed onto paint to remove asphalt splashes. Hope it helps
    ddeeren26 and TrdSurgie like this.
  18. Aug 10, 2019 at 7:19 PM
    #58
    AirOverTop
    AirOverTop New Member
    Eddy
    Had same problem and solved it today.
    Used heat gun (Master Appliance, 110 volts, 20 amps, 170° F) to melt the tar and easily raked it out of my tread with several dull screwdrivers.
    Warning: Be careful. If a chunk of hot material gets on your bare skin, it will take skin with it when you flick it off. (Don't ask me how I know this.)
    Jimmyh and Thatbassguy like this.
  19. Aug 10, 2019 at 9:04 PM
    #59
    Renogasser
    Renogasser Well-Known Member
    Scott
    Nevada
    2013 DB cab TRD Sport
    Level kit 32” Goodyear Duratracs
    Most likely you picked up crack seal material, I know I worked in the pavement maintenance field for 30 years and when ever a vehicle picked up this material in its tires we always recommended the use of WD 40 to loosen and remove the crack seal from tires or paint. spray it on and let set till sticky and lots of elbow grease to remove with a putty knife it’s gonna be a mess and takes time but you should be able to remove most if not all with this method.
    Best of luck :thumbsup:
  20. Aug 10, 2019 at 10:14 PM
    #60
    Gus87
    Gus87 Well-Known Member
    Chicagoland
    16 trd sport
    I'm a paver. When I have to pick it off my boots i just wait for them to cool down and I pick it off with a flat blade screwdriver. I'm gonna have to go against everyone and say cool it down then go at it.
