i got new rear brakes done.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by faststang90, May 31, 2017.
  1. May 31, 2017 at 6:00 PM
    faststang90
    faststang90 [OP] Well-Known Member
    dwayne
    houston
    2010 Pre Runner
    I have about 115,000 on my truck on stock rear brakes. my pedal fills soft so I was thinking it was time for new rear brakes. I took it into the dealer they said that they was still good but they would replace them if I wanted. I got the drums turned and new brake pads installed for 229.50 not to bad. they said they bleed them and the truck stops better.
    ChadsPride likes this.
  2. May 31, 2017 at 6:27 PM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    Sounds like a fair deal. Worth it since truck stops better.
  3. May 31, 2017 at 6:27 PM
    Hunt4Fun
    Hunt4Fun Well-Known Member
    Jack
    2010 Tacoma DoubleCab Base model
    Bedrug, Viper alarm and remote starter, Access tonneau cover, Low off road 3/1 suspension lift, locking tailgate.
    Soft pedal is usually air in the lines. Bleeding out the air should indeed solve the problem. You usually change front pads 2-3 times before changing rear shoes. Did they check the front pads?
  4. May 31, 2017 at 8:14 PM
    faststang90
    dwayne
    houston
    2010 Pre Runner
    I looked at them at about 75,000 miles and they did not look bad. they told me that they was not bad but they did say that the drums needed turned so no reason to use old brakes on new turned drums. I already had it in the shop so just do them.
  5. May 31, 2017 at 8:21 PM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    That's a smoking deal from a dealership.
    Alexely999 likes this.
  6. May 31, 2017 at 8:29 PM
    Bishop84
    Bishop84 Well-Known Member
    Crazy deal, glad it sorted it all out as well!
    faststang90[OP] likes this.
  7. May 31, 2017 at 9:29 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I swear I had to replace my fronts around 20-30k. I'm at 6x,xxx now and rears are still looking great.
  8. May 31, 2017 at 10:08 PM
    morgul.03
    morgul.03 Well-Known Member
    08' SSM AC TRD OR
    When I replaced my fronts the rears were barely worn on my truck. Makes sense since most of your stopping power is your front brakes
  9. May 31, 2017 at 10:43 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I kind of hate the brakes on these trucks. They are overly grabby initially IMHO and when you really lay into it to stop they aren't really that impressive- even for a truck. I've been waging an ongoing war with the rears and their high tendency to squeal at low speeds with about 50% brake pressure applied, still can't seem to figure that one out.
  10. Jun 1, 2017 at 6:27 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    171k and my rear brakes are still good.
    did fronts first time last year at around 150k
  11. Jun 1, 2017 at 6:40 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    What kind of driving do you do?
    How were the front brakes/roters?
  12. Jun 1, 2017 at 9:29 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    100% agree with this statement, on the TRD OR at least.
  13. Jun 1, 2017 at 9:33 AM
    Pigpen
    Dan
    Northwest Montana
    I need to adjusts rears and replace front pads. I'm about to turn 90,000 miles on the originals. I tow and wheel with a very heavy (for a Taco) truck on load E true 33s.
    The brakes have been great under the abuse they see.
  14. Jun 1, 2017 at 9:52 AM
    knottyrope
    Knotty
    Bahstun
    I have a mix of driving. hauling a 3500lb camper 4 times a year, half back roads and half high way.
    front rotors didn't have enough left to be turned and pads barely had anything left on them but one was half down to metal and that's when I heard the grinding noise telling me to change them.
  15. Jun 1, 2017 at 9:56 AM
    Sheepshead45
    Sheepshead45 Well-Known Member
    NC
    PreRunner SR5
    I've been wondering if anyone else wore like mine have, I'm at nearly 160k on original brakes all around. Pretty unbelievable! I had it at the dealer at 90k for a bad front wheel bearing and they told me the fronts were around 50%. Mostly highway miles, manual transmission... gotta love it!!!
  16. Jun 1, 2017 at 9:57 AM
    Jack0928
    Jack0928 Kind of a Well-Known Member
    Jack
    Huntington Beach, CA
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    Pretty good deal! Im all about getting stuff done at the dealership if the price is right, cause if they mess up you can easily hold them accountable.
  17. Jun 1, 2017 at 10:01 AM
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    I would bet money your improved braking is from bleeding the brakes. Brake fluid is only useful for so long. In an ideal world, you would bleed them every 3 years or so, and at minimum every time you replace brakes. Rear drums last a longgggg time. I've seen cars with over 200k on them with stock rear brakes, still in decent condition. There's a front braking bias, especially with rear drum, so they don't have a huge impact on feel.
    That being said, that's a fairly decent dealer price.
  18. Jun 1, 2017 at 10:14 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Should have replaced the pads and rotors yourself. Would have saved a ton, and it's very easy to do.
    By the way, why do they machine rotors rather than just replace them with new ones? Isn't the cost about the same?
  19. Jun 1, 2017 at 10:48 AM
    knottyrope
    Knotty
    Bahstun
    shops get more money to machine them some times
    25 to machine
    55 new
    mine could not be turned, was at min thickness which means replace
