I got one heck of an oil change at the dealer, I'm not happy at all!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hotrod53, Apr 8, 2016.
  1. Apr 8, 2016 at 5:08 PM
    hotrod53
    hotrod53 [OP] Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Yesterday it was cold out and i went for a short run in my truck, I noticed my engine making a weird noise. I pulled over and listened, at first I thought it was the AC fan so I shut it off. Then I thought that maybe the air pump was still running for some reason so I lifted the hood. It seemed to be getting more faint, by this time I was a mile or so from home. I shut off the engine and tried to pull the dipstick, it was stuck! My first thought was huh, the dealer just changed my oil, why would it be stuck? I managed to get it unstuck and I read the oil level. I thought it can't possibly be right, so I wiped it and checked it 3-4 more times. To my surprise, the oil level is 3.5" above the full mark!
    Tonight I drained some oil, then drained some more, then some more, and finally more. Almost 4 FULL QUARTS overfilled! At this point I'm pissed, I emailed my service manage with a picture of the oil level on the dipstick. I left him a message that I want my oil and oil filter changed again, I'm wondering if the tech changed the filter without draining the oil and filled the crankcase again without ever checking the level.
    SOSHeloPilot likes this.
  2. Apr 8, 2016 at 5:10 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I wouldn't go back.
  3. Apr 8, 2016 at 5:14 PM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    Maybe they drained the trans.....you're positive on the reading? Cause I'm sure you know our dipsticks suck.
  4. Apr 8, 2016 at 5:14 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    DIY - problem solved.
  5. Apr 8, 2016 at 5:14 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    Rat, normally I would agree, but I have an 9 year relationship with this dealership and 4 Toyotas later. On my recent visit the service manager loaned me his own vehicle because he didnt have any more loaners. I have no doubt that he will make it right, I just hope that it didn't cause any damage.
    Yes our dipsticks suck and they are hard to read, what I find helps is painting the tip using a paint marker. That marks the level perfectly and takes out the guesswork.
    DIY, yes but trying to take advantage of the new vehicle Toyota care.... Or maybe it's Toyota careless?
  6. Apr 8, 2016 at 5:18 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Sounds like they drained tranny
  7. Apr 8, 2016 at 5:22 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    I'm not getting why you think they drained the tranny. If they did that, the tranny would now be dry and the crankcase would be overfull, I've only got one of those issues.
    No doubt I'll DIY soon, Tacomas are easy to change unlike my 2 Camrys. Those have plastic belly pans to remove.
  8. Apr 8, 2016 at 5:26 PM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    :notsure:
  9. Apr 8, 2016 at 5:35 PM
    jake72
    Jake
    N.E. PA
    From what I've read on here you have to flush the tranny to get all of the fluid out, and if you have the tow package you will still have fluid in there. I could be wrong though.
  10. Apr 8, 2016 at 7:55 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    How do you know the transmission isn't dry?
    shakerhood likes this.
  11. Apr 8, 2016 at 9:25 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Was the oil foamed when you drained it? If not I wouldn't worry too much about it...
    ThorInc and 1buzzbait like this.
  12. Apr 9, 2016 at 7:19 AM
    hotrod53
    Lynd
    Pittsburgh, PA
    I would not describe the oil that I removed as "foamed". I plan to check the tranny level before I go anywhere today.
  13. Apr 9, 2016 at 11:32 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yeah it sounds like they drained the transmission and then doubled your oil.
  14. Apr 9, 2016 at 11:34 AM
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    Yeah some one has drained the tranny and poured 5qts in there engine on this forum before. The 2 drain bolts are very close and it would be an easy albeit dumb mistake. Plus you said its making funny noises. Unless you know exactly what the noise is now...
  15. Apr 9, 2016 at 11:35 AM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Have them throw in an extended drive train warranty.
    ThorInc, digitaLbraVo and Joe D like this.
  16. Apr 9, 2016 at 11:41 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    They did not drain the transmission. It would not move if they drained the transmission pan, at least not very good.
  17. Apr 9, 2016 at 11:41 AM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    Just to give a small input. If the transmission was drained, it's just the pan that drains not the whole transmission. Most of your trans fluid is in the torque converter and elsewhere. So it "would" function as normal for awhile.
  18. Apr 9, 2016 at 11:43 AM
    koditten
    Kirk
    Central Michigan
    You will know it right away. It will move, but not very well.
    txtaco87 likes this.
  19. Apr 9, 2016 at 11:48 AM
    crazykilik
    crazykilik Well-Known Member
    Tim
    Dayton Oh
    TROUBLE (The good kind!)
    3 inch lift, 33 inch tires
    WTF, an oil change is on the same difficulty level as brushing your teeth. (especially for a toyota tech) No excuse is acceptable on this one. It could have done damage to your engine. I would have some choice words for those folks. :censored: You may want to take your truck somewhere else to have it checked, so they don't try to bamboozle you.
    digitaLbraVo likes this.
  20. Apr 9, 2016 at 12:01 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    So they messed up and now you are going to go have them do it again? :bananadead:
    robssol likes this.
