I got one heck of an oil change at the dealer, I'm not happy at all!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hotrod53, Apr 8, 2016.
  1. Apr 9, 2016 at 12:09 PM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    I had the opposite experience a couple of years ago:
    https://www.tacomaworld.com/threads/dealer-didnt-put-enough-oil-in-my-engine.313076/
    It's been more than two years and 40k miles since then and it seems like a distant memory. The truck is fine and as far as I can tell there have been no ill effects from that situation. I did switch to using another Toyota dealer for some maintenance and repairs, not just because of that one situation but because I think the second dealer does a better job in general.
  2. Apr 9, 2016 at 12:23 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This is oil change 101 not flush & fill trans maint. diff. thread...
  3. Apr 9, 2016 at 12:23 PM
    hotrod53
    hotrod53 [OP] Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I checked everything again today before I went anywhere, oil level is now good, couldn't find a dipstick for the transmission. Being that it's still under Toyota careless, I never had reason to look, maybe there isn't one like a Saturn???
    Here's the other thing...... I even commented to my wife that ever since having it serviced, my idle was rough, it made no sense. As of today and 4 quarts less oil, it's smooth again. It almost felt like the injectors were dirty and I noticed it the very same day and ever since the service was done! Maybe my crankshaft was laying in oil due to the overfull?
  4. Apr 9, 2016 at 12:26 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    It'd better be in oil or you'll have bigger issues...
    Thinking over fill affected top end
    digitaLbraVo likes this.
  5. Apr 9, 2016 at 12:36 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    You still need to check the transmission fluid level....There won't be a dipstick but there is a procedure on this site for doing it.
  6. Apr 9, 2016 at 12:43 PM
    nh_yota
    Jeff
    Portsmouth, NH
    It may be a little late for you, but in my case I made sure to have the service manager note it in my file and also had Toyota Corporate note it in their file in case something happened in the future.
  7. Apr 9, 2016 at 12:43 PM
    Chrome Beer
    Chrome Beer 7th Ceaser
    Dave
    Florida
    15 DCSB SR5 4X4
    Yeh checking the transmission oil is a bitch no simple dip stick. I drained my tranyfluid thinking it was the oil and put another 4 qts of oil in after having a few beers once. The truck actually ran fine on a 40 mile round trip from work.I noticed a lil slipping coming out of a dead stop and realized what i done. Everything was fine again until a few weeks passed then i felt a bad grinding one day leaving a parking lot. Traded that bitch in 2 weeks later for a 15.
  8. Apr 9, 2016 at 12:47 PM
    nh_yota
    Jeff
    Portsmouth, NH
    That's the good thing about have the manual transmission - you'd really have to go out of your way to mistake the transmission drain plug for the engine oil drain plug. However, I bet someone somewhere has managed to do it.
    Pigpen likes this.
  9. Apr 9, 2016 at 12:54 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Just look at the transmission drain plug. If its been removed recently you'll know it.
    shakerhood and nh_yota like this.
  10. Apr 9, 2016 at 12:57 PM
    nh_yota
    Jeff
    Portsmouth, NH
    Yup because you will see a clean/oily spot around the plug where they wiped it which will stand out from the usual dirt on grime built up on the drain pan.
  11. Apr 9, 2016 at 2:09 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    It's been about 1200 miles since the oil change, not sure if I can still tell if the trans plug was out. It sure didn't look like the oil drain plug was out and the dipstick was really stuck. I had to pull the dipstick and put some vacuum grease on the O ring to get it to go all the way back into the tube.
    These dipsticks really suck, they are hard to read on a good day. I find it much easier to read accurately if you clean and paint the end of it white. With it being stainless and smooth, the oil tends to run down the stick making it hard to tell what the level really is. As soon as you paint it, there is no question where the level is, it will hold on that paint.
  12. Apr 10, 2016 at 7:01 AM
    nh_yota
    Jeff
    Portsmouth, NH
    My dipstick gets stuck every so often but if I remove it regularly to read the oil level it tends not to get stuck. I think it's because crud and rust build up around the inside of the top of the tube near the yellow handle and jam the handle in place.
  13. Apr 10, 2016 at 7:29 AM
    gearcruncher
    Canadain bumper technician
  14. Apr 10, 2016 at 8:27 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Tell the service manager it now makes the same noises your '13 did, might get his attention. :rofl:
  15. Apr 10, 2016 at 5:33 PM
    #35
    calico
    calico Well-Known Member
    Northeast
    13 Tacoma Limited
    Viper Alarm and Remote Start Prestigious Society mod Camera display relocated to headunit Weathertec floor mats, window deflectors, and mud flaps Toyota Bed mat Tailgate lock Undercover SE tonneau and Swing Cases (driver and passenger) Hi-lift install Fumoto Qwik Valve ImMrYo Mirror mod Salex console organizer
    From the first time I changed the oil I have never been able to read the damned thing. For some reason there never seems to be a clear, clean line to indicate where the level is. Every time I pull the dipstick it always looks smeared. I just make sure I put in the required 5 1/2 quarts and don't worry about it.
    On a related note, I just changed the oil today. Last time I had it done was in early February when I went out to Wisconsin to pick up a camper and made a stop at Jiffy Lube upon my arrival. I realized today those SOB's never changed the oil. I drained out about 4 quarts and it was far dirtier than I have ever seen it.
    CroResident likes this.
  16. Apr 10, 2016 at 6:20 PM
    #36
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    OP.
    Did you have the dealer check trans level?
  17. Apr 10, 2016 at 6:27 PM
    #37
    hotrod53
    Lynd
    Pittsburgh, PA
    Mad Man, I took a picture of the level on the dipstick, then I measured each quart as I removed it. I called his direct line on Friday night and left him a message and asked him to call me.
    Calico, paint the bottom of your dipstick and your world will be a better place. I used a white TexPen marker on mine and you can read it easy now. The problem is that the oil can't cling to the smooth stainless stick. Once it's painted the texture of the paint keeps the oil where it belongs and easy to read.
  18. Apr 10, 2016 at 6:31 PM
    #38
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Yup.
    Exactly, tranny holds a lot of fluid, too o_O
  19. Apr 10, 2016 at 7:26 PM
    #39
    TOY4JMEBOOZE
    TOY4JMEBOOZE Well-Known Member
    Winchester, CA
    2018 Chevy Tahoe
    If you had more oil than what it is suppose to have, get underneath your truck and check gaskets. From experience, I've seen a similar situation and suddenly had a leak from a gasket behind the motor.
  20. Apr 10, 2016 at 7:38 PM
    #40
    gearcruncher
    I know guys are complaining they cant read the level indicator for the motor oil . It was always far worse trying to read level indicators ( dipstick ) on the transmissions . Put a small bend on the dipstick and always check both sides as you are filling to the full line .
    The small bend works as a drip line . You are essentially changing the angle where the fluid comes into contact with the dipstick .
    It works good or at least has always worked for me
