I got the shakes...bad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redfisher, Dec 18, 2009.
  1. Dec 18, 2009 at 8:19 PM
    Redfisher
    Redfisher [OP] Member
    Tampa Florida
    05 4 banger
    My '05 4cyl Tacoma ( 103,000 miles) has never been glass smooth but a week ago it developed a terrible vibration. It happens under acceleration at pretty much all speeds. At 70-75 mph it does smooth out a little. I had it looked at at the dealer when I had a service done. I was told it was the transmission mount. I order and installed the mount myself. The vibration is still there and seems to be getting worse. Is there another mount that could be the problem? it does seem to vibrate some when sitting while in gear but really shakes while accelerating. In park or neutral it is smooth running.
    Please help.:)
  2. Dec 18, 2009 at 8:22 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    u-joints??
  3. Dec 18, 2009 at 8:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Maybe the carrier bearing?
  4. Dec 18, 2009 at 8:29 PM
    SwampThing07
    SwampThing07 Well-Known Member
    Orlando, Fl
    07 prerunner/ Toytec lift/ 285 nittos/ MM 951
    885/ w 5100's, Grillcraft, HIDs, 285 nittos, MM 951B, Flowmaster duals, blackout tailights, tint, Sirius.
    I'm going through the same. I also had the mounts replaced. My vibes mostly went away but every now and then I still have them. Toyota still doesn't know what it is so they are opening a case on toyota service bulliten.
  5. Dec 18, 2009 at 8:30 PM
    Redfisher
    Tampa Florida
    05 4 banger
    Cool forum!! You guys are quick!
    I didn't take the time to check those when I changed the trans mount. I should have I know. I will give them a shake on Sunday.
  6. Dec 18, 2009 at 8:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Keep us posted on what you find.
  7. Dec 18, 2009 at 8:32 PM
    Redfisher
    Tampa Florida
    05 4 banger
    will do!
  8. Dec 19, 2009 at 5:17 PM
    Redfisher
    Tampa Florida
    05 4 banger
    I THINK it's safe to say that it is the U-joint??? Right???
    I strapped one of my cameras down there to have a look.
  9. Dec 19, 2009 at 5:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Looks like alot of vibration in the tranny tailshaft...
  10. Dec 19, 2009 at 6:43 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    X2.
  11. Dec 19, 2009 at 6:45 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    x3
    I think I heard some metal banging too..
  12. Dec 19, 2009 at 8:06 PM
    hwork50
    hwork50 Well-Known Member
    San Clemente
    06 PreRunner SR5 AC
    DTRL, Skid Plate, Bed Extender, ipod hook up in glove bo, bed mat, rubber mats, Garmin GPS, 2.5"Toyotec lift with 5100 shocks and Eibach springs.
    Just tracking the thread as I have a 4 cylinder as well.
  13. Dec 19, 2009 at 8:17 PM
    Justin723
    Justin723 Dont judge me
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- 7 inch lift, ARB compressor, high pinion 4.88 with ARB locker, 4.88 open diff in the rear, PIAA 520 series lights up front, and 36 inch fire stick. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, Cobra LTD CB, and Weather Tech floor mats.
    Wow your truck is very clean.
  14. Dec 19, 2009 at 8:23 PM
    hwork50
    San Clemente
    06 PreRunner SR5 AC
    Not sure if you were talking to me, but thanks. I just posted some pics.
  15. Dec 20, 2009 at 10:03 AM
    Redfisher
    Tampa Florida
    05 4 banger
    So you guys think it is a trans problem? :(
    It looks to me like the U-joint is jacked up since it seems to be wobbling down stream of the trans U-joint.
    U-joint= $12 + time changing
    Trans= Lots of money I don't have = :(:(:(
    I have been procrastinating this morning. :rolleyes:
  16. Dec 20, 2009 at 11:16 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I am seeing a lot of trans tailshaft movement as well.
    I would change out the U-Joint first since you did the trans mount already.
    The shaft does seem to be moving in an out of round orbit at slow speeds.
    Great video by the way.
  17. Dec 20, 2009 at 11:27 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    I would do one of two things. Go ahead and replace the u-joint with a quality joint. This shouldn't cost much and will narrow down your list, or better yet, solve the problem. You can also check the u-joint by grabbing the drive shaft while the truck is in gear with the engine off and the parking brake on, and trying to rotate it. if you feel excessive play in the joint, it is most likely bad.
    If this doesn't solve your problem, disconnect the drive shaft where it meets the tail shaft of the trans, and check the run-out of your tail shaft. You could possibly have a bad bearing in the trans that it causing excessive run-out and leading to vibrations. There is also the possibility that you have a bent drive shaft, although it doesn't appear to be bent in your video.
  18. Dec 20, 2009 at 11:35 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Front u-joint is shot. Check it at 4:00 - 4:05. It shouldn't move like that.
  19. Dec 20, 2009 at 12:46 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Front u-joint looks bad, just changed mine a couple weeks ago.
  20. Dec 20, 2009 at 12:50 PM
    Redfisher
    Tampa Florida
    05 4 banger
    Thanks guys! I'll get back to you after the fix.
