I GREASED MY U JOINTS. Vibrations on take off gone
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 11Bravo4x4, Jan 26, 2019.
  1. Jan 27, 2019 at 2:58 PM
    #61
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    I don’t know about the whole driveshaft but I bet there’s somebody making greasable replacement joints . If not I’m sure they will be soon , I’d wait till your warranty expires before putting them in though , just in case .
  2. Jan 27, 2019 at 3:07 PM
    #62
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    You swap the U-Joint, but yes.
    bax[QUOTED] likes this.
  3. Jan 27, 2019 at 3:14 PM
    #63
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    turbosnail[QUOTED] likes this.
  4. Jan 27, 2019 at 3:18 PM
    #64
    turbosnail
    Pa
  5. Jan 27, 2019 at 3:23 PM
    #65
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    No it does not just the axles don't believe me slide under it in 2wd and see if you can turn the front drive shaft. Toyota most likely does not use rear drive shaft fittings any more because people didn't grease them. When they wear out (100K or so) just replace them with greasable joints if you still own the truck.
  6. Jan 27, 2019 at 3:42 PM
    #66
    splitbolt
    NW Arkansas
    WAT?
    turbosnail and bax like this.
  7. Jan 27, 2019 at 3:45 PM
    #67
    turbosnail
    Pa
    Let it go ... the world is obviously flat . Lol
    pinochle, bax and splitbolt[QUOTED] like this.
  8. Jan 27, 2019 at 3:52 PM
    #68
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
  9. Jan 27, 2019 at 3:54 PM
    #69
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I bought a pistol grip grease gun and use the flex hose. I had the lever style but that takes three hands to use sometimes. One to hold the barrel, one to hold the hose on the fitting and one to pump the lever. The pistol grip is a two handed affair... hold hose on fitting , squeeze grip with the other, done. I'm not a fan of the rigid nozzle. I try to grease every oil change.
    bax likes this.
  10. Jan 27, 2019 at 4:07 PM
    #70
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I replaced my non-greaseable rear ujoints with Neapco 2-0052 ujoints with zerks on the cap. The Spicer version if you prefer is 5-1350-1X. This is for the manual trans on a 2018. I assume the same for 2019s. The ujoints on the manual are slightly larger than the auto. It's not too difficult if you take your time, or contact a driveshaft repair shop.
    The version for the auto is discussed here: https://www.tacomaworld.com/threads/greaseable-ujoints-for-late-2016-and-2017-tacomas.521461/
    11Bravo4x4[QUOTED][OP] and bax like this.
  11. Jan 27, 2019 at 4:49 PM
    #71
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    If they did then they would still be there what is the sense of having them if they don't get serviced. I do mine and you probably do yours, more often they are never serviced The drive shaft for the front diff does not turn in 2 wheel drive the ring and pinion do not turn in 2 wheel drive the disconnect is via the spider gears.
  12. Jan 27, 2019 at 5:06 PM
    #72
    splitbolt
    NW Arkansas
    Maybe... Toyota goes back and forth between greasable and non-greasable; it happened with 2nd gens.
    But, it begs the question; why leave them on the front driveshaft then?
    I posted a video of it turning in 2wd.
    shakerhood, bax and turbosnail like this.
  13. Jan 27, 2019 at 5:33 PM
    #73
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Are you lifted much? If so, did you drop the diff any? Wondering what type of angle they had in the first place.
  14. Jan 27, 2019 at 5:41 PM
    #74
    TRDandGlocks
    TRDandGlocks Well-Known Member
    Angel
    2021 TRD Off Road DCSB 4x4 Manual
    Can I use the same grease I use to to grease my SPC UCA?
  15. Jan 27, 2019 at 5:49 PM
    #75
    splitbolt
    NW Arkansas
    What grease? If it's a PTFE base grease, no.
    Toyota specs; Lithium base chassis grease, NLGI No.2
    A calcium sulfonate base grease is also acceptable; Redline, Spicer, etc.
  16. Jan 27, 2019 at 5:57 PM
    #76
    TRDandGlocks
    Angel
    JoeCOVA likes this.
  17. Jan 27, 2019 at 6:01 PM
    #77
    splitbolt
    NW Arkansas
  18. Jan 27, 2019 at 6:05 PM
    #78
    TRDandGlocks
    Angel
    Thanks I appreciate it
  19. Jan 28, 2019 at 5:29 AM
    #79
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    It is sort of dumb to leave grease fittings on something that is used part time while a two piece drive shaft has none. The front drive is something Toyota picked up from GM it is designed for lazy people or those that are unable to figure out how a locking hub works. If you believe the shaft turns I going to guess you have never broken an axle in an open diff vehicle if you have then you will quickly notice your not going anywhere. If you have locking hubs you had better lock both or you will have no front drive. The drive shaft will turn the guts inside but the spider gears will just turn around and around and not drive the axle. Now I suppose it is possible with zero load for the viscosity of the gear grease to turn the drive shaft but I guarantee you can lay under the truck with the wheels on the ground and you can freely turn the front drive shaft.
  20. Jan 28, 2019 at 7:40 AM
    #80
    Troyken
    NY
    Probably so about the grease turning the unloaded shaft. I believe a lot of these front drive shaft U-joint bind ups are from lack of 4 wheel drive use and/ or immersion in water. Occasional use of four wheel drive will spin the driveshaft and get the grease moving. Regular greasing is always a good idea in any case. I would always want a greaseable replacement part if it was to be had.
