i guess this would be considered a "noob" question
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, Jun 22, 2010.
  1. Jun 22, 2010 at 10:56 AM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    on my 4wd shifter what does the neutral do?
  2. Jun 22, 2010 at 10:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Puts the front and rear in neutral. Separate from the tranny.
  3. Jun 22, 2010 at 11:15 AM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    in what situation would i use this? ive always just skipped neutral when going from 4 hi to 4 lo
  4. Jun 22, 2010 at 12:12 PM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    Possibly when being towed out of the mud.
  5. Jun 22, 2010 at 12:17 PM
    AlexanderD
    AlexanderD Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    i would think there isn't really any use for it unless your trans locks up somehow the transfer-case neutral would allow you to tow it. otherwise i think its just necessary in term of the internal workings of the T/C as i believe you have to have some break in power transmission to change your drive ratios when there is no clutch involved.
  6. Jun 22, 2010 at 12:58 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I dont know how true it is, but I always thought of the 4x4 neutral this same way. Kinda along the same lines as a manual transmission. There just needs to be a neutral spot in order to disengage one gear and engage the other.
  7. Jun 22, 2010 at 1:23 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    oh ok i just figured i was missing a secret technique for this or something, but this helps a basically can continue what i was doing before and simply ignore the neutral :)
  8. Jun 22, 2010 at 1:27 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    If you ever tow your truck (like behind a motor home) you can put the T-case in neutral and release the parking brake and you're good to go.
