I hate auto AC on when selecting cool air
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Flyfisher22, Dec 8, 2011.
  1. Dec 8, 2011 at 2:01 PM
    Flyfisher22
    Flyfisher22 [OP] Well-Known Member
    Cameron
    Indian Trail, NC
    2011 Off Road Package DC
    None
    As the title states, I hate that when turning to the coolest air setting my AC comes on. I searched but did not find a fix. If I over looked it I apologize. So has anyone found a way to disable that feature? I would like to be able to get the coolest air possible without AC by just turning it. Not turning it, then trying to nudge it back a little bit to check the buttons to see if it is far enough. Thanks for the help guys!
    Cam
  2. Dec 8, 2011 at 2:03 PM
    Aw9d
    Aw9d That one guy
    I'm with you, I hate this feature.
  3. Dec 8, 2011 at 2:04 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    It kind of makes sense that the coolest air would require AC....just don't turn it all the way...:notsure:
  4. Dec 8, 2011 at 2:08 PM
    Flyfisher22
    Cameron
    Indian Trail, NC
    None
    Why didn't I think of that.................. Thanks so much for your help
  5. Dec 8, 2011 at 2:16 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    i sence some sarcasm here.
  6. Dec 8, 2011 at 2:18 PM
    TeamSarcasm
    The better coast
    This might help...
  7. Dec 8, 2011 at 2:20 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    I just turn mine to the second last notch. It's pretty obvious where it is, you can feel the knob clicking past each notch.
  8. Dec 8, 2011 at 3:09 PM
    harleyg
    harleyg Landscape Photographer
    Harley
    2011 PreRunner AC 2.7 Leer 180
    I am with you on this. I hate that too. Far too easy to turn it all the way, then have to turn off the air. I find it to be an idiotic design.
  9. Dec 8, 2011 at 3:15 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Truely is an idiotic design but easily dealt with-just get used to not turning it to max cool
  10. Dec 8, 2011 at 3:18 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    is there a mod that i can do so when i set my wipers to high they don't come on?:rolleyes:
  11. Dec 8, 2011 at 3:20 PM
    TacoDawgs
    TacoDawgs Well-Known Member
    2008 Radiant Red DCSB TRD OR 4x4
    Front 5100s at 1.75. Rear TSB. LoRider tonneau cover. OEM bed mat. OEM bug deflector. Illuminated 4x4 switch. In cab AC outlets. 400W anytime. EGR in channel window visors. Black badges. Rear weathertech liners.
    I hate it too. I also hate when I turn my headlight switch, my headlights come on. And when I turn my 4x4 dial to 4H, IT GOES INTO MOTHERFUCKING 4H. Why Toyota....why?
  12. Dec 8, 2011 at 3:20 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
  13. Dec 8, 2011 at 3:22 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Has the A/C lay out changed? Mine has a button for A/C, another for recirculate/max. I'm I missing something?
  14. Dec 8, 2011 at 3:28 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    Turn the selector dial to the dash vents only, then turn your temp dial all the way to cool. your A/C will turn on automatically.
    That said, I believe if you have the fan selector on the windshield only, turning the temp to max cool won't turn on the A/C.
    Another possible remedy?
  15. Dec 8, 2011 at 3:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think they changed it in 2010....I agree it would be a silly thing to have though. I like being able to manually select "Fresh air" or "Recirc" with a seperate button, rather than how far I turn a knob.
  16. Dec 8, 2011 at 3:32 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    I think we all know this is totally different. The difference between the last and second-last notches could be huge depending on OAT. That's not particularly intuitive.
    If I want A/C, I'll ask for A/C.
  17. Dec 8, 2011 at 3:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah....a redundant feature....fabulous.
  18. Dec 8, 2011 at 3:36 PM
    t4daddy
    North Alabama
    Mine don't, and it's not marked, just went outside to check cause I was thinking I was loosing my mind. Only when you press the "AC" button does the unit come on, nothing on the thermostat dial will light up that (AC) button.
  19. Dec 8, 2011 at 3:38 PM
    t4daddy
    North Alabama
    The word MAX is nowhere on my control panel.
  20. Dec 8, 2011 at 3:55 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    look at post 19
