I hate Drum Brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tikibutt, May 11, 2023.
  1. May 14, 2023 at 7:15 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    [QUOTE="RustyGreen, post: 28723506, member: 337468]
    [/QUOTE]
    HOLY CRAP that is a mess!
    RustyGreen likes this.
  2. May 14, 2023 at 8:10 AM
    Tikibutt
    Tikibutt [OP] Well-Known Member
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    JBA UCAs, Radflo Coilovers, Lockrite mechanical Locker, All-Pro Offroad Skid Plates, 4x Innovations Sliders, Dakar Rear Springs, 37x13.50r17 Cooper SST Pro on Beadlocks
    To clarify, this was in reference to the lever under the driver's seat on the underside of the truck. The primary cable runs from the handle across a pulley, and out the bottom of the cab. It them connects to the end of a lever to multiply the force applied to the brakes. A secondary cable runs from this lever back to the brakes. It was this lever I was referring to hitting with a hammer, thus pulling the primary cable. The primary cable seems to be getting bound up, and not retracting the handle fully.
  3. May 14, 2023 at 8:11 AM
    Tikibutt
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    I pulled the adjusters apart, cleaned them, and sprayed a little lithium grease inside to allow ease of movement once reinstalled.
  4. May 14, 2023 at 9:42 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The whole handbrake system relies on fairly small springs to fully return to the release position, any drag or bind will cause it to hang up.
    Clean & re-lube everything and your problems will probably be resolved.
    I live in snow & salt country, handbrakes and I have a long history filled with colorful words... :rant:-- :frusty:
    Bivouac and Superdave1.0 like this.
  5. May 14, 2023 at 12:57 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Another place to check for the cable is free to move.
    Is where the rear cable splits that the nylon bushings are free to move.
    I have come across them removed and replaced with a bolt and nut cranked down unable to move.
    Living slightly south of Mr Green once I rebuild the parking brake I seldom have issues unless the vehicles sit outside for months.
    Never Seize works wonders .
