I Hate My Alcans!!!!!
Discussion in 'Suspension' started by ckblum, Sep 26, 2012.
  1. Sep 26, 2012 at 9:41 PM
    ckblum
    ckblum [OP] Well-Known Member
    Cam
    Chilliwack, BC
    Tacoma
    Bilsteins, Light Racing UCA's, Alcan's, Kragen HID's
    They are so flipping stiff and high!!! I bought them used from a guy who got them from Wheelers Offroad. Supposed to be a 3" lift but it looks like 5-6", rides like it's solid mounted frame to axle. I figured they'd be broken in already but he only used them for 2 months before selling his truck.
    Are these just made for a canopy and a bunch of weight? Or will they actually settle? As it stands I'm gonna be pulling a leaf or two out of the pack this weekend. Anyone have a similar situation and what leaf(s) did you pull to soften/lower it?
    Truck is a 2001 TRD 4x4 ex cab, Bilstien 5100's, stock front coils set to max setting. I also have an aluminum toolbox and about 120lb of tools, mounted in the front of the box.
  2. Sep 27, 2012 at 5:31 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Post a pic of them so we can see which ones you bought.
  3. Sep 27, 2012 at 6:42 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I'd think you could just pull the bottom ones above the overload or maybe pull the overload too if it's that stiff. Get a few sand bags from home depot and flex the springs as much as you can.
  4. Sep 27, 2012 at 6:47 AM
    Brrap634
    Brrap634 Well-Known Member
    Terry
    Englewood CO
    Some shit...
    I have some alcan leafs and I love them. I only have the 3'' lift so they are not as high as yours but my perform great and ride good as well...
  5. Sep 27, 2012 at 6:50 AM
    ruggedT
    ruggedT The Sticker Guy Vendor
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Do they have poly bushings? Did you tighten the shit out of the mounts?
  6. Sep 27, 2012 at 6:58 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    This too!
  7. Sep 28, 2012 at 9:19 AM
    ckblum
    Cam
    Chilliwack, BC
    Tacoma
    Yes poly bushings. At first I thought that, loosened them up but they still look kinda squished, but the nuts are almost loose on the lock washers.
    They are supposed to be only a 3" lift. My old springs were very saggy so I meant its about 5-6" over that height. I'd say it's about 4" over stock though. I'm going dirt biking this weekend so I'll grab some sandbags and load them up when I'm at the river. How much weight would you guys say to help break these in?
  8. Sep 28, 2012 at 9:21 AM
    MYT4CO
    MYT4CO Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    mine ride like butter, they have the red poly bushings. how tight are you supposed to tighten them? i cranked em pretty good
  9. Sep 28, 2012 at 9:22 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    I wonder if wheelers sent you the correct leaf pack
  10. Sep 28, 2012 at 9:22 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    1) you need to post center of hub to fender measurements
    2) any "breaking in" time is significantly decreased if you do it offroad. 500 miles on road = about 100 off road.
  11. Sep 28, 2012 at 9:25 AM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    Bought them used
  12. Sep 28, 2012 at 9:27 AM
    ruggedT
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    You replace the nuts with some nylock ones. Just snug... they're supposed to rotate unlike the rubber bushing. I replaced all my hardware with some grade 8 stuff.
  13. Sep 28, 2012 at 9:28 AM
    MYT4CO
    mark
    TX
    oh k thanx for that info, didnt know that. i need to go replace my nuts and loosen them:eek:
  14. Sep 28, 2012 at 9:33 AM
    Round II
    Round II Member #12005
    :confused:
  15. Sep 28, 2012 at 9:40 AM
    XXXX
    sKiP
    05 Prius
    meant "off"
    fixed
    :eek:
    :p
    :D
    what beer do you want? I'm not taking no for an answer either MR!
  16. Sep 28, 2012 at 9:46 AM
    Round II
    Oh there is an awesome beer store right next to the beach house so just get when we all get there.
  17. Sep 28, 2012 at 9:47 AM
    XXXX
    sKiP
    05 Prius
    Done.
  18. Sep 28, 2012 at 10:34 AM
    ckblum
    Cam
    Chilliwack, BC
    Tacoma
    Also I found some TRD springs from a 2nd Gen in CL used, about 20-30 000km on them. Does anyone know if the 2nd Gen springs are taller/stiffer and will give me lift? Cause the Toytec Eibachs only lift 2nd Gens 1.5" but lift a 1st Gen 3"???
    They are real cheap and so am I right now. Putting money towards shinier, expensive, more important things for now.
  19. Sep 28, 2012 at 10:50 AM
    XXXX
    sKiP
    05 Prius
    Like I said at this point you never even measured so please provide us with accurate numbers if you want accurate answers.
    Every post in here is pure speculation.
    You need to provide data to get data
  20. Oct 2, 2012 at 7:12 AM
    ckblum
    Cam
    Chilliwack, BC
    Tacoma
    Alright here's some measurements, I'm thinking of going with Eibach coils up front so maybe someone could give me that measurement as well as th measurement of their Alcans?
    Front centre of hub to fender is 23", stock TRD coils with 5100 on max
    Rear centre of hub to fender is 26.5", Alcans 3" (?) springs
    Post up your measurements, maybe my fronts are just super saggy,
