i hate our Tacoma wheel lugnuts!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aficianado, Sep 3, 2012.
  1. Sep 3, 2012 at 5:27 PM
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    why would they clad them with a decorative chrome layer? all my 21mm lugs are more like 21.5mm. i hate it. looks like my truck has one tire with a separating sidewall belt, and will need to be changed. and you know what? those guys at Costco will strip the 6 offending lug nuts sure as day..no way they take the time to tap on a 21mm..
    the offroad shorty lugs have to be worst than the longer sport lugs..no?
    i have to work tomorrow, so my wife is taking my truck in. this is so annoying..i would rather have 24 zinc plated, ugly lug nuts that are durable.
    i am gonna buy 24 new ones from wheelers..i am done with these junk lugs.
  2. Sep 3, 2012 at 5:30 PM
    aficianado
    back to bone stock.
    here is the suspect tire. i roadtrip with some off roading..on thursday. love to get this tire off and replaced. plus i will be towing a small trailer.
  3. Sep 3, 2012 at 5:36 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Should't be an issue. When I ran the stock wheels, the stock lugnuts fitted well inside a 22 mm socket, which is a fairly standard size.
    Haven't seen a 21 mm in most socket sets. Usually it's either 13/16" (20.6 mm) or 22 mm.
  4. Sep 3, 2012 at 5:38 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    I think i have 19mm nuts and never had any problem with them, but of course they are covered by my rims.
  5. Sep 3, 2012 at 6:04 PM
    Larry
    Larry CARL
    CARL
    I'd be more concerned with the alloy wheels getting torn up than the lugs.
  6. Sep 3, 2012 at 6:09 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Most lugnuts are 19mm or 21. I have only seen chryslers that have the lugnuts that have the caps seperate. Are you sure you are using the correct size socket OP? If they are a bit swelled, you can tap a 21 on, or use a 13/16, which is a tad bit bigger. Should cure your problems.
  7. Sep 3, 2012 at 6:42 PM
    aficianado
    back to bone stock.
    Yea I got three brand new 21mm from Toyota last time. They are perfect. The cladding on the old ones swelled. annoying. Thanks for the 13/16th suggestion.
