I hate Push Start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ktb556, Jan 14, 2022.
  1. Jan 14, 2022 at 6:02 AM
    BobbyTacoTRD
    BobbyTacoTRD Skewps Ahoy!
    2021 TRD Off Road
    I don't bother with a fob condom while I'm out and about, but I have a small RFID blocking box that I drop my keys, knife and wallet in at home. I've always used a box for this purpose to avoid clutter but once I heard about rare instances of thieves picking up fob signals I figured an RFID blocking box would be multipurpose.
    MentalBill likes this.
  2. Jan 14, 2022 at 6:15 AM
    vnix
    vnix Well-Known Member
    2021 white Tacoma DCSB XP Predator
    blind spot mirrors, center tray, bedrug, more to come
    Most things are possible and this one is likely possible. But, how much are you willing to pay/go through to delete this feature? I don't know what's involved nor do I care to know, but I imagine that it won't be easy or cheap. You're talking about replacing a key component. This isn't like replacing the radio in a truck 30 years ago.
    Just an FYI I think some of you might raise an eyebrow too. I used to drive a 2018 F150. It used a key but behaved more like a push button. What do I mean by that? I could turn the key to start and immediately release it back to run. Starter would continue to try to start the truck even with the key in the run position. I got used to doing that and had to relearn on my SR5 to hold the key in the start position until the engine catches.
    So, your next truck just might use a key but still be push button under the covers. That's a lovely thought isn't it.
  3. Jan 14, 2022 at 6:16 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Same here. I only use mine when the truck is parked at home.
    BobbyTacoTRD[QUOTED] likes this.
  4. Jan 14, 2022 at 6:20 AM
    manwithtools
    manwithtools Well-Known Member
    Dan
    So Cal - San Diego
    2021 Cement Gray Off Road
    Fox 2.5's Deaver Stage 2. 5.29's, 285/70/R17 Front E-Locker
    It is Friday...
    awesomeandy013 and Chew like this.
  5. Jan 14, 2022 at 6:23 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The Tacoma has had a push start for nearly 6 years now. At some point you stick in the mud luddites are going to have to get on board with it.
  6. Jan 14, 2022 at 6:25 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Do people actually give a fuck about things like this. Evolutionary thought is healthy.
  7. Jan 14, 2022 at 6:29 AM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    You don't need the faraday cage.
    Hold down the lock button. Press the unlock button twice. The red light on your fob will make two short blinks, pause, then make two more short blinks. You've effectively "turned off" the fob until you press a button on the fob. This is documented in the user's manual.
  8. Jan 14, 2022 at 6:29 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    LOL...
    Gotta admit, seeing the title and then the first post my mental image was completely different from what the thread was about. Seeing the level of ignorance I've seen here I immediately went to someone pushing their truck to start it.
    I'll never be buying a new vehicle. I'm not that OCD.
    sark likes this.
  9. Jan 14, 2022 at 6:33 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    You are incorrect. They PTS DOES have an column lock, which I think you are referring to as an ignition lock.
    eurowner likes this.
  10. Jan 14, 2022 at 6:33 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I never gave this much thought until you brought it up. My wife’s Grand Cherokee is keyless and my Tacoma is keyed. I’ve replaced batteries in her fob a bunch of times and never in mine. You’re not wrong about the amount of batteries you’ll use.
    To the back and forth, I don’t give it a ton of thought. I wouldn’t buy or not buy depending on the keyless feature. I’m much grumpier about the Jeep’s invasive stop/start programming than anything. That’s a feature I cannot stand and disable each time I drive, but the Tacoma doesn’t have it (and Toyota’s programming on the Highlander rental I had was significantly better) so it’s moot here.
  11. Jan 14, 2022 at 6:34 AM
    ktb556
    ktb556 [OP] Member
    That I have to get into my truck to start it. I used to just reach across from the passenger side and turn the key. It’s the foot on brake requirement that kills me. What makes it impossible to change? You should just need a switch for the starter motor no?
  12. Jan 14, 2022 at 6:39 AM
    ktb556
    ktb556 [OP] Member
    It’s obviously not enough to stop me from buying the truck. I love so much about it but it doesn’t make the push start any less annoying. Thanks for the help though
    six5crèéd[QUOTED] likes this.
  13. Jan 14, 2022 at 6:42 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Hah, too bulky to keep in your pocket. That's a good one! Well stop wearing skinny jeans...
    AZBMXDAD, blu92in99 and six5crèéd like this.
  14. Jan 14, 2022 at 6:46 AM
    salamihater
    salamihater Well-Known Member
    MA
    What's the range of the fob? My driveway is directly adjacent to my house and the spot by the back door where I typically toss my keys isn't really all that far from where the truck would be parked. (I have a keyed vehicle now but I'm curious about the fobs) Im wondering if the fob could be sitting in my kitchen and allow someone to walk up the driveway and open the door.
  15. Jan 14, 2022 at 6:50 AM
    #35
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I haven't tried this personally but in the tips and tricks thread it says you can do this to override the brake requirment.
    63. To start the truck without having your foot on the brake (useful for when a rider goes to the truck before you do and is sitting in the passenger seat) push the PTS button once and release, then push the PTS button and hold it till the truck starts (Approximately 10-13 seconds). This process was tested on a 2017 & 2016 Tacoma TRD Off Road with an Automatic Transmission and still requires the smart key to be in the vehicle in order to start.
    TRD75, awesomeandy013, 604 and 2 others like this.
  16. Jan 14, 2022 at 6:51 AM
    #36
    RX1cobra
    19 OR
    No the range is really close to the truck. Sometimes when I have fob in my gym bag (thats in my right hand) it won't read and I need to move the bag closer to open the door.
    604 and salamihater[QUOTED] like this.
  17. Jan 14, 2022 at 6:52 AM
    #37
    ULURU
    If you turn off the fob, you'll save battery life. I keep spare button batteries in the truck, just in case.
    In way of the the start/stop programming... Some time ago, I was on business travel. It was August. The rental car was a Chevy. The engine would shut down when I was stopped at a traffic light. And with the engine stopping, the air conditioning stopped. I would keep the car in neutral or race the engine at a light to prevent this, and to stay cool... Sometimes enough is enough.
  18. Jan 14, 2022 at 6:52 AM
    #38
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    that’s probably the most legitimate reason I’ve heard for not wanting it. I assume you mean to warm it up in the morning.
    And I’ll be honest, I have no idea what’s actually involved with switching to a key start but a push to start is so heavily incorporated into the trucks systems that it would be quite a feat to make it happen.
  19. Jan 14, 2022 at 6:53 AM
    #39
    ULURU
    Manual reads that the fob needs to be within 3 ft of the door handle to open the doors. The key can be anywhere inside the vehicle to start the engine.
    Shocked likes this.
  20. Jan 14, 2022 at 6:58 AM
    #40
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’ll be damned, this worked. I just tried it in my 2020 tundra. Had to hold it for about 16 seconds
    604 and RX1cobra[QUOTED] like this.
