I have 2 bilstein 5100 2.5 lift shocks and am about to have them set on 2.5" on stock coil springs.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06_tacoma, May 18, 2016.
  1. May 18, 2016 at 11:39 AM
    06_tacoma
    06_tacoma [OP] Member
    I have 2 bilstein 5100 2.5 lift shocks for the front of my truck and am about to have them set on 2.5" on stock coil springs. Will this cause any problems? Will i be able to get the full 2.5 inches of lift out of the shocks?
  2. May 18, 2016 at 11:46 AM
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    It technically is ok.
    Probably won't give 2.5 unless your springs are brand new. Most importantly the alignment will be hard to get and your truck will end up riding like shit. I would not run on the highest setting if you aren't lifting the rear either.
  3. May 18, 2016 at 11:48 AM
    06_tacoma
    damn..not what I was wanting to hear. Should I run it on 1.75?
  4. May 18, 2016 at 11:52 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    If you have a 4 leaf pack on the rear and no lift, 1.75 is ok.
    If you have a 3 leaf pack on the rear and no lift, stick with .85 as a maximum.
    Both are about level with the rear setups I outlined.
    I had mine at .85 and 1.75, and wouldn't want to go at 2.5 myself.
  5. May 18, 2016 at 12:54 PM
    unlewser
    unlewser Well-Known Member
    Tempe, AZ
    im at 2.5. It is stiffer ride, but the load E tires contribute more to the stiffness. I also have 1.5 wheelers progressive add a leaves.
  6. May 19, 2016 at 10:26 AM
    06_tacoma
    do you have stock coil springs with the shocks maxed out or after market coils?
  7. May 19, 2016 at 7:13 PM
    g_f0nts
    g_f0nts Member
    Maui, Hawaii
    Mines is set at 2.5 and it rides perfectly fines, just the rear is a little stiff due to my rear blocks, recommend aal instead
  8. May 19, 2016 at 7:54 PM
    Pigpen
    Dan
    Northwest Montana
    Each truck is a little different in respect to how much lift you'll get. If you have a double cab V6 4x4, you'll get right about what they say. Prerunner might be a little more (@DCSBFTMFW ?). My access cab got nearly 2.5 with springs set at 1.75. 4 banger engine is lighter than V6, so more lift. Same with regular cab. It's kind of a crap shoot until you find someone with a nearly identical truck who has already done what you're thinking of doing.
    And the driver's interpretation of what's stiff, bouncy, smooth, plush, etc... is totally subjective.
  9. May 19, 2016 at 8:33 PM
    T4RFTMFW
    We talked in PMs already.
    Pigpen[QUOTED] likes this.
  10. May 19, 2016 at 8:45 PM
    T4RFTMFW
    Actually for information sake.
    I got 1.5" of lift at .85 setting with my configuration.
  11. May 19, 2016 at 8:59 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    i would not recommend the 2.5in setting on stock springs.... 1.75in max and plan for some UCA's
    I got exactly 1.75in but im a DCSB 4x4 v6 auto so i am stock the second heaviest config. next to the lb version of my truck.
