I have 99 Problems and a Clutch is one....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ThePanda, Jun 8, 2022.
  1. Jun 8, 2022 at 7:41 PM
    ThePanda
    ThePanda [OP] Well-Known Member
    Kaelan
    Colorado
    6-Speed Manual 2010 Magnetic Grey Tacoma SR5
    Procomp 6" Lift ARB Front Bumper Brute Force Fab's High Clearance Swing Arm Rear Bumper Relentless Fabs Bed Rack Gen 2.5 Face-Lifted Exterior and Interior (mostly) -Fleabay Headlights -Heritage Grille -Scooped Hood Alpha Rex 3rd Gen Pro-Series Taillights Joying 10.5" Android head unit URD Short Throw Shifter Advanced Fiberglass Front and 3rd Gen Rear Fenders 3rd Gen Tailgate RSG Metal-Works Sliders ARB Simpson III RTT Panels Lined w/ Closed Cell Foam (In Progess...) QTP Reverse Screamer muffler TRD CAI SPC UCAs S.S. Brake lines front and rear S.O.S. Performance rear Disk Brake conversion w/PowerStop performance calipers, rotors and pads KMC Tank 17" beadlocks wrapped in 35x12.5" KO2s Long Range Offroad Extended Range Fuel Tank ATO Dual Battery tray w/ 34D Optima Yellow tops and Blue Sea ML-ACR ClutchMasters Hydraulic Throwout Bearing
    Last week my clutch went out. I'm always trying to upgrade when things break... (I.E. S.O.S. disk brake conversion when the drums went out last year. BTW I would recommend just swapping in a FJ or 4Runner rear axle- less hassle...) Anyway, I had my eyes on a URD replacement clutch and a ClutchMasters Hydraulic Release Bearing, but they both seem to be out of stock from URD. Are there any other reputable brands and/or retailers for replacements? I'm currently running the stock engine, stock gearing and 35s. I am in the process of collecting parts for installing 4.88 gears and f/r lockers. I was interested in the URD torque-u 40.5 lb flywheel and the stage 2/2+ clutch. Do these sound appropriate for my setup? Also, does anyone have experience doing the install themselves (Non-professionals)? How long did it take you, and what speed bumps did you hit along the way?
  2. Jun 8, 2022 at 8:14 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I did both, took me about 2 days total taking my time. Well worth the upgrade.
  3. Jun 8, 2022 at 8:15 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    My dowel pins were seized in the transmission, so it was fun trying to separate the trans and engine.
