i have a 2000 tacoma 2.7L with no crank no start. i believe the 5volt reference is shorted.assist me
Discussion in '1st Gen. Tacomas (1995-2004)' started by intralockshort, Dec 18, 2023.
  1. Dec 18, 2023 at 5:05 PM
    intralockshort
    intralockshort [OP] New Member
    joshua
    toyota tacoma 2000
    alternator replacement.
    battery is good. alternator is good. starter is good. check engine light won’t illuminate as you engage the key to the on position.
  2. Dec 18, 2023 at 10:45 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Welcome to Tacoma World. Do any other lights come on? Have you checked fuses? When did it last run? Have you done any repairs to it for this problem?
    intralockshort[OP] likes this.
  3. Dec 18, 2023 at 10:58 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That would my questions too, What other lights, if any, come on when the key is 'on'? Headlights, turn signals, emergency flashers, etc? Any power to the OBDII port? The check engine light could be burned out.
  4. Dec 19, 2023 at 5:42 AM
    Rougarou680
    Rougarou680 Swamp Lurker
    Lousyana
    2006 Tacoma 4.0 Prerunner, 2013 & 2014 Tacoma 4WD 4.0L
    Leveling kit, hydro dipped rims & skid plate on 2013, 6” pro comp lift & color matched rims on 2006.
    I use to have a 2000 tacoma that did that. Ended up being a severed wire on one of the coil pack plugs. I'll add it took me 2 weeks to find it, after pulling bed and replacing fuel pump thinking that was the problem.
  5. Dec 19, 2023 at 6:07 AM
    intralockshort
    joshua
    toyota tacoma 2000
    fuses appear to be okay and relays. i’ll check all the lights that illuminate. the last time it ran was a week ago he pumped gas at a shell. it’s been having crank no start issues since. only the alternator was replaced and a new battery.
  6. Dec 30, 2023 at 5:41 PM
    papajo247
    papajo247 New Member
    Joseph
    2002tacoma
    None
    Clutch button may have ratteled loose. On my 02 I have two of them. Top and bottom
  7. Jan 1, 2024 at 7:42 AM
    Glamisman
    Glamisman Well-Known Member
    The powertrain control module (PCM) is grounded on the intake manifold. There is a group of brown wires with a ring terminal, 6 wires IIRC. I would check those first. The CEL HAS to illuminate during the bulb check routine of the key on position.
