I have a 2014 Tacoma the four-wheel-drive light started flashing red
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dearymike, Aug 1, 2017.
  1. Aug 1, 2017 at 3:36 PM
    Dearymike
    Dearymike [OP] Member
    2014 tacoma extra cab
    I have a 2014 Tacoma four-wheel-drive light flashes red I put it in a long high worked fine for low worked fine took it out it all seems to work fine but the light is flashing red
  2. Aug 1, 2017 at 3:39 PM
    thekidcatcher
    thekidcatcher Well-Known Member
    Corpus Christi, TX
    05 TRD offroad SR5
    Legs- --Helo rims --KM3 285/75/R16 --Bilstein 5100 in front with OME 886 --Dakar with extra leaf --Total Chaos UCA's --5165's Bilstein in the rear Electronics- --Warn M8000 w/ Warn wirless remote --Cobra 29LTD CB, --12in sub with alpine amp , --Dual Battery, --Warn Air compressor --URD MAF sensor, --touchscreen cd player hooked up to front and rear cameras Armor- --All-Pro offroad front/rear/rocksliders --AP skid plate, diff armor Cajones- --JBA headers, midpipe, exhaust --Safari Snorkel --4.56s ECGS Misc- highlift jack --UWS toolbox --u bolt flip kit --Tepui Kukenam Custom- --in dash inverter --on-board shower system --dvd anytime mod --custom bed rack and tiregate.
    Is there an x over the rear axle on the light?
  3. Aug 2, 2017 at 1:34 PM
    Dearymike
    Yes it's below the green one that comes on when in 4x4
  4. Aug 2, 2017 at 1:41 PM
    eon_blue
    Azusa, CA
    I don't have a 2nd gen but doesn't that indicate that the Rear Diff lock is trying to engage? I didn't think that the 4x4 indicator light flashed red, just the RR Diff lock light...?
  5. Aug 2, 2017 at 1:42 PM
    eon_blue
    Azusa, CA
    If you have a TRD OR model, make sure the diff lock button to the left of the steering wheel isn't pushed in (unless you want it to be).
  6. Aug 2, 2017 at 1:45 PM
    thekidcatcher
    Corpus Christi, TX
    05 TRD offroad SR5
    Yeah, its the diff lock light. If you are in 2x4 just hit the locker button. Light should go away
  7. Aug 2, 2017 at 4:53 PM
    Dearymike
    That's not it I locked and unlocked the differential, different lights come on for that. And yes it is a TRD off-road. No modifications
  8. Aug 2, 2017 at 4:55 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Post a pic of it
  9. Aug 2, 2017 at 5:06 PM
    Dearymike
  10. Aug 2, 2017 at 5:07 PM
    Dearymike
    The green light is because I put it in four-wheel-drive that works fine the red light blinks all the time
  11. Aug 2, 2017 at 5:08 PM
    URBIKESUCKS
    URBIKESUCKS Well-Known Member
    Ron
    Prescott AZ
    2014 DCSB TRD OR
    chem light battery is low
    hoverlover likes this.
  12. Aug 2, 2017 at 5:22 PM
    Dearymike
    ? Chen light. ??
  13. Aug 2, 2017 at 5:24 PM
    URBIKESUCKS
    Ron
    Prescott AZ
    2014 DCSB TRD OR
    sorry im retired and a day drinker, goodnight
  14. Aug 2, 2017 at 5:29 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I believe thats the diff lock light. If you press diff lock what does it do? Have you tried putting it in neutral? Reverse and forward a bit to see if it engages/disengages successful?
  15. Aug 2, 2017 at 5:33 PM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    That's your diff locker light. Make sure the button is in the disengaged position and try driving for a bit. If it's blinking it's trying to engage/disengage the locker. With the button depressed it should stop blinking and go out after a short drive.
  16. Aug 2, 2017 at 5:34 PM
    hoverlover
    Mostly Zip-Ties
    You may have to drive for a bit and make some shallow turns to fully disengage the locker.
  17. Aug 2, 2017 at 5:45 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Why don't you take a second and look at your rear axle, and see if the wires are connected as they should. That's an easy place to start.
  18. Aug 2, 2017 at 5:57 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Read your year's vehicle manual, it should give you a clear explanation specifically about that indication.
    Norton likes this.
  19. Aug 2, 2017 at 7:17 PM
    URBIKESUCKS
    Ron
    Prescott AZ
    2014 DCSB TRD OR
    yeah it seems to happens after my mid day nap
  20. Aug 2, 2017 at 7:40 PM
    thekidcatcher
    Corpus Christi, TX
    05 TRD offroad SR5
    Are you responding to your own post? lol
    EatSleepTacos likes this.
