I have a 98 Tacoma and have rain leaking in and soaking the floor under the steering wheel
Discussion in '1st Gen. Tacomas (1995-2004)' started by TruckLove, Nov 5, 2020.
  1. Nov 5, 2020 at 3:18 PM
    TruckLove
    TruckLove [OP] Member
    1998 Toyota Tacoma TRD offroad
    JDM Hilux turbo diesel KZN conversion
    Has anyone else ever had this problem? I even had the windshield replaced, thinking it might be coming through an old gasket, but so far, I cannot figure out where it's coming in. I remove the floor mat and put a towel down with a brick on top to soak up the water, and then I let it dry with the floor mats removed. Thanks for any advice.
    Black DOG Lila likes this.
  2. Nov 5, 2020 at 3:20 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Does it happen only while driving or when sitting overnight in rain for example?
  3. Nov 5, 2020 at 3:22 PM
    2stroke-Taco
    2stroke-Taco Well-Known Member
    Nick
    ‘98 Tacoma SR5
    bad door seals near hood area?
  4. Nov 5, 2020 at 3:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    Dark night
    Two people, one outside, one inside
    Bright floodlight
    Where you see light, water can enter
    JudoJohn, Black DOG Lila and stevesnj like this.
  5. Nov 5, 2020 at 8:42 PM
    TruckLove
    It happens when it's parked. It may happen when driving, but I don't know. I'll check the door seals near the hood, and I'll do the flashlight routine. So, if it's around the doors, would I want to get new door gaskets?
  6. Nov 6, 2020 at 1:25 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Coming in through the wiper transmission tunnel because of rust or cracks.
    Poor job installing the windshield ?? Try the garden hose with a friend watching for incoming water .
    Is the water closer to the door or more up under the dash most times water will leave a trail as it runs to the floor.
    Is it leaking in Hurricane type rain with lots of wind or any type of rain even a mild soft rain like a 1/4" in 8 hours ??
  7. Nov 6, 2020 at 2:39 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    There are a couple of seams under the black plastic piece under the wipers that the sealer may have failed. I hit this area hard with silicone caulk.
  8. Nov 6, 2020 at 5:48 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Check the black rubber grommets on the fire
  9. Nov 6, 2020 at 5:50 AM
    ataco4x4
    ataco4x4 Well-Known Member
    Raleigh NC
    2019 Tacoma XP Super White
    tonneau cover upgraded dome lights tail gate filler cup holder cover bed math oem
    Hey that's a big issue. I would highly recommend calling Weather Channel to assist you.:hattip:
  10. Nov 6, 2020 at 6:01 AM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    Did you see the truck when the windshield was out? Mine had rust along where the gasket is and I had to have that dealt with before having the windshield reinstalled.
    I'd also look along the gasket for kinks and gaps. I've seen some pretty rough windshield installations.
    Rastopher likes this.
  11. Nov 6, 2020 at 6:12 AM
    stevesnj
    Do you have a sunroof? I'm not sure if Tacomas had sunroof's then but if the sunroof drain is clogged this will happen. It happens on my Land Cruiser that's why I'm asking. Also check the steering shaft seal at the firewall. Just throwing ideas out there. The flood light idea is a good one.
  12. Nov 6, 2020 at 8:46 AM
    TruckLove
    Thanks, everyone, for all the ideas. I will investigate all these options. I didn't see the windshield repair so have no idea what that looked like. Sounds like there are many possible causes. No sunroof. Only happens on on driver's side so door seal seems like the most likely possibility.
  13. Nov 6, 2020 at 8:49 AM
    Spraynard
    Spraynard Priapism survivor
    hagrid
    Pittsburgh
    '19 AeroTundra PRO
    Sounding more and more like my prom night...
    JudoJohn, tacojim02 and 2stroke-Taco like this.
  14. Nov 6, 2020 at 10:15 AM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    If you have a hose, i’d spray down your windshield for a few minutes from all angles, especially on the drivers side. If it turns out to be a crap install that leaks, get someone to do it right, cause thats not safe, and there might be rust.
    If that doesn’t work, check the door and door weatherstripping. Open your door as if you were getting in the truck, and look on the bottom of the door. On the side that faces in, there should be a few rectangular holes meant to allow water to drain out. If they’re plugged with dirt etc the door can send water into your cabin.
    Also, the rubber weather seal where the door meets the cab could be torn. Check that too.
    good luck and keep us posted!
    TruckLove[QUOTED][OP] likes this.
  15. Nov 6, 2020 at 10:18 AM
    TruckLove
    Thanks! First bluebird day, I'll give all these suggestions a go!
  16. Jan 10, 2021 at 6:55 PM
    TruckLove
    Hi guys, Sorry for the late response. I finally figured out where the water was coming in! There is a wire cluster that goes from the engine into the engine block and the gap was big enough to allow rain and other water to leak in. I actually went to an auto glass replacement business. They check the glass and it was fine. So then we went under the hood and found the hole. Sealed up now and have had no leak now for 1.5 months! It's fixed.
