I have a droning sound...
Discussion in 'North East' started by Larzzzz, Jan 1, 2019.
  1. Jan 1, 2019 at 7:58 AM
    Larzzzz
    Larzzzz [OP] Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    It only happens while I'm driving and it gets kind of loud around 60 miles an hour. I changed gear oil in both differentials and the transfer case. When changing the front differential I noticed the CV axle has a fair amount of slop where it goes into the differential. Would the bad needle bearing cause a droning sound?
  2. Jan 1, 2019 at 8:01 AM
    Jonas
    Jonas Boogerrrrrr!
    Springfield, OR
    05TRDSport
    I would suspect wheel bearing.
    Gunshot-6A likes this.
  3. Jan 1, 2019 at 8:02 AM
    Larzzzz
    Larry
    MA
    @Jonas. That was the first thing I checked. I have no slop in either
  4. Jan 1, 2019 at 9:24 AM
    Jonas
    Jonas Boogerrrrrr!
    Springfield, OR
    05TRDSport
    I didn't have slop in mine either. What I did have was
    Droning sound
    Faint vibrations in steering
    Dragging wheel when I spun them
    After driving I would feel the hubs with my fingers. One was really hot, the other warm.
    That's all I got. Good luck!
    Gunshot-6A and Larzzzz[OP] like this.
  5. Jan 1, 2019 at 9:32 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Wheel bearing has to be pretty badly tashed to have play in it.
  6. Jan 1, 2019 at 10:02 AM
    Larzzzz
    Larry
    MA
    Hmmmmmm I'll check that out. Thanks.
  7. Jan 1, 2019 at 10:06 AM
    Holloman
    Holloman Well-Known Member
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    It could be an inner bearing mine had that problem. Easy coast gear supply sells a replacement bushing.
  8. Jan 1, 2019 at 10:14 AM
    Larzzzz
    Larry
    MA
    I've read about the ecgs bushing.
    Did replacing that get rid of the drone and the slop where the cv seats at the diff?
    Holloman likes this.
  9. Jan 1, 2019 at 10:15 AM
    Holloman
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    Yep
  10. Jan 1, 2019 at 11:16 AM
    Larzzzz
    Larry
    MA
    Oh joy. Almost at 300 k miles and I've yet to dig this deep into the truck... I haven't had to.
    Might as well replace that axle as well. It's original and with the slop that's there now, that shaft can't be looking to pretty.
    Edit:
    Ouch! Around $500. for the bushing with seal and removal tool along with a new axle and wheel bearing. I replaced the passenger side wheel bearing last year. I'll not be happy if i still got this drone.
    Shit like this is pushing back my stereo project. :annoyed:
  11. Jan 1, 2019 at 11:41 AM
    Holloman
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    Just realized you have almost 300k on your truck. It could be the inner bearing or it could be everything else :D
  12. Jan 1, 2019 at 11:43 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Droning?? You don't have your wife/girlfriend along with you, do you...?
  13. Jan 1, 2019 at 11:56 AM
    Jonas
    Jonas Boogerrrrrr!
    Springfield, OR
    05TRDSport
    Even more likely the bearing. Those fronts should be done In pairs. Also how I knew mine was bad. The previous owner had done one side not long before I bought it. Knew the other wouldn't be far behind.
  14. Jan 1, 2019 at 12:10 PM
    Larzzzz
    Larry
    MA
    Hobbs likes this.
  15. Jan 1, 2019 at 12:12 PM
    Larzzzz
    Larry
    MA
    I've done bearings already. Twice on the driver side once on the passenger side which was the last one done. Just about a year ago.
  16. Jan 1, 2019 at 12:20 PM
    Larzzzz
    Larry
    MA
    Well, we're over 700 now. Do i hear a thousand? Lol
    it is what it is.
    Edit again...
    Struts, shocks.... There we go. Do i hear 15?
  17. Feb 24, 2019 at 4:31 PM
    Larzzzz
    Larry
    MA
    In case anybody is wondering. I have replace both wheel bearings, both CV axles, and did ECGS bushing. I still have the droning sound. Do u joints or the carrier bearing then home to make any noise that resonates through the cab?
  18. Mar 24, 2019 at 3:18 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Are the tires chopped up at all/wearing weirdly?
  19. Mar 24, 2019 at 4:14 PM
    Larzzzz
    Larry
    MA
    No, they're not. I've been dealing with this noise for a while. And, these are new from last August/September as they were due before winter.
    It drones through the whole cabin making it impossible for me to localize it. I've replaced both from wheel bearings, CV axles , and did the ECGS bushing. Took the drive shaft out too. No change.
    Even though taking the drive shaft out made no difference, I'm still replacing the u joints and carrier bearing.
    Over 300 k miles now.
  20. Mar 24, 2019 at 4:22 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Exhaust?
