I have a dumb question
Discussion in '1st Gen. Tacomas (1995-2004)' started by dustbowl, May 31, 2010.
  1. May 31, 2010 at 5:02 PM
    dustbowl
    dustbowl [OP] Member
    slidell,louisiana
    02 limited tacoma
    :confused: Ive been trying to find out what is this damn ect button and its purpose. I read the manual and all I know is that it has something to do with the transmission. Someone please help my curiosity before it kills the cat.
  2. May 31, 2010 at 5:04 PM
    kato
    kato Well-Known Member
    Kelowna
    tacoma SR5
    As far as i know it just changes your shift points. I've been driving with it on. I find with my driving style that i end up getting markedly better fuel mileage.
  3. May 31, 2010 at 5:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    ECT = Electronic Controled Transmission
    AS mentioned, it changes shift points....Kinda like a first edition "Tow/Haul" mode.
  4. May 31, 2010 at 5:15 PM
    dustbowl
    slidell,louisiana
    02 limited tacoma
    Maybe I should try driving with it on because im only getting an average of 14 to 16 mpg and thats on the interstate. I wonder if that would have any long term affects on the trans?
  5. May 31, 2010 at 5:20 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Kenwood DDX-512 Deck, Boston Acoustics G5 Sub in Ported Bassworx Box, Kenwood eXcelon KAC-X10D Amp, Sirius Satellite Radio, Magellan GPS, DDM 55w bi-xenon headlights, 2 HID Hella 500ff's mounted behind grill, 4 pc ebay Billet grill, Fog Lights (my truck didnt have them stock), Pioneer Speakers 6x9's(front) 6.5's(rear) AFE Cold Air Intake, Hose Clamp Mod, Tailgate Strengthen Mod, Removed Gay Mud Flaps, De-Badged, BHLM, 245/45/20 on velocity wheels. VW865a, Extra D Rings In Box, OEM Cruise Added Optima Red Top Battery
    if its like a tow/haul button i would think driving with it on would have slightly nevative effects on mileage. doesnt it hold high rpm's longer before it shifts into a higher gear?
  6. May 31, 2010 at 5:24 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
  7. May 31, 2010 at 5:32 PM
    dustbowl
    slidell,louisiana
    02 limited tacoma
    any noticable long term affects? Ive got 115000 miles on my ride, trying to be a little easy on it ya know(just a little)
  8. May 31, 2010 at 5:37 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Shouldnt be any affects. I know the limits of a toyota auto, blew one in 100 miles :)
  9. May 31, 2010 at 5:44 PM
    dustbowl
    slidell,louisiana
    02 limited tacoma
    Thank yall for the info, I can finally get some sleep now. lol
  10. May 31, 2010 at 6:23 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    What button? I have a manual...don't have to have a computer determine my stinkin shift points.
  11. May 31, 2010 at 6:29 PM
    viperfella
    viperfella Well-Known Member
    Bubba
    North carolina
    2000 tacoma trd v6
    15'' mickey tompson bullet hole rims 31.10.50 mickey tompson baja tires
    the button is right where your clutch cancel button is. it gives us auto trans owners some more guts
  12. May 31, 2010 at 7:19 PM
    montanabay
    montanabay Active Member
    CA
    2.7L 4WD AUTO
    when I tow I use ETC and disengage overdrive.
    I've played with it by sound cursing around, but no tachometer makes it hard to tell.
    anyone know if the shift points with ETC are the same when overdrive is off vs on?
    Does overdrive off change the shift points too, or does it just block 5th?
  13. May 31, 2010 at 7:20 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
    I had this option on my old 1st gen, it came in handy for sure :cool:
  14. May 31, 2010 at 7:21 PM
    MTgirl
    Weesa
    ECT changes the point at which your truck will jump to overdrive. If you have overdrive off then ECT is basically off too (even if its on)
  15. May 31, 2010 at 7:38 PM
    viperfella
    Bubba
    North carolina
    2000 tacoma trd v6
    from what ive noticed it shifts .5k later and the auto trans in the tacoma is a 4 speed with the 4th gear being a overdrive if im not mistaken
  16. May 31, 2010 at 7:54 PM
    montanabay
    CA
    2.7L 4WD AUTO
    so what better for towing, ETC on or overdrive off?
    Are the shift points the same with overdrive vs no overdrive (no ETC), just no 4th gear (yeah, you can tell I came from a manual!)
  17. May 31, 2010 at 8:01 PM
    viperfella
    Bubba
    North carolina
    2000 tacoma trd v6
    i would say just leave the ect on unless your going thru hilly terrian
  18. May 31, 2010 at 8:22 PM
    MTgirl
    Weesa
    first, i don't tow with my truck. second, i've been experimenting with ECT for a few months now, since I spied one of the threads in here about ECT and gas mileage. until then I had never used ECT before.
    what I had found so far is that I do get slightly better gas mileage, about 0.5 to 0.75 mpg more with ECT on. I had assumed before that ECT would just eat up the gas mileage so I never used it.
    The basic idea is this (as I understand it) - Going up long, steep inclines the transmission will shift into high gear later and stay there longer once you've crested the hill if ECT is on. also I've noticed that with ECT on (especially offroad) the truck seems to also be out of control, accelerating much quicker on downhill stretches of road. You can switch o/d on and off to allow yourself to have control of when it engages to aid ECT.
    I've towed with other vehicles in the past and there is nothing worse than maxing out the power of your vehicle 1/2 way up a hill and knowing you have a long way to go trying to maintain some speed. ECT and o/d just give you more options and control to avoid this happening.
    Now my driving habits are this: ECT on and O/D on all the time for my around town driving and highway driving. ECT always off and O/D on or off depending on grade, etc for offroad driving. If I were to tow in my truck I would think that it would be most effective to have ECT on and O/D on except on steep hills, when you would want to toggle O/D when you thought the timing is best.
