I have a lean code comming up and dont know what it is
Discussion in 'New Members' started by toyota1063, Dec 15, 2012.
  1. Dec 15, 2012 at 8:36 AM
    toyota1063
    toyota1063 [OP] Member
    02 Tacoma
    I have a 2002 tocoma reg cab and my engine light came on and I took it to Auto Zone and they said it was a lean code that came up ( I dont know what the code number was, but it was a lean code ). So, I repaced the MAF and that didnt help. Im thinking it could be the a/f sensor but not reall sure,or it could be a vaccuum leak. How can I be sure what it is insted of spending $65 to hooked it up to a computer? Or would that that be the best thing to do is hook it to a computer? Im pretty low on funds and trying to get out of this cheaply
  2. Dec 15, 2012 at 8:39 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Too much air, not enough fuel. Look into all your fuel delivery components.
  3. Dec 15, 2012 at 8:49 AM
    toyota1063
    02 Tacoma
    Yes..I understand that is what that code means.. and I did..and I still dont know why im getting that code
  4. Dec 15, 2012 at 8:54 AM
    08pretaco
    az
    Other than the MAF what else have you done?
  5. Dec 15, 2012 at 8:55 AM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    I mean the first step is to know what code it is. Advance still does it for free. They don't clear the codes but they will pull them. Might be an oxygen sensor unless you've replaced them recently (There is a faulty O2 sensor code but they could also be bad and messing with your mix). After that you could need a fuel filter, new injector(s) maybe.
    You need to know which code it is unless you've got money to blindly throw at the problem.
  6. Dec 15, 2012 at 8:56 AM
    Aw9d
    Aw9d That one guy
    Best thing is get an actual code number. That rules out a lot of possibilities.
  7. Dec 15, 2012 at 8:57 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Did you? I'd start at the tank, and go forward. Mainly, pump, filter, injectors.
    But first, find out what the code actually is.
  8. Dec 15, 2012 at 8:58 AM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    Orieily's or autozone will read the code for you. Use that to look up the possible causes. The store may give you the top 5 likely causes when they print it out.
  9. Dec 15, 2012 at 9:07 AM
    misterdmac
    Doostin
    '97 2.7L DLX
  10. Dec 15, 2012 at 9:28 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    There are two different lean codes, P0171 and P0174. '1 means the problem is on the side of the engine with the #1 cylinder. '4 is the other side.
    When you step on the gas, does the vehicle seem hesitant or does it go like it has before? At idle, is the engine smooth or does it run rough?
    If either of these is happening, more than likely the problem is not related to the MAF. Instead, look to the vacuum system (leaks), PCV and possibly a fuel injector. Could also be a dirty fuel filter.
    Also, before you try anything more; did you clear the codes after you replaced the MAF? If not, try doing that first (assuming the engine is running smoothly).
  11. Dec 15, 2012 at 9:40 AM
    toyota1063
    02 Tacoma
    repalced the #1 coil pack..plugs..and the egr valve..i forgot the exact code for it..but it was a lean code
  12. Dec 15, 2012 at 9:56 AM
    Country101
    NW Arkansas
  13. Dec 15, 2012 at 12:17 PM
    toyota1063
    02 Tacoma
    it was a po171 code..i did clear the code when i replaced the MAF and the truck runs real good..smooth..im think a leak somewhere
  14. Dec 15, 2012 at 12:18 PM
    toyota1063
    02 Tacoma
    and its a 4 cyclender..the 2.7
  15. Dec 15, 2012 at 12:18 PM
    Cbass38
    Cbass38 Well-Known Member
    sebastian
    scottsdale
    07 pre runner
    projector hids,wheels,small lift,flowmaster
    its generally either 02 sensors, shitty injectors "doubtful" because youd probably have a miss fire... or an exhuast leak could be causing it also
  16. Dec 15, 2012 at 12:42 PM
    toyota1063
    02 Tacoma
    had both exhuast gaskets replaced like a year ago..im thinking the a/f sensor..thats $230 at a dealer..and toyota is VERY picky on any electical parts to put in
  17. Dec 15, 2012 at 1:07 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Question, if you clear the codes; when does the CEL come back on? Is it at engine start or after you put the truck in gear and drive away?
    If it's the later and you haven't swapped the fuel filter, I'd change that.
  18. Dec 15, 2012 at 1:13 PM
    toyota1063
    02 Tacoma
    it comes on like 16 miles after i cleared the code..it runs smooth abd all and i think the fuel filter is in the gas tank..no sure
  19. Dec 15, 2012 at 1:21 PM
    Country101
    NW Arkansas
    I think I remember seeing somebody with a first gen say it was located on the frame rail. May be off on that. I think in the 2nd gen it is in the tank.
  20. Dec 15, 2012 at 1:23 PM
    toyota1063
    02 Tacoma
    how would i know what gen it is..im thinking mine is 2nd gen cause i havent seen a filter
