I have a long travel on the front but I want more clearance, suggestions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by nolant2014, Jul 1, 2016.
  1. Jul 1, 2016 at 1:51 PM
    nolant2014
    nolant2014 [OP] Well-Known Member
    Hey guys, I have an 03 tacoma with a total chaos long travel on the front and I would like a little more lift on the front but I dont want to compromise ride quality. any suggestions?
  2. Jul 1, 2016 at 2:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Without cranking in more lift by adding pre-load to the COs, I don't see any options. I suppose you could get a little more by going to a larger tire but that may also require adding pre-load and also some tubbing in the pinch weld area.
    Are you a 4x4?
  3. Jul 1, 2016 at 2:32 PM
    nolant2014
    no its a 2 wheel drive, I have a prerunner set up and just want a little more clearance for offroading so I don't want to go with a bigger tire
  4. Jul 2, 2016 at 4:08 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Lift spindles.
  5. Jul 2, 2016 at 5:48 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Buy a skid plate.
    You should have loads of clearance with that lt. More than youd need for where a 2wd truck will get you.
  6. Jul 2, 2016 at 9:04 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    what size tires are you running? what are you trying to get over that you need more ground clearance?
