I Have a Need for Isolation
Discussion in 'Off-Roading & Trails' started by Nick54, Sep 9, 2012.
  1. Sep 9, 2012 at 10:40 AM
    Nick54
    Nick54 [OP] Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    Does anyone make a safety thimble isolator that can be installed once the line is already on the winch spool?
  2. Sep 9, 2012 at 2:48 PM
    Nick54
    Nick
    Mentor Ohio
    27 looks and no comments, am I to assume there isn't such an isolator???
  3. Sep 9, 2012 at 2:56 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I think you would get better response in a different topic.
  4. Sep 9, 2012 at 3:00 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
  5. Sep 9, 2012 at 3:10 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    That's actually from factor 55.
    OP is talking about a rubber thimble isolator though, not what you posted. An isolator will keep the thimble from banging and making noise on the fairlead.
  6. Sep 9, 2012 at 3:58 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    as in the rubber base that comes with the one i posted?
  7. Sep 9, 2012 at 4:34 PM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Yes.
  8. Sep 9, 2012 at 4:38 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    gotcha.
    OP, if you're ok with the look, i'd jsut cut a circular piece of rubber with a slid leading to a hole in the center. just slide it on when you pull in your line, and put it in your pocket when the winch is in use.
  9. Sep 9, 2012 at 5:20 PM
    Nick54
    Nick
    Mentor Ohio
    This is the item I'm looking for and I think your approach Colin is the likely solution. I will probably get two, cut one for now and when I get around to unspooling the line put the uncut one on.
    Thanks
  10. Sep 9, 2012 at 5:22 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    sounds like a good plan. I can't imagine a piece of polyurethane like that cost too much either.
  11. Sep 9, 2012 at 5:42 PM
    Nick54
    Nick
    Mentor Ohio
    Actually I was just looking at hockey pucks at Dicks Sporting Goods. 1"X3" and just $2.00 Drill a 5/16" hole and cut a slot to the center. The viking isolators are $8.00 to $3.00 shipping. I can ge the puck tomorrow and order the isolator. I think this will be a quick temporary fix.
