I have a nocking noise coming from either the front strut or the steering rack?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04TRD4x4, Jan 13, 2010.
  1. Jan 13, 2010 at 3:01 PM
    04TRD4x4
    04TRD4x4 [OP] Active Member
    OC california
    04 limited TRD 4x4
    bumpers, rock sliders, rims, more to come
    When I drive over bumps in the road or when i'm driving down a dirt road with pot holes my truck sounds like the front drivers strut and spring are loose. I put my truck on jack stands and check everything. nothing seems loose? anyone have any ideas? Has anyone had this problem before.
  2. Jan 13, 2010 at 3:20 PM
    takern
    takern Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    i have the same thing. i read somewhere that it is the sway bar bushings or somethin to do with the swaybar. i have not gone under there and looked at it yet though
  3. Jan 13, 2010 at 4:00 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    If its just a "knocking,bumping noise" when you hit bumps in the road but your steering & control feel fine its probably your front stabilizer bushings worn out... pretty cheap...pretty easy fix too.....:cool:
  4. Jan 14, 2010 at 1:37 AM
    04TRD4x4
    OC california
    04 limited TRD 4x4
    Yeah my steering and control is perfectly fine, its just a knocking or kluncking noise when i hit bumps in the road. I'll check the stabilizer bushings. hopefully its as easy as just that. thanks.
  5. Jan 14, 2010 at 5:02 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
  6. Jan 14, 2010 at 7:12 AM
    TacomaDan
    TacomaDan Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    That will solve it even tho it only happens when the driver side hits a bump? i have the exact same problem!!!
  7. Jan 14, 2010 at 3:15 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    sounds like it could be ball joints also
  8. Jan 15, 2010 at 12:20 AM
    TacomaDan
    Daniel
    Woodland, CA
    even if the steering isnt sloppy and the suspension cycles fine? i mean besides the clunk
  9. Jan 15, 2010 at 12:23 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    ball joints!, lift the front of the jack and put it on jackstands, with the tire completely off the ground, try to move the tire back and forth, as in hands at 3 and 9 and twisting (not turning) the wheel, if there is any play it is ball joints.
    if it is moving, loosen the boot on the end of the steering rack to check the inner ones, get someone to twist the wheel as you watch for play.
  10. Jan 15, 2010 at 7:17 AM
    Idrivetoys
    Yuma AZ
    yeah even with no sloppy steering it still probably is a ball joint
  11. Jan 15, 2010 at 11:35 AM
    04TRD4x4
    OC california
    04 limited TRD 4x4
    Ok. I'm checking my ball joints now also. thanks
  12. Jan 15, 2010 at 1:19 PM
    04TRD4x4
    OC california
    04 limited TRD 4x4
    Its not the ball joints they seem pretty tight. no play at all. I ordered the steering rack bushings, I'll let you guys know after i install the bushing if that solves the problem.
  13. Jan 25, 2010 at 6:07 PM
    persianboy1769
    persianboy1769 Member
    josh
    chino hills
    Procomp 3" spacers with aal, procomp rims with 265/70/17 nitto terra grapplers, 6k hid headlights 3k foglights with yellow film, Flowmaster muffler, k&n intake
    i think i have the same problem. my truck makes a knocking noise when i go offroading or when i turn left. i went to the dealer and they said it was the upper control arm hitting the strut. so i went home and jacked it up myself and saw that the control arm does hit but i do not think thats what makes the noise.
