I have a stock 2018 SR5 4 cylinder with a 3500# towing capacity.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by arizonakawboy1, Feb 19, 2020.
  1. Feb 19, 2020 at 7:21 PM
    arizonakawboy1
    arizonakawboy1 [OP] New Member
    David
    tacoma
    I need to replace original shocks. Anyone have a suggestion on shocks that may increase towing capacity? Thank you...
  2. Feb 19, 2020 at 7:22 PM
    Bishop84
    Bishop84 Well-Known Member
    Unfortunately the only way to increase load capacity is to buy new shocks attached to a new truck.
    Yann, hiPSI, Txexplorer and 5 others like this.
  3. Feb 19, 2020 at 7:24 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Its friday somewhere i guess.
    Malvolio, whatstcp and Chew like this.
  4. Feb 19, 2020 at 7:28 PM
    DevilTaco4
    DevilTaco4 Well-Known Member
    Folsom, CA
    2017 SR Access 5MT
    Penis
    Malvolio and Junkhead like this.
  5. Feb 19, 2020 at 7:29 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Malvolio likes this.
  6. Feb 19, 2020 at 7:34 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    New shocks are not the problem. It is the engine that is limiting you. You need the V6 to pull more.
    Junkhead likes this.
  7. Feb 19, 2020 at 7:40 PM
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
    Malvolio and Junkhead[QUOTED] like this.
  8. Feb 19, 2020 at 8:13 PM
    arizonakawboy1
    David
    tacoma
    Really? I'm looking for 5% +/- 3675# to pull my trailer from one side of a job site to the other! I have a one ton diesel... but it has gotten too costly to drive over the road. Hence 4 cylinder. MILAGE! 27.5 Highway. I've tweeked many 22RE and I'm sure I can get 175# more towing out of this engine.
    I do not want to change leafsprings even though that would do it, it would also change ride dynamics. Just looking for shock recommendations. Thank you.
  9. Feb 19, 2020 at 8:16 PM
    Bishop84
    Very likely the 4 cylinder shocks are the same as the 6 cylinder 6400# shocks. They don't make a difference to load.
    Adding a leaf or air ride just shifts weight forward, neither can add to weight capacity.
    If you tow over and DOT catches you, especially commercial it can be a bad thing.
  10. Feb 19, 2020 at 8:22 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    You can weld in a second set of shocks if you want. It will still not increase your towing capacity. Springs won't either. You are limited by the rating Toyota has put on the vehicle.
    And welcome to the forum :hattip:
  11. Feb 19, 2020 at 8:56 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Itll do it, just dont take it out on the road
  12. Feb 19, 2020 at 9:17 PM
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
  13. Feb 19, 2020 at 9:19 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Dude shocks have nothing to do with increasing towing payload. Nothing.
