I have a stupid idea
Discussion in 'Street Trucks' started by gstodd, Apr 10, 2024.
  1. Apr 10, 2024 at 11:12 AM
    gstodd
    gstodd [OP] Well-Known Member
    2005 2wd base 5-lug
    Now hear me out before you tell me how dumb this idea is.
    I have a 2005 base 4-banger w/ manual transmission. My original plan for the truck was to 4-link the rear, run coil overs, swap to disc brakes and drop it using the DJM kit. Now I've been thinking about getting all this done in a different way. Swapping in a Mustang IRS.
    The bolt pattern for both hubs is the same, with a larger center bore, axle width is within a couple inches of each other and one variation of the Mustang differential has a 3.31 gear ratio just like my stock diff.
    Pros:
    This gets me disc brakes, without the weakened/no e-brake issue of most of the rear disc kits.
    Takes care of the rear drop
    Gets me an IRS over the 4-link.
    Cons:
    The Mustang IRS would have to be welded in, but so would the 4-link.
    I would need to figure out where/how to mount some coil overs, but I had already planned on doing this.
    The gas tank would have to be relocated to either the rear in place of the spare or put a fuel cell in the bed.
    I would have to have a custom driveshaft made.
    Ok, now everyone can pick this apart and point out things I've missed and tell me how dumb it would be.
    Gunshot-6A, drizzoh, wilcam47 and 3 others like this.
  2. Apr 10, 2024 at 10:08 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    I say go for it. Step 2 after...Turbo
    Gunshot-6A, wilcam47 and 23MGM like this.
  3. Apr 10, 2024 at 10:17 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    If you don't care about putting time and money into a 4cyl 20 year old truck, go for it. I'd like to see the end result. It might be cool.
  4. Apr 10, 2024 at 10:23 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    agree
    23MGM[QUOTED] likes this.
  5. Apr 11, 2024 at 7:28 AM
    pinktaco808
    pinktaco808 Hot Steppa
    Do it
    ohcaltexscar likes this.
  6. Apr 11, 2024 at 7:30 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    This is the way.
    dannybubbles and gstodd[OP] like this.
  7. Apr 11, 2024 at 10:45 AM
    gstodd
    2005 2wd base 5-lug
    Yeah, but this 20 year old truck only has 52,000 miles on it and I put 10K of those miles on it in the last year or so. Also I just modify my vehicles, started at 16 and have keep doing it for almost 40 years. I was sort of hoping someone would point out something big I missed. Looks like I shall have to get the project car up and going so I can daily it while putting this under the welding torch.
  8. Apr 11, 2024 at 10:48 AM
    gstodd
    2005 2wd base 5-lug
    Nope, if I go forced induction I would go supercharger. But it Cali emissions would prevent that. Sort of hard to get that to pass the visual portion of the test.
  9. Apr 11, 2024 at 11:08 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It's not crazy at all.
    People like you, are the ones that get things done.
    Other never do, because it's not "drop-in" or easy.
    Go for it.
    I'd be interested to see the put come.
  10. Apr 28, 2024 at 7:02 PM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    Southwest Ohio
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
  11. Apr 29, 2024 at 11:08 AM
    gstodd
    2005 2wd base 5-lug
    Yeah, I've watched both of those videos. There are some much better ones, especially in the F100 crowd, on doing it but those at least give some ideas.
    batacoma and ohcaltexscar like this.
  12. Apr 29, 2024 at 11:19 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Do it
  13. Jun 7, 2024 at 1:43 PM
    dannybubbles
    dannybubbles yada yada
    Daniel
    Chico, CA
    01 3.4 auto 4x
    Only thing I can think of is to maybe try and get a body cut when you get the rear suspension setup? thinking of the floor pan thru fenders, basically a cross section slice of the car that contains the upper shock/coilover mounts, that way you'd have a template to work off of for
    the truck side upper mounts.
    Does that make any sense?
  14. Jun 7, 2024 at 1:50 PM
    gstodd
    2005 2wd base 5-lug
    While I can see where that might work I'm going to dump the stock shock and spring setup and just go with a custom coil over that is the correctly length once I put the rear in. It's just easier and won't require cutting into the bed to fit it.
    dannybubbles[QUOTED] likes this.
  15. Jun 7, 2024 at 1:58 PM
    dannybubbles
    Daniel
    Chico, CA
    01 3.4 auto 4x
    makes sense to me, and sounds like a fun and unique way of doing it in general, dig the swap plan.
    Look forward to pictures and problem solving when the time comes
    :popcorn:
    Edit: replaced a question about mounts with a link to mounts, lol
  16. Jun 7, 2024 at 2:06 PM
    dannybubbles
    Daniel
    Chico, CA
    01 3.4 auto 4x
  17. Jun 10, 2024 at 9:51 AM
    gstodd
    2005 2wd base 5-lug
    Yep, looked over their kit and while it would be nice to get something almost ready made I'll need to cut into the frame since I want to go lower than their brackets would let me.
  18. Jun 10, 2024 at 9:56 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I say go for it.
    I admire your can-do attitude. if you can afford it, do it.
  19. Jun 10, 2024 at 6:09 PM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    Already been done.
    There was a guy with a stunner who didn’t an IS300 it’s swap. My buddy did an s13 swap in his pick up. Not a crazy idea. It’s been done. Good luck I’m sure you will have lots of options.
  20. Jun 10, 2024 at 6:22 PM
    dannybubbles
    Daniel
    Chico, CA
    01 3.4 auto 4x
    Doesnt look like theres too much to the kit anyways, pretty sure fabbing four flat spots for bolts will be the least of it, lol. And from the sound of it you obviously have a plan and the skills to make it happen
    :cheers:
    Pretty clear from the polls that we all agree its a great idea, so start throwing money at it and take some pics so we can all support your progress!!!
    :popcorn:
