I have an obsession with perfect glass!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hattr1ck, Oct 16, 2018.
  1. Oct 16, 2018 at 8:50 PM
    Hattr1ck
    Hattr1ck [OP] Well-Known Member
    Josh
    2017 DCSB TRDOR 4x4
    None yet
    So I hate imperfections in my windows and windshield. I can’t stand smudges or fog/haze on the inside, spots and dirt and grime on the outside. Even the residual left on the areas where wipers don’t reach bothers me after even a day after it’s done raining. Lately I have been going through getting new wipers. My stock pair finally started to fray at the ends. I have always been a fan of Bosch. I’ve used them on several different cars with amazing results and longevity. So of course I went with them again. But to much dismay, I have less than ideal performance this go around. Within the first couple weeks the wipers were hopping. Still clearing the water off smoothly but hopping in the process which drives me insane!! Got a replacement set free of charge from the store and the same happened almost instantly. I use and have always used in all the other cars the green rainx washer fluid so I’ve ruled that out. The fluid seemed to help lubricate the wipers a little but only while constantly spraying. Went and got another set, different line of Bosch and they had similar issues but not as noticeable. Only the end on the inner sweep motion hops after a short break in period(which was worse at first but I gave tons of break in opportunity on the previous pairs too). The hop is mild and inaudible now but still visible and annoying. Anyone have tips or similar experience?? By the third pair I liberally cleaned the glass to possibly remove any imperfections that might be obstructing smooth flow and sweeps of the wipers. Still the mild inner arch vibration or hop
    I married my tacoma likes this.
  2. Oct 16, 2018 at 9:01 PM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Ceramic coat your windshield....
    Thank me later.
  3. Oct 16, 2018 at 9:06 PM
    Hattr1ck
    Josh
    2017 DCSB TRDOR 4x4
    None yet
    Been debating on that regardless of the wiper issues. Also was curious about the ultra hydrophobic product rustoleum makes if it could be applied to glass etc?
    Any suggestions on ceramic coating otherwise. See tons of different ones come across my fb and ig and each seems to think it’s the greatest since slice bread.
  4. Oct 16, 2018 at 9:10 PM
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    I have ceramic pro 9h on mine. Cleaning is easy and water just beads right off. I only had Id done cuz my paint is also coated.
    Otherwise if not that route just use a DA polisher and some glass polisher and go to town and use your favorite wax/sealant. I use invisible glass to clean all my windows in between washes. This is what I do with my Audi windshield that is not coated.
  5. Oct 16, 2018 at 10:52 PM
    Silentwolf
    Silentwolf Well-Known Member
    2017 Tacoma SR
    Cruise Control,Led Reverse lights, Weathertech mudflaps, Weathertech headlight protectors,Lund stepbar, Interior Leds, AVS Hoodflector, AVS In-Channel Ventvisor, aFe Pro DRY S airfilter, K & N cabin airfilter, A/C drain valve, Mostplus Led Headlights
    Had Bosch wipers for 2 years.
    Theyve always hopped. The drivers side bottom when vertical but only the last 1/4 of the arm swing.
    gthupman and I married my tacoma like this.
  6. Oct 16, 2018 at 11:16 PM
    ELT2JV
    ELT2JV Well-Known Member
    17 TRD OR ACLB
    8112 front 8100 rear. Method NV with 265/75/16 KO2.
    Aquapel coating, rainx fluid, bosch icon wipers. I don't use wipers over 35, and they dont skip
  7. Oct 17, 2018 at 3:06 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I too have had issues on my vehicles in the past. I always go back and use OEM blades. My Suburban required OEM blades, nothing aftermarket worked. My Tacoma only has a few thousand miles and has I have only been in the rain a few times but the factory bladed don't hop. I have always used a little lacquer thinner on a rag and cleaned off the blade, this might help your blades. I have used a product called glass wax, had a can for years and I have yet to find another can and even tried google to find it. A little of it goes on when it gets a fresh coat of wax.
    hiPSI and I married my tacoma like this.
  8. Oct 17, 2018 at 4:57 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I think the hopping is due to crap on the windshield that we don't see. I've had good luck with using 0000 steel wool to clean the outside of the windshield. It seemed to stop the hop until it needed cleaning again. It seemed to last at least 6 months.
    Actually, mine started hopping again. The next dry day, I'll clean it again.
    tonered likes this.
  9. Oct 17, 2018 at 5:00 AM
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    There is a glass guy on here.
    I remember a thread with him discussing all of what to use and not to. Wish I could think of it, but it's been years.
  10. Oct 17, 2018 at 5:28 AM
    Hemlocktherm78
    Hemlocktherm78 Well-Known Member
  11. Oct 17, 2018 at 5:38 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
  12. Oct 17, 2018 at 5:50 AM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    Didn't see that one coming...
    Anyone have a easy way to get those water spots off the glass? My Taco is less than a week old and I guess it got them sitting on the dealer lot.
  13. Oct 17, 2018 at 5:59 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Rain-X on the windshield. Not the washer fluid (though I use that too to keep the application 'topped off'), but the actual rub on/buff off concentrated stuff in the yellow bottle. Keeps the wipers from chattering at low speed, and at anything faster than 30-35mph the wind just rolls the water off so you don't need to bother with the wipers at all.
    Wipers can't chatter if they aren't running :laugh:
    Hattr1ck[QUOTED][OP] likes this.
  14. Oct 17, 2018 at 6:15 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I recently purchased PIAA Silicon Wipers, they seem to work quite well.
  15. Oct 17, 2018 at 6:28 AM
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    I recently replaced my OEM blades with Trico Onyx, their top of the line blade. They were on sale. They are terrible! Aside from chattering in a light rain, the drivers side does the strangest thing. In any decent rain the blade gets to the far left side of the windshield and then it pulls a sheet of water about a third of the way back across the stroke of the wiper! It must be a draft related issue, it's worse at higher speeds. I'll be going back to OEM asap.
  16. Oct 17, 2018 at 7:52 AM
    Hattr1ck
    Josh
    2017 DCSB TRDOR 4x4
    None yet
    I’d follow the ‘vette cleaning video mention towards the top with clay bar after spraying etc. Really about the only thing that’ll get those “stained” on water spots or you’ll scrub a hole in ur paint or glass trying.
    And I don’t have a problem with water beading and still being able to see, Especially at speed bc it does run up and off mostly. But in town I wipe more and they just hop.
    I’ve deep cleaned like mentioned above and waxed the glass. Might be time to redo it but the oe blades didn’t hop ever. I only replaced them after almost 2 years bc the ends frayed
    MFTAF13 and Vbpiper like this.
  17. Oct 17, 2018 at 9:47 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    When mine started to fray, I replaced with the Toyota Sightline and they are pretty solid imho. Quiet, work a bit better than my stock ones did new and flex really well to the curvature of the windshield. Had them on for 3-4 months now and they are just like new
  18. Oct 17, 2018 at 9:54 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    take a razor blade and clean your windshield with a glass cleaner as lubricant. you'll hear and feel all the crap the wipers are dragging against. Hold the blade at a pretty shallow angle as you don't want to gouge the glass.
    wipe down with a waffle weave microfiber.
    next get a clay bar with a water based lubricant and clay bar the windshield. again wipe down with the a new waffle weave microfiber.
    next get your favorite paint sealer. not rain x or even wax, it needs to be a sealant and apply it lightly and buff with a standard soft microfiber. if you can do this facing the sun to find haze smears. buff and buff and buff until clear.
    lastly, remove and clean the wiper blades with your glass cleaner. making sure they are not damaged.
    the sealant will let water roll off at speed and last much longer than rain x or wax. each time you use your wipers you're wiping off the wax/rain x and clogging the wiper blade up.
    do this twice a year usually after winter and in the early fall.
    edit: video on how to use the razor blade technique
    https://www.youtube.com/watch?v=_NTPTjEkpvw
    photogr4x4, BVita and oscolivar1 like this.
  19. Oct 17, 2018 at 10:10 AM
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    Larry kosilla +1 for you!
  20. Oct 17, 2018 at 10:17 AM
    tonykarter
    Snuff Gully, Texas
    How about polishing the glass with a Porter Cable after the clay bar?
