I have literally no idea why this sound is occurring. Possible piston slap?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by disel_V1, May 10, 2021.
  1. May 11, 2021 at 12:14 PM
    disel_V1
    disel_V1 [OP] I eat cold pizza rolls
    3rd Gen
    few things here and there.
    Dang, how much was that to fix?
    the sound certainly gets a bit quieter in gear. Sometimes the sound is more apparent than other times. It doesn’t quite make sense to me. Just hoping it’s nothing too serious..
  2. May 11, 2021 at 1:26 PM
    Taco'09
    Taco'09 Well-Known Member
    Take a sample of your oil and send it off for analysis to some place like Blackstone Labs. It is cheap to do.
  3. May 11, 2021 at 1:38 PM
    disel_V1
    3rd Gen
    Took it to a shop today (they were busy, but came out to at least take a listen. Which was cool, didn’t ask them to!)
    anyway
    some questions he asked
    does it run good? Yes
    Does it idle fine? Yes
    (Unscrewed oil cap, shined a like down and observed. Said it looks really good.)
    Checked oil level (looks good)
    Is it worse in a cold start? No
    Does it get worse as you rev the engine? No
    Does it get worse going down the road? No, it gets quieter in gear. Can’t hear it when I’m driving
    final verdict (for now) : Just drive it.
    he said you’ll know if it gets worse. The fact that it hasn’t isn’t a telling sign, but it’s also not a death sentence.
    he mentioned that it would need investigated to determine the exact source, but the engine itself sounds fine.
    he said he would just drive it and if it gets worse.. THEN bring it down. Of course it wasn’t doing it there on the spot. (At least as loud).
    nonetheless.. I think he’s right. I should just drive and observe. If it gets worse I’ll just make the inspection appointment
    others say theirs sounds the same.. some say “mine doesn’t sound like that” .
    Who knows. ‍♂️
  4. May 11, 2021 at 1:43 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Piston slap....... :rofl::rofl::rofl::rofl: Not likely.
    The piston fits the cylinder bore with a few thousandths of an inch clearance. Plus the length of piston prevents the piston flopping around in the cylinder bore.
    If by some chance the piston is "slapping" around in the cylinder bore, then you have serious engine problems and the resulting noise will be horrendous.
    wilcam47 likes this.
  5. May 11, 2021 at 1:55 PM
    disel_V1
    3rd Gen
    makes sense! I was told by well.. the internet that’s what it may be. That’s why I wanted more feedback lol.
  6. May 11, 2021 at 1:55 PM
    Northerntaco69
    Northerntaco69 Well-Known Member
    2023 TRD Offroad 6MT dcsb
    Trd pro grill, blackout overlays, black tailgate inserts
    3k for a used motor. The used one sounded real quite. They put a little hole in the oil pan so we had to rip that motor out to change the upper oil pan. Luckily i can change a motor so no labor
  7. May 11, 2021 at 1:57 PM
    Knute
    Suggest you spend a little time to learn about the basic assembly of a piston type engine.
    Try a 1 cylinder lawnmower engine. They all assemble the same basic way.
  8. May 11, 2021 at 2:09 PM
    disel_V1
    3rd Gen
    i agree, something I shouldn’t have to guess with.
  9. May 11, 2021 at 2:18 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Piston slap is an actual thing.. it used a problem for older Hondas in the 90s. The pistons are aluminum and they would rattle (slap) in the bores when cold. The clearances were just a hair too loose when cold, when the engine heated up they would expand and quiet down. Might not be what's going with OP's truck but it does happen
    Northerntaco69 likes this.
  10. May 11, 2021 at 2:21 PM
    zippo88
    zippo88 Well-Known Member
    L
    2012 sport
    You're over thinking it. You said the sound was coming from the cat. It would make sense the sound is worse at idle.. more vibration.
    Inspect the cat again. I'm sure something is loose there. Either a heat shield or something internal.
  11. May 11, 2021 at 2:26 PM
    disel_V1
    3rd Gen
    for sure. I think I’m still in the “oh god, please don’t be serious” phase. We all love our trucks, but you know.. it is what it is.
    still drives great!
    zippo88[QUOTED] likes this.
  12. May 11, 2021 at 2:27 PM
    Knute
    Heat shields are notorious for coming loose.
    Is the noise like a cheap tinny sound? Similar to a empty tomato can rattling around in a metal box.
    Kolter45 likes this.
  13. May 11, 2021 at 2:36 PM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Sounds like most Toyotas I've owned. The 22R-E in my old Pickup used to sound like a diesel.
  14. May 11, 2021 at 2:45 PM
    disel_V1
    3rd Gen
    Well fellas, idk if this will help but I made another video. I’m not too good at helping find the obvious. I just thank y’all for your help as is. I made this in the event anyone wanted more clarity.
    https://youtu.be/zcHQmg7vvBI
  15. May 11, 2021 at 3:04 PM
    #35
    Caboose69
    Caboose69 Well-Known Member
    2011 Black DCSB Off Road
    I had a similar noise coming from mine. I really only noticed it at idle. It wasn't bad, considering it's 10 years old with 165K on the odometer, but it was mildly annoying to me. I was prepared to live with it. But after my first oil change ( I bought the truck last November), the noise has vanished! I was pleasantly surprised. I don't know what oil was in it, but I put in Castrol EDGE Extended Performance (gold bottle) 5W30 full synthetic. The oil level was full when I changed the oil. Maybe try a different oil and see what happens?
  16. May 11, 2021 at 3:06 PM
    #36
    disel_V1
    3rd Gen
    I’ve had the truck about 35 days and it’s due for one! I’ll give that a shot.
  17. May 11, 2021 at 3:38 PM
    #37
    Northerntaco69
    If you can inspect the filter media. You'll need to cut the filter open
  18. May 11, 2021 at 3:46 PM
    #38
    disel_V1
    3rd Gen
    When I inspect it, what should I look for? Also, if I find something abnormal should I do anything specific? I’ll have it done by the shop when I get the oil changed. I was all excited to change it myself, but just to make sure.. I’ll have actual mechanics inspect it lol
  19. May 11, 2021 at 4:19 PM
    #39
    Lthompson
    Lthompson Well-Known Member
    Its the Cat... mine is the same.. took it off, and didnt hear it. You can really tell if you get under there with a hose in your ear. The sound comes straight from the cat
    disel_V1[OP] likes this.
  20. May 11, 2021 at 4:21 PM
    #40
    disel_V1
    3rd Gen
    thank you. I thought it may be.
