I have no idea what package or sub model my truck is
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RustyChicken, Aug 25, 2021.
  1. Aug 25, 2021 at 4:18 PM
    RustyChicken
    RustyChicken [OP] Member
    I have a 2006 Tacoma that I assumed was a prerunner trd ,but when I asked the dealership and they told me it was a base model with no packages. I was highly confused because I have leather seats and 6lug wheels. I called a second dealership and they told me it was a base model with the sr5 package, which sounds a bit more correct, but it still doesn’t quite add up because of the leather seats and I have 6 lugs instead of 5. I find it highly unlikely that the previous owner would go through all the trouble to change the seats and the wheels from 5lugs to 6. As far as I understand only prerunner and 4x4 have a 6lug pattern. Now my question is can anyone help me tell what package and sub model my Tacoma is? Is there any other things I can look for to tell if it’s a prerunner other than the lugs and seats? Any help or feedback will be much appreciated, thank you.
  2. Aug 25, 2021 at 4:30 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    If you are able to post some pics of the interior and exterior that would help and someone could likely tell you what you’ve got.
    you can also go to toyotaowners.com and register and add your vin and look at the build information
    welcome aboard!
    knayrb likes this.
  3. Aug 25, 2021 at 4:33 PM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
  4. Aug 25, 2021 at 4:43 PM
    RustyChicken
    I’m not sure if this helps. If not just let me know what else to take a picture of.
    BassAckwards[QUOTED] likes this.
  5. Aug 25, 2021 at 4:47 PM
    BassAckwards
    Looks like you have an SR5 with a color matched grille, sport hood, and plasti dipped or painted rear bumper.
    the sr5 package came with color matched fender flares and a chrome rear bumper and grille surround. It looks like someone didn’t like the chrome rear bumper and chrome grille it came with and did some swapping.
    wi_taco likes this.
  6. Aug 25, 2021 at 4:49 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    I see a Sport hood and stock wheels, but that doesn't necessarily mean its a TRD Sport. It could be a good indicator though.
    Leather seats have nothing to do with it, those are aftermarket and no packages came with that standard as far as I know
    EDIT: agree with @BassAckwards . That looks like a SR5 with a Sport hood
    wi_taco likes this.
  7. Aug 25, 2021 at 4:49 PM
    RustyChicken
    so what about the leather seats and the 6lug wheels? The dealership and vin number says it’s base model sr5 with no prerunner. And as far as I’ve seen the sr5 doesn’t come with leather seats or 6lug wheels. Although I do feel like the seats could have been swapped.
  8. Aug 25, 2021 at 4:51 PM
    RustyChicken
    Is there something I can look for to determine wether it’s a prerunner or base model? The reason I ask is because I need new struts and I know there is a difference between prerunner struts and base model ones
  9. Aug 25, 2021 at 4:51 PM
    BassAckwards
    They could have swapped the seats for some aftermarket ones or added covers like clazzios or katskins.
    sport wheels are an easy swap too along with the hood and grille. Those are a pretty common swap around here. The chrome rear bumper with the color matched flares, black door handles, and black mirrors all point to an sr5. TRD sports had color matched goodies
  10. Aug 25, 2021 at 4:52 PM
    BassAckwards
    Your truck is a prerunner
    wi_taco and blu92in99 like this.
  11. Aug 25, 2021 at 4:53 PM
    Shwaa
    Bay Area, CA
    If it's 6 lug its definitely not a base model. The comparison you are looking for would be Prerunner sR5 vs TRD. Unfortunately the easiest way would have been to look at the stock seat material, but yours doesn't have that. I think the TRD Sport may have a LSD (Limited Slip) button left of the steering wheel, that the SR5 won't have? Someone else may need to confirm that though.
  12. Aug 25, 2021 at 4:55 PM
    RustyChicken
    Thanks for the help. The reason I’m double checking is because I was told it was a trd and it also came with the trd stickers which I took off. After running the vin and seeing it was a sr5 I wanted to make sure it was a prerunner also or if the previous owner just bought the lettering and put it on himself like he did with the trd
  13. Aug 25, 2021 at 4:55 PM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Take a picture of the front struts (suspension)
  14. Aug 25, 2021 at 4:55 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Climb under it. If there is a transfer case and front diff then it’s not a prerunner. They are only 2WD
  15. Aug 25, 2021 at 4:59 PM
    RustyChicken
    I’m not sure if this helps. If not I can take one from a different angle
  16. Aug 25, 2021 at 5:01 PM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
  17. Aug 25, 2021 at 5:02 PM
    BassAckwards
    The black tokico shocks reaffirm the sr5 theory. The TRD sports came with yellow and blue bilsteins.
    The lack of CV axles confirm it’s a prerunner
    wi_taco and TacooSaucee like this.
  18. Aug 25, 2021 at 5:03 PM
    BassAckwards
    On a side note, what are those pieces in between the coil spring?
    Marcmtb1 likes this.
  19. Aug 25, 2021 at 5:08 PM
    RustyChicken
    no clue. I’m guessing it has something to do with how they raised the truck. I’m replacing all of the suspension anyways and I’m going to get it raised the right way but I needed to know which ones to buy
  20. Aug 25, 2021 at 5:11 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Those are old fashioned coil spring lifts. You twist them in with an extension on a ratchet.
