I have no idea what this is...
Discussion in 'Suspension' started by malcolmpless, Jan 26, 2012.
  1. Jan 26, 2012 at 8:35 AM
    malcolmpless
    malcolmpless [OP] Member
    Malcolm
    Provo, UT
    01 Tacoma SR5 TRD
    6" Fabtech Lift, 35's
    Alright, I just got my first Tacoma. Took it wheelin for the first time and found out that my rubber bushing on top of my shock is shot, it gets to banging around in there. The problem is that I have no idea what kind of setup this is or who to go to for parts. I have tried searching all over the forum and google to no success. I can't seem to find anyone that has the upper A arm deleted. I have no idea what kind of setup this is, or what it is called if it has a 'name.' Any help as far as what this is, who might make it, and where I can get parts from would be greatly appreciated!
  2. Jan 26, 2012 at 8:37 AM
    98tacoma27
    Ben
    Not Beech Creek
    They don't make that lift anymore.
  3. Jan 26, 2012 at 8:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Looks like an old Trail Master lift. You can get a Gabriel strut to replace the worn out one....cant remember the part number though.
  4. Jan 26, 2012 at 8:40 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    what lift is that?? thats so weird, never seen it before..
    ben, who used to make it?
    EDIT: thanks chris. im sure they still make parts for it or some type of replacement
  5. Jan 26, 2012 at 8:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    Trail Master. That's probably the forth one I've ever seen.
  6. Jan 26, 2012 at 8:43 AM
    98tacoma27
    Ben
    Not Beech Creek
  7. Jan 26, 2012 at 8:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. Jan 26, 2012 at 9:11 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    A very poor setup, i'm sorry to say. You really need to get rid of that and get an upper control arm back in there, along with other factory components. Basically I would recommend starting over on the suspension.
