i have no reverse lights.....help
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaDude01, Jul 4, 2010.
  1. Jul 4, 2010 at 10:13 AM
    YotaDude01
    YotaDude01 [OP] Kentucky Boy
    KY
    01' TRD off-road
    I just recently noticed that when I back up I don't have any reverse lights. I took the bulbs put and checked them. There good. Does anyone think its the reverse light switch? And does anyone know where its located at? Or does anyone know somethings else that could cause it. Thank you all.
  2. Jul 4, 2010 at 2:25 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    did ya check your fuses?
  3. Jul 4, 2010 at 2:27 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    x2
  4. Jul 4, 2010 at 9:51 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Also does your truck have trailer wiring? I know reverse lights usually are untouched in those setups but I've seen some weird shit caused by bad trailer wiring.
  5. Jul 4, 2010 at 10:12 PM
    YotaDude01
    KY
    01' TRD off-road
    I couldn't find a reverse light fuse. Yeah it has trailor wiring but all my other lights work.
  6. Jul 4, 2010 at 10:17 PM
    MowTaco
    Kansas
    Mine shorted out earlier this year and it had the marker lamps in the front turn on with the brakes... If nothing else works might wanna try there
  7. Jul 5, 2010 at 6:36 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    03 DCSB
    magnaflow cat back exhaust, K&N filter, gray wire, deck plate, ome 883's, ome dakar leafs, bilstien 5100's, blacked out grille, AVS bug shield & window vents, arb bull bar, hella 5in lights, mile marker 8k winch, debadged tailgate, energy steering rack bushings, custom rear bumper w/ hidden receiver, custom headache rack, ome greasable shackles, 4.88's w/solid spacer, SS extended brake line
    check your reverse light switch its either on the shifter or the trans linkage
  8. Jul 5, 2010 at 9:27 AM
    BajaTaco96
    BajaTaco96 Well-Known Member
    Silver Springs, FL
    1996 Toyota Tacoma 4wd, 3" suspension lift
    K&N, ToyTec 3" front spacers, 3" Fabtech AAL's, Flowmaster exhuast, no cat, Exedy Stage 2 clutch
    My buddy had a similar problem on his '01, turned out to be a shorted socket where the bulb plugged in. Just one side kept both sides from working on his truck, I just took a multimeter to it to see if they were getting power at all. One side did, the other didn't. Replaced the connector and voila! T'was fixed.
    But reverse light switch is never a bad place to start, it pays to have a multimeter on newer vehicles. :D
  9. Jul 5, 2010 at 8:04 PM
    YotaDude01
    KY
    01' TRD off-road
    Yeah. Ill start by checking the switch. I can't see where it has changed anything else on the truck. Like lights or anything. Everything still works besides the reverse lights. The truck does have a short throw shifter in it so I'm not sure if that has anything to do with it or not.but thanks for your alls help. Does anyone know how much a new switch is.
  10. Jul 5, 2010 at 11:06 PM
    BajaTaco96
    Silver Springs, FL
    $27.12 from the theautopartshop.com
    From advance or autozone it's around $35, checked on the computer at work for you. =]
    Better part from TAPS btw, and that's coming from a parts pro at Advance. :D
    Comes down to patience though.
  11. Jul 6, 2010 at 4:34 AM
    YotaDude01
    KY
    01' TRD off-road
    thanks man.
  12. Jul 6, 2010 at 7:50 AM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    my friends evo 8 did that too, turned out to be a sensor on his transmission that caused his lights not to come on. hope you have a just a bad switch or relay
  13. Nov 29, 2015 at 1:08 PM
    scratchy
    scratchy New Member
    1996 4x4 Tacoma
    Hello All,
    This is my first time post to this forum and I am experiencing the same problem as was described in this thread. I found the problem, a wire pulled free from the back up wire plug that is just left of the transmission. Is it possible to get to the other end of the cable through the hole where the manual shifter is located via the interior cabin to either replace or repair this cable?
  14. Nov 29, 2015 at 1:45 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    I just checked in my FSM (for '99 Tacomas), and there is a relay just for the backup lites. It appears to be near the dash fuse box. Yours is likely similar.
  15. Nov 29, 2015 at 1:51 PM
    scratchy
    scratchy New Member
    1996 4x4 Tacoma
    Thanks Tan4x4 for the reply. Once I replace the damage wire, and if the problem with the back up lights continues, then I'll look at the relay.
    My initial question was enquiring about the accessibility through the shifter console to the other end of the wiring on top of the transmission.
  16. Nov 29, 2015 at 2:07 PM
    tan4x4
    Rick
    Folsom, CA
    What makes you think that wire ends up near the shifter? It likely either goes to either the fuse or to the lights themselves.
    BTW, on closer look at the wiring diagram, that relay is only there for column-shift automatics.
  17. Nov 29, 2015 at 2:51 PM
    scratchy
    scratchy New Member
    1996 4x4 Tacoma
    I was under my truck this morning, had the one end in my hand and I noticed the the one of two wire leads pulled from the plug. I then followed the cable along the top of the transmission with my hand and notice that it stops a foot down and it is plugged into the transmission.
    It's not a question if this wire is at fault. I've already determined that it is. I just want know if anyone has gone through the shifter to get at their own if they have in fact experienced a similar issue.
