I have some Questions please help! and be nice. lol..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WillDaBeast84taco, May 7, 2020.
  1. May 7, 2020 at 9:59 AM
    WillDaBeast84taco
    WillDaBeast84taco [OP] Well-Known Member
    William
    2013 Tacoma V6 4.0
    all stock so far, but looking to get some part soon. I want to add boost
    I have a 2013 four-door to come up with the V6 4.0..
    QUESTIONS LIST!
    #1. I live in Arizona and I would like to swap out my air conditioner with something with more power!
    what would I need to do I was thinking about using a tundra AC compressor? what do you think can anybody give me some suggestions on how I can get my AC to blow some super cold air without turning it on high every time thanks!
    #2. I'm going to do a wide body body kit but I'm going to lower my truck a little bit.
    is there any kind of long arm suspension that I could get that doesn't require a lift?
    should I get adjustable or tundra arms? please help thank you.
    #3. I would like to go all wheel drive not 4x4! is there any modifications I could do to possibly make this happen? could I buy an all wheel drive kit from another vehicle and customize and fabricate something to make it work on a Tacoma?
    has anybody done this or does anybody have any ideas on how this could work or what work at all?
    #4.I can't find many helpful information on the internet but I would like to relocate my battery and my computer to the back or in cab
    I need to make room in my hood for other things
    I would like to rewire my harness to clean it up I think it's a disgusting mess..
    I would like to lengthen some areas and hide as much wiring as I can would that affect any of the performance or anyting I would most definitely upgrade the gauges to a little bigger to guarantee flow of information.
    has anybody else done this or do you have anything to suggest thank you fam!
    b_r_o and Biscuits like this.
  2. May 7, 2020 at 10:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    1. Recharge it.
    2. https://www.urdusa.com/lowering-kits/ (You can't lower with a lift)
    3. No.
    4. The computer is already in the cab. You could put the battery in the bed possibly. Lengthening wires just adds more wire which is just more wire to hide. You could put it in a fancy wire loom instead of the stock black plastic.
    Twizted, MadDaddy, b_r_o and 6 others like this.
  3. May 7, 2020 at 10:15 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Use Max more
  4. May 7, 2020 at 10:17 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Change the cabin air filter
    Gunshot-6A, b_r_o, whatstcp and 2 others like this.
  5. May 7, 2020 at 10:19 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    no
    no
    no
    no
    lynyrd3, wilcam47 and TireFire like this.
  6. May 7, 2020 at 10:28 AM
    ljma90
    ljma90 Well-Known Member
    Jordan
    2007 Toyota Tacoma v6 4x4
    2.5 inch suspension lift front with rancho 9000 quick lift struts, rear rancho shock absorbers with 2.5 inch sky jackers add a leaf springs in rear. extra 2 inch long braided front brake lines with radiator flush, transmission flush, brand new front brake rotors, calipers, and shoes all done myself. more to come
  7. May 7, 2020 at 10:29 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    1. Pull down the headliner and insulate and also paint the exterior cab roof white.
    2. There is sketchy stuff you can do that I will not repeat here.
    3. Get a Honda Ridgeline.
    4. Yes, you can move the battery into the bed of the truck.
    lynyrd3 and BillsSR5 like this.
  8. May 7, 2020 at 10:30 AM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Lowered Sequoia?
  9. May 7, 2020 at 10:33 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    1) :facepalm:
    2) :facepalm:
    3) :facepalm:
    4) :facepalm:
    PoweredBySoy, lynyrd3, Hobbs and 4 others like this.
  10. May 7, 2020 at 10:35 AM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    It sounds like what you really want is a Tacoma X-runner. Unfortunately they don't make 4 door X-runners
  11. May 7, 2020 at 10:38 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You need to trade for something you like.
  12. May 7, 2020 at 10:45 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    1. Always drive in a northerly direction
    2. The Solara would be a better foundation for such a build, try and find a rag top.
    3 Do tracks instead the conventional ones not the type that mount to each axle.
    2. Relocate everything under the hood into the bed. MR-2coma.
    Gunshot-6A and SaltyCrew401 like this.
  13. May 7, 2020 at 11:09 AM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I agree that the a/c in the Tacoma is a bit weak but just MAX all day every day :D
    It also sounds like you may have purchased the wrong vehicle lol.
  14. May 7, 2020 at 11:40 AM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Is this for your 200mph taco you've been posting off and on about? Still waiting on the performance info you promised last month :popcorn:
    3)I think there's one guy that did an AWD swap, actually. Possibly with 4runner parts? Google is your friend.
    4)Longer very heavy gauge wires. A few have done that, too, again google is your friend.
    What are you trying to make room for?
    Gunshot-6A likes this.
  15. May 7, 2020 at 11:46 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
  16. May 7, 2020 at 11:52 AM
    rocky_mountain_dave
    David
    Or get a Silverado SS. Those have AWD, lowered from the factory, and a 6.0 small block V8.
    Skyway, 98tacoma27 and Island Cruiser like this.
  17. May 7, 2020 at 1:16 PM
    WillDaBeast84taco
    William
    2013 Tacoma V6 4.0
    thank you everyone for helping me out and yes I'm going to be posting my build pictures and possibly a few videos I'll send you the links on YouTube and thank you for all the positive feedback and for all of you that have doubt it just fuels the fire.
    I want to have a Tacoma nobody else has.
    it will be very customized mostly built not bought and I love my dick, but I would like it to be very unique.
    once it's done you will all see.
    eather a failed attempted or an amazing success!.
  18. May 7, 2020 at 1:20 PM
    WillDaBeast84taco
    William
    2013 Tacoma V6 4.0
    I also have about five grand worth of parts that I have already that I'm going to be installing and building soon I have about two crates full of a fiberglass and resin and a huge role of a specialized carbon fiber that is going to be the cherry on top!.
    again thank you all so very much for the feedback it's amazing to hear all of you coming together to help out someone with odd Questions..
    you guys will all be treated with my end result and when it's finalized I will show everyone and then I can pass on information when somebody else has the same kind of question and once I become more knowledged I can then help someone else in need..
    I just really appreciate it when everybody comes together what's positive feedback.
    I don't mind some of the negative stuff either it really does help out also sometimes people are right and sometimes I can take a step back and think about a few things if I should be doing something different so I will take everything and inconsideration and thank you again for everything..
    keep on truckin and more info please
  19. May 7, 2020 at 1:22 PM
    rocky_mountain_dave
    David
    Good luck. Count me as a skeptic but I would love to see you pull it off and create something unique
  20. May 7, 2020 at 1:24 PM
    tcjacado
    tcjacado Well-Known Member
    With enough time and money, anything can be done.
    98tacoma27 and Biscuits like this.
