I have the Icon add a leaf installed. How will my truck ride if I reinstall the leaf
Discussion in 'Suspension' started by Navar, Jun 22, 2014.
  1. Jun 22, 2014 at 9:54 PM
    Navar
    Navar [OP] Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    Question: I have the Icon add a leaf installed. How will my truck ride if I reinstall the leaf they took out? Sorry not sure what it is called.
    Trying to just get a bit more lift out of it. I can always turn up the front to level it.
    Thanks
  2. Jun 22, 2014 at 10:04 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Are you talking about the Overload spring the "Frowning" one all the way at the bottom, it's thicker than the others? It wouldn't ride much different. It's utilized when loaded heavy, hence the downward arc and the thickness.
  3. Jun 22, 2014 at 10:27 PM
    Navar
    Corona CA
    Yes the overload spring. Thanks
    So it sounds like you can install it and add a little to the lift.
    Again thanks
  4. Jun 22, 2014 at 10:30 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Adding the overload back in won't affect the ride. It will add about 1/2" lift and might add some driveline vibes also. I have the overload installed with my 3-leaf AAL.
  5. Jun 23, 2014 at 5:07 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Yep, it will raise you the thickness of the leaf.
  6. Jun 27, 2014 at 8:19 PM
    Deidara7117
    Deidara7117 Active Member
    Brandon
    Houston Texas
    A Tacoma
    ICON 3 leaf progressive AAL with Bilstein 5100 shocks and OME 885X coils
    will Bilstein 5100 Rear Shocks work with these add a leafs? or will i need the 5100 Extended Rear Shocks. I only have 3 leafs in my truck and also want to keep the Overload spring
  7. Jun 27, 2014 at 9:13 PM
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    OP how does your truck ride without the overload leaf with the mini pack compared to the factory ride?
