I Have to Sell My 1st Gen, 97, Base Cab 2RZFE, What to Ask?
Discussion in '1st Gen. Tacomas (1995-2004)' started by HairBear, Sep 13, 2017.
  1. Sep 13, 2017 at 1:41 PM
    HairBear
    HairBear [OP] Well-Known Member
    1997 2.4L Tacoma 2wd
    None
    These pictures are from when I bought it a year ago.
    165k miles. Auto Trans. Tires 6 mo. old. New injectors. New TPS and IAC Valve. Replaced rotor, cap, wires and plugs. Compression test = 167 to 175 lb. Pioneer stereo installed with Blue Tooth. Replaced fuel filter. Replaced brake pads and flushed system. Replaced Trans. fluid and filter. Replaced gear oil in differential. Added wheel covers. A/C and heat work fine. Also new headlight on driver's side. This thing runs like a scalded dog!
    Has rust on top of fender well and had a place where the frame rusted through; I patched it myself. Has small oil leak on valve cover near the distributor. Needs rear bumper.
    What should I ask for this thing?
    x
  2. Sep 13, 2017 at 2:54 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Id ask for a bag of lays
    eon_blue likes this.
  3. Sep 13, 2017 at 4:33 PM
    callmeammo
    callmeammo Well-Known Member
    Idk, but good luck. I'd be wary of buying a truck from somebody who put a lot of work into it and was selling so soon. I'd assume they encountered a problem was was too big.
    It looks like you got it for $1000. I'd say that, that you bought it to fix up and make a profit, list the things you've done and how well it drives, offer to take it to a mechanic if they want, then say how much you've spent on new parts and how much you want to profit.
    Or just ask $3-4k or whatever and park it somewhere.
  4. Sep 14, 2017 at 5:57 AM
    HairBear
    None
    It was my go to work truck, I invested in it, but I have to sell it; not because I want to. Thanks for the reply.
  5. Sep 14, 2017 at 9:18 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    where is the truck at?
    HairBear[OP] likes this.
  6. Sep 14, 2017 at 12:21 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    What ever the local market is.
    To high it will just sit .
    You can maybe have some wiggle room but know your rock bottom price you need to have
