i heard chattering in rear lsd
Discussion in 'Technical Chat' started by LazyRyan, Jan 29, 2009.
  1. Jan 29, 2009 at 9:57 PM
    LazyRyan
    LazyRyan [OP] Wtf am i suppose to type here?
    Long Beach,CA
    08 DblCab PreRunner V6 TRD Sport
    BHLM, Black badges, Trex Eyelids, AFE drop in
    ok so i did a couple of oil changes on my truck today.
    5.5 qts of castrol syntec
    new mobil 1 oil filter (m-209)
    new afe pro dry s drop in air filter
    and lastly a rear lsd oil change using castrol hypoy c (3 qts)80w90 w/ 7oz lsd additive.
    I did my round abouts (8 turns left n right) and everything and didnt hear any grinding or chatter however when i had to floor the gas pedal for a lil bit the lsd chattered for a few secs and stoped when i eased off the pedal. when i got off the freeway i floored again to see if it would do it again but good thing it didnt. should i add a half tube more of lsd additive on the safe side or just let it go?
  2. Jan 30, 2009 at 7:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should only use 4oz. of addative. Let it be for now and see what it does in a couple of weeks. If the chattering persists, you may need to drain and re fill with a diffferent oil.
  3. Jan 30, 2009 at 11:23 AM
    LazyRyan
    Long Beach,CA
    the bottle was a 7oz called tran x posi trac. the tube said pour the whole thing in. anyways, its been quiet since. i'll post if something goes up.
