I hit 100K this past weekend!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006TRDSPORT, Oct 10, 2013.
  1. Oct 12, 2013 at 4:23 PM
    hualampeter
    hualampeter Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
    You will know if they are bad once you start your engine. It will give you this overwhelming feeling like you should stop driving. Also, a check engine light will usually emerge.
  2. Oct 12, 2013 at 4:44 PM
    TRDtexasTaco
    TRDtexasTaco Well-Known Member
    JP
    Sunnyvale Trailer Park
    06 TRD PreRunner
    Billy shocks, Maxtrac spindels, AllPro standard leafs, BAMF shock relocation, King 2.5 smoothies
    well,glad to know I dont experience none of that!
  3. Oct 12, 2013 at 4:50 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    I hit a grand a few hours ago, so I'm 99,000 behind you!
  4. Oct 12, 2013 at 9:50 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Congrats on 100k. I had 126k when i sold my 2005 superwhite. Never had an issue with mine either. I did a coolant flush at 102,000 and had the tranny flushed at the dealer b4 that. Other than that, it was regular maintenance. These trucks last forever, especially if you maintain them properly.
  5. Oct 12, 2013 at 10:17 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Mine will be at 100k by the time it's due for its next oil change. Most likely before the end of the month.
    LOL! Biggest year I ever had was 45k in one year on my '03 Tundra.
    Bought it in October of '02 and traded it August '05 with 125k on it.
    I bought a '94 DLX in September '96 with 34k on it, traded it on the Tundra with 225k. That was an average of 27k per year.
    I bought my '08 in December '11 with 54k on it. I'll be over 100k by December this year, so I'm still averaging about the same, and I'm no longer using the truck for business!
    Que????? Bad coil just means you'll have a misfire. There's not enough liquid fuel to hydraulic the head, and think about it... a cylinder that does not fire has less pressure at TDC than a cylinder that is firing.
    2nd Gen has a separate coil for each cylinder. The engine will kinda' run on 2 coils.
  6. Oct 12, 2013 at 11:47 PM
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    Misfire lead me to my blown head gasket. I had no problems before.
  7. Oct 12, 2013 at 11:55 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Congrats, they'll keep going way longer then that if I didn't total my 05 tacoma with 151,000 mi Id still have it and probably have 230k on it. Im hoping to get a million miles out of my 13' and run it to the ground. Keep it up:burnrubber:
  8. Oct 13, 2013 at 12:14 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Or did the blown head gasket cause the misfire?
  9. Oct 13, 2013 at 11:27 AM
    2006TRDSPORT
    2006TRDSPORT [OP] 2006TRDSPORT
    Felton, Delaware
    2004 4Runner SR5 4WD
    TY, I was exited about hitting 100K & made SURE to get the photo, lol. I need to change the coolant myself although it checks good, but it's most likely due. Bought the truck at 62K, not sure if it's ever been done. I really want to flush the tranny as well although Toyota says it's sealed & don't need it, would feel better about it getting done regardless. I know that it's just the beginning of a long dependable journey. :D
  10. Oct 13, 2013 at 11:28 AM
    2006TRDSPORT
    Felton, Delaware
    It will be a great ride getting to 100K, I assure you!
  11. Oct 13, 2013 at 12:24 PM
    cool16v
    cool16v Member
    Dallas
    04 PreRunner SR5 2WD
    I just went past 100K a couple of weeks ago on my 2004 Tacoma. I new it was coming and wanted to capture the odometer reading too but it completely slipped my mind and caught it at 100,030 miles instead! DANG IT! I wanted to cry because I missed it.
  12. Oct 13, 2013 at 12:32 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Welcome aboard cool16v!! :)
  13. Oct 13, 2013 at 5:00 PM
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    I thought about that. However, cylinder #2 ignition coil went out twice after the rebuild.
  14. Oct 13, 2013 at 5:08 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Coincidence.
    Bad coil won't cause a blown head gasket.
    A problem in the ECU (or swapped wires) causing the coil to fire at the wrong time could cause enough cylinder pressure to blow the gasket, but that is very unlikely and wouldn't fix itself with a new coil.
  15. Oct 13, 2013 at 5:17 PM
    #35
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    I say your right on this one :)
  16. Oct 14, 2013 at 7:36 AM
    #36
    81shark
    81shark Well-Known Member
    another 6 months and i should be there.
  17. Oct 14, 2013 at 1:40 PM
    #37
    cool16v
    cool16v Member
    Dallas
    Thanks for the warm welcome! It took me 100K to get here but I'm here now!
  18. Oct 14, 2013 at 1:50 PM
    #38
    cool16v
    cool16v Member
    Dallas
    Wow, that was a long time ago! I miss my truck when it was just an infant too! Happy miles ahead for you! Enjoy!
