I hit a tree.
Discussion in '1st Gen. Tacomas (1995-2004)' started by TGurau, Jun 26, 2010.
  1. Jun 26, 2010 at 8:20 PM
    TGurau
    TGurau [OP] Well-Known Member
    Tibi
    Portland, OR
    '98 SR5 4x4
    3" OME Suspension lift. PEX motoring headlights.
    So, I was offroading in this place near my cousins house and we were going up this hill. There were ruts on either side of the path and right at the end of the ruts, it shot my truck to the right and i hit a tree. It was nuts. Like a dumbass, I wasn't wearing my seat belt so I hit my head on the windshield and cracked it (i'm fine). The front end is very surprisingly! NO DAMAGE! I hit my front end and slid my tire into it. My front right tire hit the tree harder than my bumper did. It kind drives funny now. I can't explain it, but now my steering wheel is off. Do you guys know what kind of possible problems I should look for? I love my truck and I really don't one broken thing breaking other things.
  2. Jun 26, 2010 at 8:22 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    damn that sucks. hopefully it just knocked your alignment off. good luck
  3. Jun 26, 2010 at 8:25 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Get an alignment & you should be OK.
    Count your blessings - could have been worse!:)
  4. Jun 26, 2010 at 8:26 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That does suck! Does it pull to one side when you let go of the steering wheel or when you apply the brakes?
    Got Pictures?
  5. Jun 26, 2010 at 8:29 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Bent wheel maybe? Does it drive straight or is the steering wheel just turned?
  6. Jun 26, 2010 at 8:31 PM
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    the steering wheel is turned when the wheels are straight. I actually went out to look at my truck and the right wheel is turned to the right when my left wheel is straight. I suspect a bent control arm. I'll post picks up tomorrow.
  7. Jun 26, 2010 at 8:46 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    It could be a couple things wrong with the suspension but I would get an alignment and the guy should tell you if anything is wrong. Glad you aren't hurt.
  8. Jun 27, 2010 at 1:21 AM
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    Thanks for your concerns guys. I'm going to get an alignment as soon as I can and hopefully, there won't be to much wrong.
  9. Jun 27, 2010 at 1:27 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Could be a bent spindle.
  10. Jun 27, 2010 at 1:32 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    x2. Probably bent that spindle. Look at it closely and Compare it to the other side. I know they are left and right different but the build is the same.
  11. Jun 27, 2010 at 2:38 AM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    ^^^ i must agree with the bent spindle/knuckle hypothesis.
    i did almost the same thing to my 09(hit a tree with the tire) and the knuckle had bent, ever so slightly, but enough to knock the steering out of alignment and made it drive funny.
    tip: with the tires pointed straight ahead see if they both look the same. the one i hit looked like it was leaning in a little on the top. it was very hard to see the bend until i put the bent one right next to the new one
  12. Jun 27, 2010 at 9:08 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    with mine when i hit a car head on my rack and pinion, tie rods, coil and shock spindle were all bent also check your front diff a hard impact to one side can jam your CV axle into the carrier bearing of the front diff (aka youd need a new front diff and CV's) thats what happened to mine
  13. Jun 27, 2010 at 9:24 AM
    C17Guy
    C17Guy Well-Known Member
    Dennis
    Charleston, SC/ Charlotte, NC
    09 SR5 Access Cab 5 Lugger
    Readylift Kit, 245/75/16, HID's, Debadged, Kenwood DNX9960 Double Din Navigation, Image Dynamics Door Components, Pioneer Amp, Dynomax Super Turbo Muffler, Grillcraft Uppers and Lowers
    glad to hear your ok, and best wishes with the truck. i'm with the others, try and alignment (fire stone has life time alignments for $149.00), that way after the work you can get it aligned again.
