I installed a transfer case skid and it's loud as hell
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lenny Dykstradamus, Mar 8, 2022.
  1. Mar 9, 2022 at 2:33 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    As an aside, here’s some new tech that flexes.
    https://m.youtube.com/watch?v=97t7Xj_iBv0
    Tacolife5[QUOTED] likes this.
  2. Mar 9, 2022 at 2:52 PM
    Tacolife5
    Tacolife5 Well-Known Member
    Durango, Colorado
    2017 TRD Off Road DCLB
    I agree that excess flex isn't good. But on dirt bike's chassis is just as important as suspension. Different motor mount materials, triple clamps, titanium vs aluminum axles, steel vs aluminum frame's, and beefing up certain parts of frames while leaving other parts thinner for more flex determine the ride characteristics, including traction all come from the chassis more than one would think. I have hours of experience with different setups and it's quite fascinating how they can change the ride. Having a frame like a KTM that's made of steel vs aluminum, absorbs bumps better so you can run a stiffer suspension setup to charge into rough terrain harder without sacrificing a smooth ride.
    Now I'm not saying that the skid is causing the Tacoma to drive weird or be much more rigid that a normal person would notice this at all while driving. The new Tundra is a fully boxed frame, which is much more rigid. To combat having to rigid of a ride, they implemented the new coil rear suspension which is much more supple and smoother of a ride than traditional leaf packs. If they put the traditinal leaf pack on the boxed frame, the ride would be much more rigid and passengers would feel every bump in the road.
  3. Mar 9, 2022 at 2:56 PM
    gudujarlson
    Minnesota
    You just repeated the common myth. Show me some evidence that the amount of frame flex is comparable to the range of motion of a dirt bike suspension.
    Frame flex is undesirable for many reasons. It changes the alignment of vehicle, puts stress on the various moving parts, etc. It’s also undamped, thus prone to causing “springiness”.
  4. Mar 9, 2022 at 3:06 PM
    gudujarlson
    Minnesota
    If you have ever ridden a dirt bike with a bent frame, you might understand more intuitively why frame flex is a bad thing. The frame is there to keep all those moving parts in alignment.
  5. Mar 9, 2022 at 6:28 PM
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
    Not buying it, that just makes no sense unless you have an exhaust leak right around where the transfer case skid is? Whether there is a skid plate there or not that does not affect exhaust flow or change the sound if there are no leaks. Any dampening from bolting up to the frame would also be negligible as the exhaust doesn't even touch the frame, only the rubber exhaust hangers which would negate the majority of vibrations anyway.
    What's more is you have people with the same skid plate stating they hear no noise further embellishing its likely a problem with your setup an not a wide spread problem from the skid plate itself. I've got RCI's an never noticed any changes in sound as you shouldn't.
  6. Mar 9, 2022 at 6:33 PM
    Lenny Dykstradamus
    Lenny Dykstradamus [OP] Well-Known Member
    Lenny
    New York City
    Tacoma Warthog
    Brother idc if you dont buy it, im not selling lol. Theres always a contrarian coming in threads with a whole lot of gib. Im guilty some times.
    A giant steel plate “could” reflect sound and create a resonant sort of chamber. This one is loud. SCIeNCE! Gonna get a video up ASAP for the truther type.
  7. Mar 9, 2022 at 6:37 PM
    dezert.taco
    Nate
    Northern Nevada
    2018 Tacoma
    :brianr:
  8. Mar 9, 2022 at 6:38 PM
    Lenny Dykstradamus
    Lenny
    New York City
    Tacoma Warthog
    :benchpress: Allday
  9. Mar 9, 2022 at 6:51 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  10. Mar 9, 2022 at 7:00 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    :lalala:Scientists require a before and after video, driving the same speed, down the same stretch of road, using a decibel meter for comparison, plus, another bone stock Tacoma as control, witnessed by a 3rd party with no affiliation. SCIeNCE! :redxfall:
  11. Mar 9, 2022 at 7:12 PM
    Lenny Dykstradamus
    Lenny
    New York City
    Tacoma Warthog
    FAIL
    RyanDCLB[QUOTED] likes this.
  12. Mar 10, 2022 at 4:00 AM
    Propsoto
    Propsoto Active Member
    2022 TRD OR DCSB Midnight Black Metallic
    When I added a skid plate to my motorcycle it did the same thing. Next I added Dynamat to the inside of skid plate, problem solved.
  13. Mar 10, 2022 at 9:24 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Out of curiosity, have you tried removing it and checked the sound level? If you have an iPhone there’s an app for a dB meter call Decibel X that works pretty good.
  14. Mar 10, 2022 at 9:29 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    used to race downhill mountain bikes before i got sick. man, i miss that. lots of the guys i raced with raced dirt bikes too.
  15. Mar 10, 2022 at 9:59 AM
    #35
    Lenny Dykstradamus
    Lenny
    New York City
    Tacoma Warthog
    Yep I used Audio Tools ios and its 6db louder installed, but because its mainly only at 2-3k rpm and using an ipad its not that reliable.
    Not overly concerned with sound level as much as the audible pitch. Gonna make a video later tonight.
    Thanks for the info.
    Captqc[QUOTED] likes this.
  16. Mar 10, 2022 at 10:35 AM
    #36
    Captqc
    Tigard, OR
    I’m a sound tech at my church and I know that 6 dB can be significant depending on what the sound source is. Good luck figuring this out.
  17. Mar 10, 2022 at 1:07 PM
    #37
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    So you got a skid plate and got free braaaaps? Sounds like a bonus to me.
  18. Mar 20, 2022 at 2:44 AM
    #38
    ethandoubleu
    ethandoubleu Member
    Denver
    2015 Tacoma SR5 4.0
    I just installed my Pelfreybilt transfer skid 3/19/2022 which is thick as hell and we checked for exhaust clearance which looked perfect. First thing I noticed was a low sounding droning noise at low speed and rpm so I think you're onto something with the resonance chamber effect. I think some do and some don't, cause the noise. Whatever, I'll just have to listen to louder music ‍♂️
  19. Mar 20, 2022 at 6:08 AM
    #39
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    Get some silicone grill mats and RTV them to the top of the skid plate. It will kill the resonance.
  20. Mar 20, 2022 at 7:14 AM
    #40
    BobbyTacoTRD
    BobbyTacoTRD Skewps Ahoy!
    2021 TRD Off Road
    Just here to throw out the old adage: "you can have two Tacomas, with exactly the same set up, and have two entirely different results."
    Now consider that these two Tacomas likely have different wheels, tires, lift, no-lift, other aftermarket add-ons, one driver is fat the other is skinny...etc. and it's even more reasonable that the results seen from a singular like part install might be different.
    Just sayin.
