I just bought 285/75/17 toyo m/t and it rub
Discussion in 'Wheels & Tires' started by Tikka T3, May 1, 2009.
  1. May 1, 2009 at 2:57 PM
    Tikka T3
    Tikka T3 [OP] Member
    New-brunswick cnd
    05 Tacoma sport edition
    4inch REVTEK LEVELING KIT
    I just bought myself some wheels and tire ,i started to place them but soon found out i was rubbing badly against the front part of the fender and also the back part of the fender.so i think i bought too big off a tire !! ive got a 3inch lift and dick cepek wheels on my truck ! what would be a perfect fit for my truck without too much trimming !!! wheels are 17 inch also !!I need somebodys help soon !!!
  2. May 1, 2009 at 4:51 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Mine are 285-70-17. I hardly rub at all and I'm running the Baja MTZ claw on a 17x9 moto metal 955.
  3. May 1, 2009 at 5:06 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Your gonna have to trim the front black piece, I think its the splash guard, and the back part of the fender with a 3" lift. Everyone has to trim. I trimmed a lot and still have to trim more. lol. Good luck.
    285/70/17
  4. May 1, 2009 at 5:14 PM
    Rustyrooster
    Rustyrooster Well-Known Member
    Decatur Tennessee
    O9 Tacoma TRD Sport Black Sand Pearl
    TRD High Performance Exhaust, Satoshi Grille, 3 inch Revtec Lift, Pioneer avh-4100dvd,Retrax bed cover
    I did the same thing 285/70/17 rubbed bad, also rode like a log waqgon. I went to a 265/70/17 much better and still looks good with 3 inch lift
  5. May 1, 2009 at 6:06 PM
    jrobson
    Mobile, Alabama
    09 DC 4x4
    I guess it really depends on which "3 inch lift" you got. I went with the Ultimate kit from toytec and barely rubbed with them at the stock setting. Others that just buy spacers seem to rub pretty bad.
  6. May 1, 2009 at 6:49 PM
    Tikka T3
    New-brunswick cnd
    thanx , i have a 3 inch revtek kit and im trying to run some dick cepeck rims 17 inch . and when a i mounted on my truck it seem like it would tear my fender away . so i cut that black squarre in front of my bumper and it was still rubbing big time !! but maybe i can return my tire for smaller that be lot better ! right !! am i gonna have the same look if i go with 265/75/17 so what else should i trim !!
  7. May 1, 2009 at 7:05 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    We can't really tell you what to trim. You gotta get out and look at the truck at full lock left and right, fully stuff tires, and any other positions that you hear rubbing in, figure out what is touching and how far it needs to be trimmed back...
    There is no one single answer or trimming "pattern" to follow to fix it...
  8. May 1, 2009 at 7:16 PM
    Tikka T3
    New-brunswick cnd
    ok so from what i see is that i should go with a 275/70/17 or 265/70/17, and for the rubbing probably every tire gonna rub differentalso i suppose depending the treads . im putting some toyo M/T . thanx anyways guys
  9. May 1, 2009 at 7:27 PM
    AZsand
    AZsand Well-Known Member
    You need to trim no matter what, but your 75 tire profile is a little to big for a 3"lift and if you are running a negative offset it's even worse, you might rub on metal in the rear of the fenderwell. You could:
    -get smaller tires
    -if you have negative offset wheels get ones that are max. 0 offset (positive might be needed)
    -get a slight body lift.
  10. May 1, 2009 at 7:30 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Your 285/75/17's are actually 34's, not 33's. Thats why you're having the issues most likely. I'd recommend 275/70/17's for little to no rub with the 3" lift, 285/70/17s with a little bit of trimming.
  11. May 1, 2009 at 7:45 PM
    Tikka T3
    New-brunswick cnd
    so would 33 inch tire from toyo M/T passe on my truck with a 3 inch lift. im running now toyo a/t 265/75/16 thats equal what rughouly 31 inch tire !!
