I just bought a 1990 Toyota pickup, any ideas on upgrades
Discussion in 'Toyota Trucks & SUVs' started by ZT_Richtofen, May 15, 2015.
  1. May 15, 2015 at 9:36 AM
    ZT_Richtofen
    ZT_Richtofen [OP] Member
    Robbie
    Gerrardstown WV
    1990 Toyota Pickup
    Toyota
    So i just bought a 1990 Toyota pick, it already has a 6 inch left on it and 35in tires, i just order bucket seats for it because the bench seat is tore up, im looking to put a new front bumber on it with a winch and i want to know if anyone knows of a good one to buy that will look sweet, and im also looking to take the bed off and make it just for rock crawling.
  2. May 15, 2015 at 9:39 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    if its the bulletproof 4 cyl 22re then you could get lots of upgrade parts like cams and headers ect or even turbo it depending on your state laws.
    If its the 3.0 V6... swap that engine for a newer Tacoma 3.4 V6 from the 96-04 years.
    35 inch tires.. that thing must be a dog.. and you need 5.29 gears to be new stock power ish.. also look into brake upgrades.
  3. May 15, 2015 at 10:44 AM
    ZT_Richtofen
    Robbie
    Gerrardstown WV
    1990 Toyota Pickup
    Toyota
    yes the engine is the 4 cyl 22r, a turbo would be pretty awesome and help with the power, and it definitely needs new gears, and for brakes are you talking about just the front brakes or should i put disc brakes in the back to?
  4. May 15, 2015 at 10:46 AM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    just the front as they do 80% of the work it seems. Look into a big brake kit conversion or just steel lines, high quality pads and rotors. the larger wheels need bigger and better brakes to be as efficient as stock.
  5. May 15, 2015 at 11:43 AM
    ZT_Richtofen
    Robbie
    Gerrardstown WV
    1990 Toyota Pickup
    Toyota
    ok will do, the truck seems to be a beast so far, i haven't come a cross anything that can stop me yet so it should be alot of fun to mess around with
  6. Jul 2, 2015 at 1:51 AM
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    22r or 22re? either way turbo propane is an easy route that runs good.
    4.88 gears are my preffered I ran them with 35's for a long time.
    I have 5.29s now. Bought them as 4.88 and they turned out to be 5.29 :/
    Disk brakes on the back can be a headache. If your still IFS fix that first and go SFA. I like Marlins front bumper.
  7. Jul 2, 2015 at 1:52 AM
    Konvict KROG
    Louisiana
    for brake upgrades get some v6 calipers, and new rotors. OR get v6 calipers and landcruiser rotors and stick them on an 85 front.. even better :)
  8. Jul 23, 2015 at 3:30 AM
    VW fanboy
    VW fanboy Active Member
    Brandon
    Wausau, Wisconsin
    1994 toyota pickup 4wd DLX extended cab and 2012 VW Passat TDI SE
    Going to be doing a TDI swaperoo
    call me crazy.. but go down the rabbit hole that i am going to embark on
  9. Jul 23, 2015 at 3:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    Can't quite understand why bigger brakes are needed on a rock crawling type vehicle.
    Other than the 'more bling' crowd (slotted, cross drilled, fill my fancy wheels) the general rule for bigger brakes in the performance car world is when the current brakes overheat and begin to fade. Often the case when folks take their street built sports cars to HPDE events and 1) they don't know how to drive yet (which is why they are there) 2) they have not upgraded the pads/fluid on the OE brakes 3) or the car actually is capable of out performing the brakes due to robust power upgrades. Even Spec Miatas running in fender to fender track racing run stock sized brakes...........
    The second case I've seen for bigger brakes is to increase safety with towing capacity upgrades on an older vehicle.
    So why does an underpowered, deeply geared, (thereby slow moving) vehicle like this need 'bigger brakes'? I understand well maintained, better pads, good fluid, etc., but bigger? Other than the case of direct fit from junkyard parts, big brakes are pricey.
    I'm not so much arguing the point as wanting to understand the value. What am I missing?
  10. Jul 23, 2015 at 3:53 AM
    Kotayota
    Kotayota Well-Known Member
    Sean
    Charleston, SC
    04 White DC
    Bilstein/Eibach combo, 1.5 rear shackles, 33/12.5/15 Duratracs wrapped around MT Classic IIIs, flowmaster 40, K&N intake, 4way pioneer speakers, mini d2s headlight retrofit, satoshi grill, interior leds
    Wanna buy a flowmaster high flow cat?? I got one
  11. Jul 23, 2015 at 1:17 PM
    VW fanboy
    Brandon
    Wausau, Wisconsin
    do what im going to be doing for my truck
  12. Sep 23, 2015 at 6:11 PM
    Mfreund1
    Mfreund1 Well-Known Member
    Eastern Ia
    2007 SR5 Sport
    The bigger tires weigh much more so the brakes are less likely to be able to stop without brake fade.
    If you need a reason, imagine it would be your family in front of your truck and need a panic stop.....because it is someone's family. I know my family is worth it. May seem dramatic but with all the lawyers it makes sense for your personal, financial well being.
  13. Sep 24, 2015 at 12:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    OP states he's building 'just for rock crawling'
    My question was 'Can't quite understand why bigger brakes are needed on a rock crawling type vehicle'
    I don't think my family will be in front of one of those. I mean I'm taking his comment literally (not a road vehicle) and my question is for that, not a road vehicle.
    Is 'fade' really an issue in rock crawling? (assuming a well maintained system). It seems to be a fairly slow moving and controlled process.
  14. Sep 25, 2015 at 8:16 AM
    Mfreund1
    Eastern Ia
    2007 SR5 Sport
    Sorry, I missed the part where he said he was only going to trailer it. If he drives it on the street he needs to prepare for the worst that can happen or the lawyers will own all his stuff and everything he earns in the future.
  15. Sep 25, 2015 at 8:25 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    OP be careful with the sunroof... I shattered mine wheeling and it was not a fun adventure :censored: if you take it out you can easily cut plexi glass or lexan and use a 100% silicone so there is no worry there.
  16. Sep 27, 2015 at 9:47 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Cheap upgrade, swap out the POS sealed beam headlights for an H4 conversion E-code replacement. Huge improvement. There are a few brands but in my experience the few extra dollars for the Hellas was well worth it in fit and finish. E-codes (euro spec) put far more light on the road and less in the air to illuminate overhead signs than the DOT lights, meaning for a given input the E-codes will appear far more powerful in light output.
