I just Called 4Wheel Parts and found out that 17" wheels work best for a 3" lift.
Discussion in 'Wheels & Tires' started by motomonkey, Jan 6, 2010.
  1. Jan 6, 2010 at 12:57 PM
    motomonkey
    motomonkey [OP] Been Around for a Bit
    The Glorious 661
    2015 White TRD Offroad
    Fox 2.0 coilovers, Method Roost Wheels, Falken WildPeak 285/70 r17, Cab chop, copious trimming in the fender region, really cool TRD shift knob.
    I don't mind going bigger, but I'm getting conflicting info from different sources. Ideally, I only want to put a 16" wheel with about 4.25 backspacing. I'm working with a 3" spacer lift on the front. What do you guys think?
  2. Jan 6, 2010 at 12:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think the first mistake was asking 4wheel parts.
  3. Jan 6, 2010 at 1:02 PM
    motomonkey
    The Glorious 661
    I was starting to think that as I hung up the phone. I figured I'd turn to you guys for some direction.
  4. Jan 6, 2010 at 1:04 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i'm running 16's on my 3" lift....4WP is full of shit. nothing changes on a 3" lift that would cause you to need to increase rim size. some 16s rub the calipers, but that has nothing to do w/ a lift...its the rim itself
  5. Jan 6, 2010 at 1:07 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    rim size wont really matter, its the TIRE size
  6. Jan 6, 2010 at 1:08 PM
    The_Hodge
    SC
    some 16s wont fit....but its trial and error and few - far between
  7. Jan 6, 2010 at 1:14 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    oh ok, did not know that
  8. Jan 6, 2010 at 3:45 PM
    Trowber24
    Trowber24 Marquette Fence Masher...
    Andy
    Marquette, MI
    07 Tacoma 4wd
    3" Toytec lift, 286/75/R16 BFGoodrich Mud Terrains
    I asked around the same question...I didn't much of a clear answer so I ended up ordering the Wheeler's Offroad Custom Tacoma Black Steel Wheels with 4" backspacing....At least this way I KNOW they will fit :)
  9. Jan 6, 2010 at 4:32 PM
    The_Hodge
    SC
    wheelers claims that their 16" alloys wot fit the 2nd gens...but they fit mine. only about a cunthair away from the caliper, but none the less
  10. Jan 6, 2010 at 4:36 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    4wheelparts is just trying to cover themselves in case you buy a 16" from them and then they dont fit. the 2nd gen tacomas have a little larger of a brake caliper which causes some 16" rims to rub. one advantage to running a 16" is that tire prices are much better.(once you add the price of all 4 together you wind up saving maybe 1-200 which in my mind is good). so if you see some 16s you like find a place that has em and will let you test fit em to check for clearance.
  11. Jan 6, 2010 at 4:46 PM
    bdwsrjoe
    bdwsrjoe Well-Known Member
    Joe
    Rio Hondo, TX
    08 Tacoma Double Cab TRD Offroad 4X4
    K&N Cold Air Intake, Magnaflow Catback Exhaust, 3" ToyTec Lift Kit, JVC InDash DVD Player with Backup Camera, 2 10" JL Audio Subs, 8K HID Headlights, 8K HID Foglights, N-Fab Nerf Steps, In-Channel Ventvisors, springfield xd40v10, mossberg 500 12ga.
    I'm running a 3 inch spacer lift from Toyteclifts with 16's and i haven't ran across any problems. From my understaning a 6 inch suspension lift would require bigger wheels.
  12. Jan 6, 2010 at 5:51 PM
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    I think the second mistake was using spacers for 3"
  13. Jan 6, 2010 at 6:17 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    17" wheels rub too. TRUST ME, mine did... that's why I'm running 5mm spacers.
  14. Jan 6, 2010 at 8:11 PM
    Trowber24
    Andy
    Marquette, MI
    07 Tacoma 4wd
    Wow I'm suprised wheeler's told you they wouldnt fit...I specifically asked if their steel wheels would fit and they guaranteed they would fit...thats the only reason I bought them...otherwise I would have taken a chance on a much better looking wheel :)
  15. Jan 7, 2010 at 7:19 AM
    spearhead
    spearhead Taco Supremist
    Winston Salem NC
    09 4DR Mag Grey 4WD Sport
    TRD CAI Eibach Springs 5100s all around Front set to .85 Toytec AAL
    Don't be
    I consider them the McDonalds of lift shops.
    Even if they don't completely screw you, you still know you could of done better immediately after having any interaction with them.
    I had on 05 pre-runner that I couldn't get the dealer to do the rear TSB on, so I had 4WP put on an AALs and some Billys and they totally treated me like the mall crawler dude lifting his non American made, non 4WD truck.
    They screwed up 2 times and then tried to over charge me...
    I'll be renting a spring compressor when I do my '09
  16. Jan 7, 2010 at 7:34 AM
    cotruckin
    cotruckin Well-Known Member
    Westminster, CO.
    Lifted 06 TRD Sport
    Bilstein 5100 Lift with rear 1" blocks, ARE Z series topper with Yakima rack and Rola basket, some audio equipment, some more goodies
    I previously ran the Revtek lift and now the Bilstein lift with 16 with no problems. First I had the AR-767's and they rubbed, with my new wheels they dont.
  17. Jan 7, 2010 at 8:09 AM
    The_Hodge
    SC
    if u check their site, the alloys arent listed for the 05+ only the 95-04
  18. Jan 7, 2010 at 8:56 AM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    I know nothing about lifts.
    So what happens when lifted that requires you to use a larger wheel diameter?
    I can understand having to monkey with control arms, brake lines, etc.., but not the wheels. Except for looks.
    TIA
  19. Jan 7, 2010 at 9:17 AM
    Trowber24
    Andy
    Marquette, MI
    07 Tacoma 4wd
    OK, my fault, I thought we were talking about the steelies...
  20. Jan 7, 2010 at 10:10 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    FYI
    Wheeler's Offroad is NOT 4 Wheel Parts.
    Two different companies.
    The rim size matters in regard to caliper clearance. From there, it's a matter of backspacing to avoid having the rubber wheel make contact with the UCA, etc.
