I just can't decide...
Discussion in 'Suspension' started by wolfdog2314, Oct 11, 2010.
  1. Oct 11, 2010 at 9:49 PM
    wolfdog2314
    wolfdog2314 [OP] Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    Hey all, I have a 2011 trd sport 4x4.... And I can't figer out what to do.
    Originally I wanted to go for the best of the best with icons CO, TC ucas and a emu leaf pack. That puts me around the 2000$ mark.
    I'm not a hardcore 4x4er, this is a DD that gets me to work, the mountain to board and hunting roads.
    So I really don't think I need that nice of a set up.
    I'm thinking of going with the toytec ultimate lift with aal.
    I want to clear 285/70/17's.
    Wheels I'm looking at have 4.25BS.
    Will that setup work with setting the CO's at 2.5in? I don't want to worry about new UCAs and cv angles.
    I think this is all. Ahh
    Thank u all in advance!
  2. Oct 11, 2010 at 9:57 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    RCD drop bracket lift... retains stock suspension geometry and lifts 4.5 inches... no need to upgrade UCAs, flat cv angles
    costs $1799 from wheelersoffroad
    clear 285s easily... rides like stock
  3. Oct 11, 2010 at 9:59 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Zach
    Oregon
    Go with long travel suspension... Oh wait a min you said 2000.00 dollars... haha. Uhhhhh... I would get some Icon resi CO's with TC UCA's. As for the rear deaver's leaf spring kit with Icon resi shocks.
  4. Oct 11, 2010 at 10:04 PM
    wolfdog2314
    Brush Prairie
    Thanks for the quick responses...
    But I was trying to get away from the premium setup cause I won't be really using it to the full potential.
    Rcd, I don't have the confidence to do something like that lift, and would need a shop to install. Round here a DB lift goes for around 1000$ to install. CO's I can do myself.
    If I had coilovers set at 2.5in... Will it clear 285's? And how bad will cvs be at that point?
    Or should I really just fork it out for new ucas and set lift to 3in?
    Thanks all!
  5. Oct 11, 2010 at 10:08 PM
    memario1214
    memario1214 Vivid Illumination Moderator Vendor
    Colton
    Missoula, MT
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Solus, imma shoot you a PM tomo regarding the RCD. Few questions for you.
  6. Oct 11, 2010 at 10:10 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    anything over 2" will need new UCAs to get correct alignment... alignment will be marginal at best without new ucas.
    CV angles will be stressed with any suspension lift.... the higher the lift the more stress... our cv can handle increased angle with smaller lifts, but 2.5" will begin to push it.
    285s will require cutting/chopping/banging in the wheel well area to clear 285s
    since you won't offroad much... Light Racing ball joint UCAs would work just fine
    if you can do coilovers you can do DB lift... it will just take a helluva long time
  7. Oct 11, 2010 at 10:10 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    cool
  8. Oct 11, 2010 at 10:12 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    look up jrobson... he went from the toytec ULK to the RCD kit due to CV issues
  9. Oct 11, 2010 at 10:22 PM
    wolfdog2314
    Brush Prairie
    Thanx solus. Thanks for making me spend more money haha. It is only money I guess!
    I originally wanted the RCD lift when I first got my 2nd gen. I went from a 1st gen.
    One question about that lift, how's the ride with the blocks in the back?
    Thanks!
  10. Oct 11, 2010 at 10:23 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    its okay on the street but a little bouncy on bumps and offroad... I intend to upgrade the rear at some point but its not that big a deal for now
  11. Oct 12, 2010 at 9:24 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Ah yes, I went through the same thing.
    More isn't better.
    So many folks (including me) post pics on here of taco's clearing 285/70R17s and they look really badass. But clearing those tires means a more radical 3" lift with potential alignment, UCA, diff CV issues etc...
    For your intended use, consider simplifying.
    Bilstein 5100s all around set at 1.75 in the front and an Add-a-Leaf in the back, then run 275/70R17 BFG All-Terrain TA tires on 17x8 rims with 4.5" backspacing. You might have to remove front modflaps and cut a little plastic from the inner front wheelwells.
    Improved clearance, traction (both off-road and on paved icy/snowy roads) tire durability, and looks vs. stock. No alignment issues. No harsh ride. Done.
  12. Oct 12, 2010 at 9:55 AM
    wolfdog2314
    Brush Prairie
    Ahhhhhhh.
    Moose, your probably right. I'd love to go big, especially after looking around at all of the sweet trucks on here.
    And, if I wanted to after a few years I can upgrade. But for now and I'm purpose with the truck it's probably the best idea to go with what u just stated.
    I am kinda leaning upwards the dura tracs tho'!
    I'm looking at the wheelers site. 178$ for front. 158$ for the back 5100's. Then a 1.5in AAL for like 75$ and then I'm set yah?
    Thanks again for all your input!
  13. Oct 12, 2010 at 12:02 PM
    wolfdog2314
    Brush Prairie
    Thanks oswego,
    I think this will be the route I take.
    One last question...
    Could I set the bilsteins to 2.5 and run 285/70/17 with 4.25 bs wheel with little to no probs? If not, I'll probably stick with what moose suggested...
  14. Oct 12, 2010 at 12:08 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    More isn't better. Once you set those bilstiens up to 2.5 you start opening up the chances of all the issues that come with 3" lift. There's never any certainty you'll have problems. But you might, and you need to be mentally prepared to deal with them, including simply rougher ride. Many folks on this site who installed 5100s started with them at 2.5 then went down to 1.75 or even .85 to get a smoother ride.
    "The true secret to happiness is having low expectations, and your own bowl of potato chips" -Scott Adams.
  15. Oct 12, 2010 at 12:15 PM
    wolfdog2314
    Brush Prairie
    Well after a little more searching, and your last post... You've got my convinced, finally.
    Bilsteins at 1.75. AAL. And 265/70/17 duratracs. I think that'll do it! :-D thanks!
  16. Oct 12, 2010 at 12:23 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Post pics as you do the install, and of your truck when you're finished!
  17. Oct 12, 2010 at 12:32 PM
    wolfdog2314
    Brush Prairie
    Deffinitally. Thanks again to all
  18. Oct 15, 2010 at 7:40 AM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    2011 DC 4X4 TRD Sport
    RCD Lift, Custon Alcan Leafs, Ballistic Jesters, Duratracs 285/70/17,Fold-a-Cover Elite G4 Tonneau, Black Grill Emblem, Sock Monkey Yeti Decals, Tundra 4x4 emblem sprayed black, Debadged, LED interior, Xenon Depot 6000K HID Headlights, Xenon Depot 3000k Fogs with Lamin-X Coating, Borla Exhaust - Chopped, Weathertecs, Custom Katzkin Leather TRD Interior.
    I am going RCD. Install is set for 10/25/10. I want to keep as close to stock ride as possible and run 285's. I test drove a Tundra with a fabtech 6 inch lift and it was a bit stiff for my taste with the coilovers.
  19. Oct 15, 2010 at 9:27 AM
    wolfdog2314
    Brush Prairie
    Thanks for the pic. That's the setup I'm gonna go with. Bilsteins at 1.75. I think I'm gonna give wheelers a call today and order!
  20. Oct 15, 2010 at 9:55 AM
    wolfdog2314
    Brush Prairie
    I was thinking of just an AAL. Ive thought about the progressive tho', but don't like the idea of removing the overload. I don't haul a lot. But in the near future I'll have a quad. And boat...
