I just got CEL and P0500 error code, speedometer quit working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jboudreaux1965, Aug 14, 2018.
  1. Aug 14, 2018 at 7:09 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Howdy all,
    I got CEL and P0500 error code and speedometer quit working. Planning on changing the ABS sensors since I have on hand anyway, (ABS light always stays on, I nicked the ring on RR bearing on last bearing change, so ABS light being on doesn't offer any clues) any other sensors on trans or anything I should look at?
    Thanks!
  2. Aug 15, 2018 at 9:25 AM
    SeafireXV
    SeafireXV Well-Known Member
    Olathe, KS
    2006 Tacoma TRD Sport ACLB
    Check Fuse #31 under your coin drawer left of your steering column. That fuse causes all kinds of problems, including speedometer. It's a 10A microblade fuse, red in color.
    jboudreaux1965[OP] likes this.
  3. Aug 15, 2018 at 5:03 PM
    Ncskeeter
    Ncskeeter Well-Known Member
    North Carolina
    2005 Silver Tacoma Prerunner DCSB SR5
    Mostly stock
    If it’s not a fuse, the VSS signal isn’t making it to the cluster from the skid control computer. It’s either a wheel speed sensor, the skid control computer, or a broken wire in that path.
    Pulling ABS codes may help
    Assuming you have an auto, the speedo is driven from the ABS system, not a sensor on the tranny.
  4. Aug 15, 2018 at 9:50 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    No abs codes, before I changes abs sensors today, a couple times speedometer started working again for like a minute or 2, then stopped. After changing abs sensors same thing. Thinking maybe nicked a wire somewhere doing latest lift, but that was like 2 months ago. Guess I'll start tracing wires. Open to any ideas you guys have. Thanks!
  5. Aug 15, 2018 at 9:51 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    BTW, no VSS on mine.
  6. Aug 15, 2018 at 11:02 PM
    b_r_o
    b_r_o Beef jerky time
    Alex
    WA
    2015 DCLB
    Watch vehicle speed on a scan tool while driving. If the speedo stops working and you lose the vehicle speed on the scanner at the same time, suspect a sensor issue.
    If the speedo stops working and you still have a vehicle speed on the scanner, suspect a gauge/cluster issue
    BassAckwards and TomTwo like this.
  7. Aug 16, 2018 at 12:30 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Speedometer and scan drop off at same time.
  8. Aug 16, 2018 at 12:43 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Another odd thing, if I clear codes, clear CEL, then start driving when speedometer isn't working, sometimes CEL will come back on right away, sometimes take 5-10 minutes of driving before CEL comes on again. I tried driving steady slow, quick acceleration, fast then slow, etc doesn't seem to make a difference how quick I get CEL. When speedometer does work for a bit, it also random? Ive strictly used digital GPS speedometer since 2010, so the speedometer not working doesn't really affect my driving, more worried about how this could affect performance and any negative side effects to engine and trans. operation.
  9. Aug 16, 2018 at 6:17 PM
    Ncskeeter
    North Carolina
    Mostly stock
    My transmission's shifting seemed to be a little off when I had a P0500 code. Also, I can't pass inspection with the check engine light on so I had to fix mine.
    Since you have no ABS codes, it's probably the skid control computer, the cluster, or the wiring between the two. Unless you can find a broken wire, you really need access to an oscilloscope to troubleshoot this code...it's not going to be easy for DIY'ers.
  10. Aug 23, 2018 at 8:29 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Update... I changed ABS sensors like mentioned above, no change. I crawled underneth and checked all the wires and connections and loosened the relocate brackets for the wires we installed when doing the last lift, made sure there was plenty of slack, then tightened everything up. Cleared codes, no CEL and speedometer works now. Think I must have crimped or nicked a wire some where. Now just need to find where, for the time being, all good. Thanks for the help guys!
