i just got some new ar-15 magazines in and
Discussion in 'Guns & Hunting' started by meeestirg, Apr 23, 2011.
  1. Apr 23, 2011 at 2:01 PM
    meeestirg
    meeestirg [OP] Well-Known Member
    D15, CA
    i took them apart to check them out. the springs looks dry, is that normal? or should i take them all out and do a quick spray of WD-40?
    thanks
  2. Apr 23, 2011 at 6:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Its OK if they are dry.
  3. Apr 23, 2011 at 7:09 PM
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    What kind of magazines are they? If they are from Magpul then they are meant to be dry and used as such. WD-40 is absolutely the worst thing you could ever use. All of my duty and training mags I use dry and will dissamble and clean monthly depending on how offer they see the range.
  4. Apr 24, 2011 at 9:09 AM
    blendedfamily
    blendedfamily Well-Known Member
    'Burque(sucks)
    with all steel mags you can put a drop or two of oil on the spring and run it from the top to bottom with your fingertips. Like John said, if they're polymer, clean off the packing grease and leave 'em alone.
  5. Apr 24, 2011 at 9:13 AM
    JTaco386
    JTaco386 Well-Known Member
    JT
    Fort Rucker, AL/ Home: Port Orange, FL
    13 DCSB TRD Sport 4x4
    leave them as they are
  6. Apr 24, 2011 at 4:44 PM
    meeestirg
    D15, CA
  7. Apr 24, 2011 at 4:46 PM
    meeestirg
    D15, CA
    thank you, thank you!:):):)
  8. Apr 25, 2011 at 7:12 AM
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    Okay so with the D&H steel mags you can run a drop on the inside on the steel and wipe it around the inside with your finger. Don't even think about doing that with the Magpul one. Oh and do the steel ones have the anti-tilt follower? I'm assuming they don't. Go onto Magpul's website and order you some that way you don't have any feeding issues in the future. Then go out and give them hell.:D
  9. Apr 25, 2011 at 8:36 AM
    blendedfamily
    'Burque(sucks)
    John, is magpul paying you for this? :p
  10. Apr 27, 2011 at 6:05 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I do not EVER put a lubricant of any kind on a magazine spring. It will draw dust, dirt and other contaminants in the most critical part of the magazine.
  11. Apr 30, 2011 at 6:46 PM
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    Hahaha. Geeze I wish. I have a buddy at lance that hooked me up with some mags as well which are freakin great. Magpul have a great system for their mags and all their other accessory stuff is really well built and is sturdy for everything from a duty gun like mine and an everyday gun. I just like the setup and research what I use before getting anything.
  12. Apr 30, 2011 at 6:50 PM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Kyb Shocks... for now
  13. Apr 30, 2011 at 7:09 PM
    meeestirg
    D15, CA
  14. Apr 30, 2011 at 8:14 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
  15. Apr 30, 2011 at 8:43 PM
    meeestirg
    D15, CA
    yeah but they ship it to me as repair kits, so i dont assemble them until that rivet is in.
