I just ordered a 2021 TRD OR DCLB... I have some Questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SH7mi, Nov 18, 2020.
  1. Nov 18, 2020 at 5:35 PM
    SH7mi
    SH7mi [OP] Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    I just totaled my 08 Tacoma DCLB Sport and ordered a 2021 TRD OR. Questions....
    1) Does the 4x4 switch illuminate?
    2) Does the 3rd brake light also light the bed?
    3) Does the hood have lights underneath which illuminate the engine compartment when hood is lifted?
    4) Are the mud flaps flexible or stiff?
    5) Does the TRD OR come with remote start?
    6) How far does the steering wheel scope out?
    7) Can the cruise control assist be disabled?
    That's it for now but may think of more...
    71tattooguy and RobP62 like this.
  2. Nov 18, 2020 at 5:43 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Sorry to hear about your 08', hope no one was hurt. Your 21' is going to be damn near the same except for some minor differences here and there.
    Hey, if you're on a roller coaster there's ice cream later.
  3. Nov 18, 2020 at 5:48 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    Honolulu, Hawaii
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    1) I think so
    2) Yes
    3) No
    4) Stiff (OEM)
    5) Yes (May very through trim)
    6) about 3 inches
    7) I don't think so (mine can't - 2019)
  4. Nov 18, 2020 at 5:57 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    1. The switch itself? It lights up when your lights are on. Indicator light is on the dash
    2. Yes
    3. No.
    4. Oem are stiff.
    5. Yes. Press lock 3 times, and hold. Lights will flash and truck will start. Truck will shut off when door is opened.
    6. Pretty damned far. (6-8 inches). I've been comfortable in all of the ones I've driven (dealership employee, just ordered one), I'm 6 3 and i fit.
    7. Depends what assist you mean. Steering assist, yes, in the settings in the center screen between the tach and the speedo.
  5. Nov 18, 2020 at 5:59 PM
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    1) I would have to check on this. Haven’t really looked.
    2) Yes, but there’s also a bed light kit that’s an easy install and provides a lot of extra light.
    3) No
    4) Stiff
    5) Yes, I believe they have remote start via the key fob. If you get the remote services option it also allows remote start via the Toyota app.
    6) maybe a couple of inches or so. I haven’t adjusted it much, but don’t remember it being a lot.
    7) I think the dynamic cruise control can be disabled. I think you hold the cruise control button on the stalk for a few seconds to revert to traditional cruise control. It’s been awhile since I looked into that, so my memory is a bit fuzzy there.
  6. Nov 18, 2020 at 6:42 PM
    Jlab
    Jlab Well-Known Member
    Justin
    Utah
    2020 Cement TRD OR DCSB
    Doc62 and SH7mi[OP] like this.
  7. Nov 18, 2020 at 6:47 PM
    StayinStock
    StayinStock Pepsi > Coke
    Bob
    Missouri
    Yes I do
    Some
    You're #7 is correct (at least, it is on an '18)
    Taco1701[QUOTED] likes this.
  8. Nov 19, 2020 at 2:47 AM
    SH7mi
    Kevin
    West Grove, Pa.
    Thanks for responding. My 2008, many of these I added. The illuminated 4x4 switch; Under hood lights; Better Bed lights;
    The Mud flaps were stiff and removed themselves, which is why they ‘should’ be flexible/rubber;
    I never installed remote start but would welcome it; The steering wheel telescoped only 2” max; The cruise control assist is flat out dangerous!
  9. Nov 19, 2020 at 6:38 AM
    CliffyDeuce
    CliffyDeuce Well-Known Member
    DFW, TX
    2020 DCSB TRD OR MT
    Note on 5: only on auto transmission. No remote start on MT.
    7. On my 2020, you can disable the radar portion of the cruise control and revert it to an old-school “dumb” cruise control that just holds the speed you set.
    Some of the other points are why I told the dealer I didn’t want the mud guards (put on flexible Rek Gens myself) or the bed lights (save about $100 and install the OEM ones yourself in 10-15 minutes).
    SH7mi[OP] likes this.
  10. Nov 19, 2020 at 8:00 AM
    SH7mi
    Kevin
    West Grove, Pa.
    After 13 plus years, Toyota still doesn’t have manual transmission on the DCLB. The only configuration it’s not available.
  11. Nov 19, 2020 at 8:16 AM
    CliffyDeuce
    DFW, TX
    2020 DCSB TRD OR MT
    True, but I didn’t see that the new truck is a long bed, just TRD OR.
  12. Nov 19, 2020 at 8:23 AM
    SH7mi
    Kevin
    West Grove, Pa.
    Correct, I did not put that in description. Not in the thread title at least.
    I added ‘DCLB’ to title
    CliffyDeuce[QUOTED] likes this.
  13. Nov 19, 2020 at 12:42 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Order first, research later? Interesting plan!
    philth and Artjr like this.
  14. Nov 19, 2020 at 1:16 PM
    Shippe
    Shippe Well-Known Member
    Isaiah
    Idaho
    2020 MGM Tacoma TRD Off-Road / 2014 BW Corolla S
    1. Yes
    2. Yes
    3. No
    4. My 2020 didn’t come with mud flaps
    5. Yes
    6. Not far
    7. Not sure
  15. Nov 19, 2020 at 1:25 PM
    SH7mi
    Kevin
    West Grove, Pa.
    The answers to question 6 are wide range, from not far to 6-8”... What’s the actual distance of the telescoping steering wheel?
  16. Nov 19, 2020 at 3:10 PM
    Taco1701
    William
    GA
    I checked mine just now and it has about 2 inches or so of total movement forwards/backwards.
    Maybe the 6-8 inches was referring to the tilt. No way it’s telescoping that much though.
    SH7mi[QUOTED][OP] likes this.
  17. Nov 20, 2020 at 1:01 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  18. Nov 20, 2020 at 1:22 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    How is it dangerous? I use mine a lot and have zero danger.
    Dropping in 10' on a mtn bike is dangerous.
    Racing superbikes on the Isle of Man is dangerous.
    Wing suit flying between buildings in dangerous.
    Dynamic cruise control is not dangerous.
    DirtyDan, DamnHippie, fmb and 2 others like this.
  19. Nov 20, 2020 at 1:25 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    hiPSI likes this.
  20. Nov 20, 2020 at 3:38 PM
    SH7mi
    Kevin
    West Grove, Pa.
    Setting the cruise at 65 on a major highway, some other driver cuts me off, the car suddenly slams the brakes and the driver behind me almost rear ends me... quite dangerous.
    RobP62 likes this.
