I just reached 70K Miles...what should i do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dougmays, Aug 3, 2010.
  1. Aug 3, 2010 at 12:03 PM
    dougmays
    dougmays [OP] Well-Known Member
    Doug
    Gainesville, FL
    2007 SR5 Tacoma 4WD/Tow Pkg Black
    Westin Bull Bar, Firestone Destination AT 255/70/16
    What are standard maintenance things todo at 70K miles?
    - my brakes are original..thinking it might be time to replace?
    - Transmission fluid replace (haven't done this yet)?
    What else?
  2. Aug 3, 2010 at 12:44 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Just look in the manual and do the 60,000 scheduled maintence. You may not need brakes, just inspect them and see how they look.
  3. Aug 3, 2010 at 12:59 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    I assume you mean besides the normal maintenance items like lube u-joints, oil and filters and spark plugs?
    New transmission fluid is definitely good as well as differential oil.
    Some people would replace all belts and hoses about now.
    Even if you don't need brakes it's a really good idea to flush.
    Other'n that: drive it till something breaks. You could run yourself ragged doing lots of crazy things telling yourself you're 'pro-active', but ultimately being in tune with the noises and behaviour of your vehicle is a lot better, and cheaper, than trying to replace things when they don't need it.
  4. Aug 3, 2010 at 1:10 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Toyota changed the transmission fluid change to 60k btw.
    Otherwise just follow the manual's schedule and i should be fine, presuming you have to this point. If not... do everything that was missed. I'd also crawl under and check for surface rust spots and stuff to sand off and paint. Sometimes just crawling around under and looking at stuff is the best.
    As for the brakes... inspect the pads and wear. If it needs it, change them... if they're still good... they're still good. How long they last is dependent on driving style, not millage.
  5. Aug 3, 2010 at 1:19 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Wheel it. That's what I did when I hit 70k. :D
