I just replaced my original spark plugs on a 2010 4 banger Tacoma with 211,000 miles (pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TreeFortRichard, Feb 12, 2022.
  1. Feb 12, 2022 at 10:59 AM
    TreeFortRichard
    TreeFortRichard [OP] Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    So I’ve been a little lax in replacing the spark plugs in my Tacoma. You can see from my signature that I use Fuelly. My miles per gallon have dropped by for this winter down to low 16 mpg. I was suspicious from the fact that my truck was running horribly in the cold that it was either the mass airflow sensor for my spark plugs. Well today was finally 55°F so I pointed the hood to the sun and broke out the tools. I can’t believe how easy it is to do a spark plug swap on a four-cylinder. The old plugs came out creaking like a rusted door hinge. Slow and steady. I put a tiny amount of anti-seize on the new ones. Keep in mind the OEM gap on tacoma spark plug is supposed to be .043 these plugs measured upon removal greater than .07 but technically since there was no linear line between the iridium tip and the ground arm to spark to it sort of had to go at an angle. The great news was inside the coil packs everything was nice and clean. No oil no black no char. Just even wear on all of the spark plugs.
    I guess I’ll see you at 422,000.
    upload_2022-2-12_13-54-48.jpgupload_2022-2-12_13-54-49.jpgupload_2022-2-12_13-54-49.jpgupload_2022-2-12_13-54-49.jpg
  2. Feb 12, 2022 at 11:30 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    You might have set a TW record for miles on a set of plugs! One of your plug tips actually had a split it appears in the photo but maybe that’s just a shadow?
    Good write up, will be interested to see what kind of milage you get with the new plugs.
    I’ve done a little reading on plug replacement for the 2.7L out of interest though I’m only at 8700 miles lol. Doesn’t seem hard at all, just the intake removal.
    I suggest a change at 311,000 miles next time haha.
    TreeFortRichard[OP] likes this.
  3. Feb 12, 2022 at 2:01 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Those poor coil packs.
    Brazoshound, usmc2msu, Nevin and 3 others like this.
  4. Feb 12, 2022 at 3:47 PM
    TreeFortRichard
    Brian
    VERY easy to do...Especially now that I've done it. I budgeted 2hrs and was done inside 1hr...I think it's the first time i've had a DIY that EVERYTHING went how it was supposed to go...Hardest part is getting the air intake hoses shimmied back into proper place...
    Engine already sounds a million times better...Now I can hear ALL the exhaust noise ;)
    davidstacoma[QUOTED] likes this.
  5. Feb 12, 2022 at 3:51 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I did mine around 110K and same, about an hour or so. Not as bad as I expected.
  6. Feb 12, 2022 at 4:04 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Good to know, and nice write-up. I'll probably do mine in the spring, pushing 170k +. Still getting right around 20mpg give or take a little. Not a daily in winter months though.:thumbsup:
  7. Feb 12, 2022 at 4:07 PM
    TreeFortRichard
    Brian
    This guy is very helpful...
    https://www.youtube.com/watch?v=J8K7DVOfzAw
  8. Feb 12, 2022 at 4:17 PM
    That one old guy
    Chuck
    Stockish
  9. Feb 12, 2022 at 5:30 PM
    ABA180
    East Bridgewater MA
    That might have been the one I viewed as well, or if not it was damn close.
  10. Feb 12, 2022 at 5:34 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    Wait. How do you know these are originals?
  11. Feb 12, 2022 at 5:46 PM
    TreeFortRichard
    Brian
    I bought the truck 2 years old with 78K on it from the place where the original owner had it serviced (carfax). They had all the service records. The original owner was an obese man who smoked vanilla scented cigars and ashed in a cup between his legs...There are still burn holes in the seat and on hot summer days the smell of vanilla tobacco wafts the cabin...I digress...The Toyota dealer that sold me it gave me a full write up on what it was due for etc..It was a certified used...
    I have it on good authority that they were original when I bought it 130K ago...and I'm pretty sure my wife never snuck out and put a set in for me ;)
  12. Feb 12, 2022 at 5:52 PM
    ABA180
    East Bridgewater MA
    I didn't take any pics but mine looked good for 110K. I've owned the truck since about 6500 miles (see signature for the exact number)
  13. Feb 12, 2022 at 5:54 PM
    Nevin
    Washington
    Well. I'd smoke a vanilla flavored cigar with you in celebration, just for helping that motor.
  14. Feb 12, 2022 at 5:57 PM
    ABA180
    East Bridgewater MA
    I enjoyed my grape flavoured ones, before the state of MA banned em
  15. Feb 12, 2022 at 5:59 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Anti seize is absolutely not necessary nor recommended on sparkplugs with the silver colored threads. That is a sacrificial coating that breaks away to release the threads after getting cooked in the heads over the miles. Adding anti seize can alter your torque value, resulting in potentially stretched spark plugs, or even broken off spark plugs.
    Black oxide threaded sparkplugs absolutely require anti seize, otherwise they get corroded in place. Torque specs on these take anti seize into account.
  16. Feb 12, 2022 at 6:00 PM
    TreeFortRichard
    Brian
    I bet you were in 8th grade and corrupted by big tobacco....and not an adult making adult decisions ;)
  17. Feb 12, 2022 at 6:02 PM
    TreeFortRichard
    Brian
    Yes, I read all the pros and cons on this...I feathered a minuscule amount of anit-seize....
  18. Feb 12, 2022 at 6:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That is either way too much or not enough.
    If you’ve been here long enough you’ll understand the statement above. If not, you will soon enough.
    Best of luck keeping this thread on topic now. ;)
    winkel likes this.
  19. Feb 12, 2022 at 6:39 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    You're lucky they didn't let loose and chang-a-lang on those pistons. lol
  20. Feb 12, 2022 at 6:47 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I use anti-seize and Fram filters. My truck is probably self destructing in my garage, as I type.....
    Tomorrow, it will be as reliable as my '77 Camaro was.... (hint: It was a piece of shit.)
