I just want a simple lift. Will this work?
Discussion in 'Suspension' started by whitetacoma89, May 15, 2013.
  1. May 15, 2013 at 12:23 AM
    whitetacoma89
    whitetacoma89 [OP] Well-Known Member
    Anaheim
    11 Prerunner
    Ive read countless threads on here about lifts and like many other threads i have my question. Im trying to go for a simple lift. I have a few buddies that ran 2'' spacers only in the front and their tacomas looked amazing.
    Ive read enough to know that front spacers shouldnt be considered and that the best way to do it is to get the bilstein 5100s.
    I just want that the front to be leveled with the rear and overall the tacoma to be sitting a little higher.
    My question: If i purchase ONLY the bilstein 5100 adjustable front and rear shocks will this be ok?
    This is what im considering:
  2. May 15, 2013 at 12:26 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    That kit will be fine. If you keep the rear at factory height you will need to set the front at 1.75 for it to be level. If you add the aal to the rear you will have to go up to 2.5...
  3. May 15, 2013 at 12:45 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    X2
  4. May 15, 2013 at 12:51 AM
    tapatio1985
    tapatio1985 Member
    tom
    san diego
    07 prerunnerSR5 sport
    3.5 lift front /2.5 lift back
    I have a 3.3 custom spacer lift in the front of a 2007 tacoma pre-runner almost for a year and no incidents till now i also have the bilstein 5100 series with a .85 lift in the front and 2.5 blocks in the back recommend it there is not a single flinch in the suspection and runs perfect would not trade it for nothing
  5. May 15, 2013 at 3:09 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    "No incidents till now" :confused:
    How's the axle wrap doing?
    OP, ur on the right track for a small decent front lift.
  6. May 15, 2013 at 1:52 PM
    whitetacoma89
    Anaheim
    11 Prerunner
    thanks. i was able to find a discount code for toytec. ive read around here that Down south motorsports sell these for cheaper? can anyone confirm if i need to contact them through here or should i call directly for the cheaper price
  7. May 15, 2013 at 1:56 PM
    whitetacoma89
    Anaheim
    11 Prerunner
    my buddies told me the same story. The spacers were the only thing they ran just to level out and they said the ride was fine. but reading all over here makes me think twice haha. i guess its more critical on the boards.
  8. May 15, 2013 at 1:56 PM
    BulletToothTony
    You can either pm or call DSM. Sonny is a great guy to do business with.
  9. May 15, 2013 at 2:36 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    X2.....Sonny and Micah are great.
    Toytecs shipping fees defeat their discount.........even the 1/4 lean spacer costs more to ship than the part.
  10. May 15, 2013 at 2:45 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Billys at 1.75. Thats want im using. works great
  11. May 15, 2013 at 8:24 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Ok so setting the billys at 1.75 to be level is that with the non TSB rear leafs? ( 2 leafs with helper ) Reason I ask is because I have read some threads that say to set the billys to .85 just a little confused. :confused: Please help.
  12. May 15, 2013 at 8:26 PM
    BulletToothTony
    Do you have the tsb leaf pack (3+1) or factory (2+1)?
  13. May 15, 2013 at 8:29 PM
    tacoma guy
    Joe
    Phoenix Az.
    I have the factory ( 2+1)
  14. May 16, 2013 at 5:44 AM
    tacoma guy
    Joe
    Phoenix Az.
    ^ Bump
  15. May 16, 2013 at 5:52 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Trucks are not all the same.....some are heavier due to build, some sit lower due to mileage/age, some have been worked harder than others.
    TSB or not,the easiest way to get an idea how YOUR specific trucks gunna sit is by using a floor jack to lift the front. Measure the hub/flare distance first.....then use a jack to lift the truck approx 1", then 1.75, then 2.5 and see how it looks front to back.
    Obviously do this on level ground and keep safety in mind.
  16. May 16, 2013 at 5:58 AM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    I have a RC, completely stock in the rear and no TSB. I put 5100s only on the front, set them at .85, and it looks really close to level even without the camper shell. 1.75 would be dead on level or maybe even a little high in the front in my particular situation, but that is still what most folks suggest.
  17. May 16, 2013 at 8:33 AM
    tacoma guy
    Joe
    Phoenix Az.
    Thanks guys I appreeciate the input !! I like the way 1.75 looks but some guys have had issues with vibs and the VSC. Mainly vibs. So Iam going to go .85 setting. Thanks again guys , much appreciated !!!
  18. May 16, 2013 at 8:41 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Keep in mind the vsc can be recalibrated....I don't have vsc thank god, but I think the dealer does the recalibration..... others may know more tho.
  19. May 20, 2013 at 8:43 AM
    Duke1978
    Duke1978 Member
    maryland
    2006 double cab tacoma trd sport
    future = leveling kit and hopefully 285 70 17
    Hello All!
    Wondering what can size tires can I run with the bilstein 5100's adjustables front and rear? 2006 toyota tacoma double cab trd sport 17" rims stock.
  20. May 20, 2013 at 11:24 AM
    whitetacoma89
    Anaheim
    11 Prerunner
    Just placed an order with DSM for the billy 5100s :) + free shipping!
