I keep blowing headlights!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by namylevets, Jan 19, 2010.
  1. Jan 19, 2010 at 6:49 PM
    namylevets
    namylevets [OP] Member
    NH
    06 Tacoma. I am going thru headlights at a rate of 1 every 2 months. WFT!! @ $15-25 a pop I'm getting pissed. I've tryed the expensive one's the cheap ones, I don't touch the glass of the bulb...Anyone else having this problem? Does anyone know why this could be?
  2. Jan 19, 2010 at 7:12 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    05 TRD Sport 4x4 SR5 V6
    Garage Fabbed +2 LT, FOA 2.5 RR w/ Comp Adj, 35 XMTs on Level 8s, 50T Spring Under w/ 13" Shackles, Elite Front Bumper, AP Rear, Retrofitted, Wicked Flow, Custom Roof Rack, Custom Sliders, Custom Scratches, 12" JL and an Audiopipe amp.
    Thats really weird... maybe something is wrong with the electrical system and it sends to much voltage to the light which in turn blows the bulb? I have never heard of this, i'd say take it to the dealer unfortunately.
  3. Jan 19, 2010 at 7:17 PM
    frozen_taco
    frozen_taco Well-Known Member
    Fairbanks AK
    05 Off rd. trd acc. cab with modddds
    flowmaster 50 series delta flow dual exhaust, grillgraft mesh, BHLM, VIPER 2 way auto start, Alpine 10" type R subwoofer, Custom made sub enclosure in back, aries tube steps, K&N, 20% tint, debadged, 20"X9 panther realm rims, Nitto 420 tires, blacked out tails, visors, PIAA headlights, bug guard,
    i have that same prob with my fog lamps they actually blow up.
  4. Jan 19, 2010 at 7:22 PM
    Carson
    Carson
    Modesto, California
    Do you get water or moisture in them? I know that i got water in mine while is was on and it blew up.
  5. Jan 19, 2010 at 7:24 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Stop touching the bulb itself?
  6. Jan 19, 2010 at 7:26 PM
    Happyboucher
    Happyboucher Member
    Boucher
    Baton Rouge
    05 PreRunner DC LB
    Pending
    "I keep blowing headlights!!!!"
    Be careful you don't cut your lips on the glass. :)
    Sorry -- couldn't resist.
  7. Jan 19, 2010 at 7:29 PM
    totmacher
    totmacher Well-Known Member
    Daniel
    TN (memphis-ish)
    '15 TRD OR with duck tape and zip ties
    lifted, removed, relocated, and/or painted some stuff
    when you say that you've tried cheap, expensive, and so on... Did the original stock bulb go out or is it only aftermarket bulbs that are going out?
    I've never had a set "whiter" or "brighter" aftermarket bulbs last more than about a year before one went out. That goes for this truck and the chevy I had before.
  8. Jan 19, 2010 at 8:01 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    ^^Agreed. Stick to OEMs.
  9. Jan 20, 2010 at 11:20 AM
    namylevets
    NH
    Sylvania "silverstar" is what I'm using...I don't believe it's the fact they are defective or cheaply made, I'ts gotta be something with the truck.
  10. Jan 20, 2010 at 11:22 AM
    01tacoprerunner
    01tacoprerunner Lifted 'n Locked 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner with No-slip locker
    4WD Conversion, No-slip locker, 5100s set at 2.5" and shackles in the back. Black 2nd gen rims, and Courser M/T tires, Bull Bar,Fog lights, UWS toolbox, CB Radio, Fiberglass antenna, 2nd Gen Badges, Deck Plate Mod, Diff Breather Mod, Sockmonkey decals.
    hahahaha I was gonna post the same thing......but ya beat me to it.:D
  11. Jan 20, 2010 at 11:27 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    You could have a wire rubbin/shorting out.
  12. Jan 20, 2010 at 11:30 AM
    SLOCOMA
    SLOCOMA Your Toyota Parts Guy
    kenny
    ARI-ZO-NA
    07 TRD PRERUNNER
    It has to be something with the truck.. the only reason why is I just had pulled out my fog bulbs (1st owner for two years) and they are still good.. now I know the headlight bulbs and fogs are completely different....also toyota uses Sylvania..so technically, its OEM..
  13. Jan 20, 2010 at 11:31 AM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '16 4Runner Trail Barcelona Red
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    Just went thru this too. I have the Hella bulbs and one burned on me the other night. Lasted almost a year. We'll see if i they burn again, I'll be going back to OEM :(
  14. Jan 20, 2010 at 11:38 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    ^^ Freaking THIS!
    Do not, under any circumstances, touch the glass of the bulb with your fingers. The oil deposited creates a hot spot and will blow the bulb in under a month's time.
    If you do touch the glass, completely clean it with rubbing alcohol before installing. Even then, keep a spare around.
  15. Jan 20, 2010 at 11:40 AM
    mjp2
    NJ
    BTW, is it always the same side or do both headlights tend to go out?
  16. Jan 20, 2010 at 11:42 AM
    Fever
    Fever Well-Known Member
    Portland, Maine
    TRD OFF RD
    TRD exhaust,remote starter, heated seats, Westin Bull Bar,TRD CAI, Weathertechs
    Is the fuse properly sized?
  17. Jan 20, 2010 at 11:42 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    My buddy uses after market bulbs they they blow on him every six months. I've always stuck with OEM and I think I've had to replace one in the past 10 years.
  18. Jan 20, 2010 at 11:44 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Dammit! Everyone beat me to it!
  19. Jan 20, 2010 at 11:47 AM
    el_smurfo
    el_smurfo Well-Known Member
    Do you have a voltmeter or cheap alternator meter you could watch while you're driving around?
  20. Jan 20, 2010 at 12:31 PM
    BSP4x4
    BSP4x4 Guest
    are there any oem bulbs that are as bright as the silverstar afternmarket "white" lights?
